Nasty gearbox knock ! ? (cbr600fx)
samomighty
PostPosted: 23:58 - 20 Dec 2007    Post subject: Nasty gearbox knock ! ? (cbr600fx) Reply with quote
Hi my bike (cbr600fx) has just developed a knocking noise sounds similar to a chain slipping round a sprocket and doesnt have a set timing pattern but is a lot worse when bike is on centre stand , in any gear ticking over i just bought a whole new chain and sprocket set thinking it was the worn front sprocket and chain but its still there ! could anyone help me with what it could be ?
https://uk.youtube.com/watch?v=Jan8qEH38Sg
Thank's Sam
Timmeh
PostPosted: 00:05 - 21 Dec 2007    Post subject: Reply with quote
it sounds like something's wrong with the clutch. Does the sound change when you pull the lever in?
Could be wrong though.
Paddy Blake
PostPosted: 00:30 - 21 Dec 2007    Post subject: Reply with quote
Did you have the clutch of the bike.
Was any other work done.
Paddy.
samomighty
PostPosted: 00:36 - 21 Dec 2007    Post subject: Reply with quote
Paddy.
Nope all i have done since i bought it is a oil and filter change when i got the bike home then i fitted the sprocket's and chain today. (it's done 32/33k miles to if that helps)
Sam
samomighty
PostPosted: 00:41 - 21 Dec 2007    Post subject: Reply with quote
It started just as a very intermittent knock at different points when i was riding then it started doing it a lot at slow speeds (pulling away up to 30mph was the worst) no matter what gear im in at all times i.e. it would just make single knock sound now and again when i was powering up , down , changing gear , braking and holding a steady engine speed that was when it wasnt so bad i dont fancy trying to test it at the moment as i dont want to reck it !
Sam
PostPosted: 09:12 - 21 Dec 2007    Post subject: Reply with quote
Sam
Could it be a cam chain knock? That year of CBR is known to have iffy cam chain tensioners, and the cam chain slapping against the engine cases might make a similar sound...
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
finpos
PostPosted: 09:17 - 21 Dec 2007    Post subject: Reply with quote
That sounds to me exactly like the chain is hitting something. I'd check the chain tension, wheel alignment, remove the chain guard, and, as you say it's worse on the stand, look to see that the wee nylon slipper is in place where the chain runs over the top of the swingarm.
f.
swaffs
PostPosted: 10:29 - 21 Dec 2007    Post subject: Reply with quote
Sounds like the cam chain tensioner, I have a 2000 FY and it's a common issue.
It won't do any harm but can be annoying.
Here's a detailed description on how to fix it yourself.
https://www.bossturbo.com/cbr/howto_cct.shtml
Some people have been know to change them and it goes again only a few '000 miles later.
The only real way to stop it is to fit a manual one. I couldn't be arsed with that.
Rich Swaffs
Swaffs Photography |
BCF vinyl stickers
"Look not back in anger, nor forward in fear, but around you in awareness."
samomighty
PostPosted: 11:13 - 21 Dec 2007    Post subject: Reply with quote
It sounds like its from the gearbox though and if you watch the rear wheel running in gear when it knocks the back wheel jerks as if there were teeth missing on a gear somewhere but the revs dont die and theres no major sound from the front of the engine but this has only happened over about 80miles it was fine before then while i was on a ride it just got progressively worse now it does it constantly like in the video i posted, its just such a pain it happened before im meant to be going away to a few places for x-mas Sad
samomighty
PostPosted: 11:23 - 21 Dec 2007    Post subject: Reply with quote
I was having a look in the haynes and could the drive shaft bearing be shot seeing as it does it in all gears and gets a bit faster through the gears even though the revs are the same ?
samomighty
PostPosted: 11:50 - 21 Dec 2007    Post subject: Reply with quote
Sorry to keep adding things a bit at a time but i just ran it again and the sound seems to go if i drag the rear brake which again makes me think maybe the rear drive bearing ?
Thank's Sam
jimbothe
PostPosted: 13:48 - 21 Dec 2007    Post subject: Reply with quote
https://cbrworld.net/forums/thread/277240.aspx
any good?
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
samomighty
PostPosted: 14:08 - 21 Dec 2007    Post subject: Reply with quote
It doesnt sound like its from the clutch but there has always been a bit of clutch noise anyway but not a bad noise like this !
PostPosted: 17:56 - 21 Dec 2007    Post subject: Reply with quote
Thank's Sam
Nooooo. If you drag the rear brake this puts tension on the chain in a different way to drive.
Therefore it could be the chain slapping on the swinging arm...
samomighty
PostPosted: 23:30 - 21 Dec 2007    Post subject: Reply with quote
Vincent wrote:
Oh, BTW, try the old screwdriver to the ear test, place it on the clutch cover & near the front sprocket somewhere solid.
Yeah i actually have a proper engine stethoscope so i'll try it over the weekend just such a pain i have taken off the front cover and hugger so i can see everything now but nothing is catching but the top end tapping is getting slighty louder unless im just paranoid now.
Sam
finpos
PostPosted: 14:48 - 22 Dec 2007    Post subject: Reply with quote
The top run of your chain is hitting something. ffs.
f.
samomighty
PostPosted: 18:17 - 22 Dec 2007    Post subject: Reply with quote
f.
Thats what i thought but i striped it down (took sprocket cover and hugger off) and i cant see anything it can hit i also tightened the chain up a fair bit (just while it was on the centre stand without suspension compression) and it still does it Sad
Sam
baldy
PostPosted: 22:32 - 22 Dec 2007    Post subject: Reply with quote
It is yor chain, my bikes do it, it hits the swingarm when it wobbles. my cbr had the camchain thing, that was a lot quieter. If it does it while your riding, your chains not adjusted properly.
One day i will rule the world, just not today.
PostPosted: 09:48 - 23 Dec 2007    Post subject: Reply with quote
Looks to me like you're idling the bike with it on the stand and in gear. Sounds like back-lash in the gears because your idle is so rough. Balance your carbs and it will go away. I would stop doing it in any case before you damage the gearbox.
Ride the bike on the road under gentle power and I bet you don't hea anything. If you do, your chain it too tight or you have a knackered bearing in your rear wheel/sprocket carrier.
TUG
PostPosted: 13:43 - 23 Dec 2007    Post subject: Reply with quote
Does it still knock when the wheel isnt moving? could be bearings in the rear wheel, but i'm probably way out with this suggestion. I hope you sort it out. Thumbs Up
Haz ER-5, innit!
The last post was made 18 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 117.57 Kb
