Welders
Rowey
PostPosted: 19:47 - 21 Jan 2008    Post subject: Welders Reply with quote
I'd like to do a bit of welding.
Screwfix do an ARC welder for £50, its 130A and comes with a little started pack.
Would this be any good for making up brackets and fixing them to frames? Would frame repair, modification and general street fighter esq work, be a bit too much for this welder?
Also what are the differences and benefits between ARC, MIG, TIG?
Thanks in Advance
ZX6R C6F.
PostPosted: 20:28 - 21 Jan 2008    Post subject: Reply with quote
Arc is cheapest and the most common DIY welder. You can buy the rods quite cheaply, it can be used outside in windy conditions, is very portable.
Mig is next-best for DIY. The sets are more expensive but it's easy to gain a reasonable weld with practice. Cannot be used in wind as it blows away the shielding gas. Downside is that you have to buy the gas, either in the tiny bottles that cost the earth for any amount of welding or by hiring a bottle of proper welding gas (like I do), which costs about £100 a year.
Tig is the most expensive of the three to buy and run. The hardware costs more and the shielding gas is pure argon which is double the cost of Mig. It cannot be used outside unless in very still air and the cost of running is higher. Once you have developed a reasonable skill it will give the tidiest results.
On balance I would say if cost, space and room are the primary considerations I would buy an arc welder (aka stick welder, more properly MMA welder). If you can afford the extra, get a tidy Mig welder, you'll get better results from a half-tidy MIG set, just don't forget to turn the as off when you're done.
PostPosted: 20:36 - 21 Jan 2008    Post subject: Reply with quote
Not much of a question then.
Ok, they all do the same thing, ie melts piece of wire up against a piece of metal so they join together. In order to do this effectively, you need to exclude oxygen from the point you are welding at.
A stick welder does this using stuff called flux which is round the outside of the welding rod (the middle being the metal wire). Electricity is passed down the rod, melts at the end, burns the flux, all joins together (in theory).
Stick welders are cheap to buy but are perhaps trickier to use. They are good for thick stuff but in the hands of a novice can turn into a device for blasting holes in bits of metal. Not so easy to do fine/thin stuff with.
MIG (stands for Metal Inert Gas) has a coil of metal wire that is propelled out of the end of the welding nozzle at a speed you set. The electricity moves along the wire which melts onto the workpiece. You can get wire with a flux core, the wire is expensive but the flux-core welders are cheap.
More traditional MIG welders use plain wire and flood the area round the weld site with an inert gas which you have to buy in cylinders. MIG welders are easier to use and are good for fine/thin work. If you get a powerful enough one, they'll also do anything a stick welder will do.
TIG (Tungsten Inert Gas) welders use an even more inert gas than MIG ones and do something different with the electric current (here's where it gets beyond me). You can weld non-ferrous metals using a TIG set such as aluminium. TIG setups are expensive.
You also get oxy-acetylene welding for which you use two gas cylinders and a rod of metal. It is an old fashioned way of welding (although technically you can use it to weld anything). It is particularly good for really thin stuff.
So, a novice (like I am) is probably best off getting the most powerful MIG set he can afford. I have been told that an inverter type set is the best one to go for. This setup would be most flexible.
From personal experience, the best thing you can get is an auto-darkening welding mask. This lets you use both hands on the nozzle and importantly, lets you see what you're doing. There is nothing quite like seeing what you're doing for getting a job done properly.
I was just getting the hang of my cheap, Chinese, gassless MIG (flux cored wire, it was the wrong welder to buy, I'd get a decent, second hand, inverter MIG set next time) when the motor jammed and caught fire. Whole thing went up, it sucked.
Keep a suitable fire-extinguisher near at hand and make sure your 'welding bay' is fireproof, you WILL set stuff on fire.
Rowey
PostPosted: 20:38 - 21 Jan 2008    Post subject: Reply with quote
Thanks Geri and Stinkwheel, would the 130A ARC welder be sufficient for welding pannier brackets, and subframes?
The ARC sounds the best for my uses, as it's cheap to buy and run. My only concern is the strength of the welds on various metals and thicknesses.
ZX6R C6F.
PostPosted: 20:50 - 21 Jan 2008    Post subject: Reply with quote
Trial and error. The weld has to penetrate deep into the metal you are welding. A tidy weld isn't necessarily a good weld if there is no penetration.*
Preparation of your piece is important, don't try to weld rust, ideally leave a 'channel' to flow the weld into by chamfering the edges of the pieces of metal with a grinder.
In fact, get out the grinder every time you get out the welder. Don't try for immaculate welds, try for good penetration and tidy up the seagull shit later.
If you've done something structural, weld it up, then try to break it. Like my pannier racks. I welded them up, ground the spatter off then clamped them in a vice and attacked the welds with a lumphammer. Couldn't break them, test passed Thumbs Up.
Don't try anything really structural until you are happy you are penetrating properly. The only way to check is to x-ray the piece or to chop it apart again so collect offcuts, practice welding them together and cut them up again to see if it was a truly 'good' weld.
* I have seen someone off this forum (who shall remain nameless) weld a major structural componant to his bike by joining two flats side by side. He did a lovely weld all the way round the two bits of flat, looked like a bought one right up until the point the wheel fell off (luckily while stationary). When you looked at the broken part, there was only a couple of mm penetration between the two bits of metal. It's a wonder it held together as long as it did.
PostPosted: 20:54 - 21 Jan 2008    Post subject: Reply with quote
Yes, the stick welder would do that - BUT - there are some things to consider.
You have to practice - a lot - to get even a half-tidy weld. Not a problem coz all it will cost you is a box of rods & a decent suntan.
You can burn-through on thin metals, especially if you are welding a thicker bracket to a thinner frame tube.
You must get the workpiece clean of paint, rust & other contaminants, to get a good weld and give yourself half a chance.
You need to ensure you don't expose your eyes and skin to the light. Wear sleeves and get a decent head-mounted mask, and get some welding gauntlets (aka motorcycle gloves, see other thread Very Happy) You can very easily blind yourself with arc-eye, and even mild exposure can dry out your corneas enough to make it very uncomfortable. Shutting your eyes does no good at all the ultraviolet light just goes right through your lids.
I would advise:
Get some off-cuts from your local sheet metalworks. Just small stuff 2-3mm thick. If you tell them what you're about they will probably let you raid the scrap bin. Buy a 5" angle grinder, and get an abrasive flap disc like this:
https://www.abbeypowertools.co.uk/webupload/APOWER/DRAPER/APOWERLARGE41468_APT112.jpg
This disc is great for removing paint & rust without taking off too much material. I suggest 60 and 120 grit.
Big Pete
PostPosted: 13:29 - 22 Jan 2008    Post subject: Reply with quote
all the above, plus - wear safety specs when you are chipping the slag off.
Trust me, I`m an engineer
GarageOfPower.co.uk
PostPosted: 13:48 - 22 Jan 2008    Post subject: Reply with quote
A piece of advice which applies to more than one area of life! Wink
Walloper
PostPosted: 16:45 - 22 Jan 2008    Post subject: Reply with quote
Since we are well beyond the point of pedant....
In critical welds, use of a carbide cutter or bastard file to finish the prep is desirable, as this limits any chance of 'inclusions' in the weld from the particles of abrasive that grinding leaves embedded in the surface.
These are not normally visible to the naked eye, but over time it can lead to failure of the weld due to propagation of microscopic cracks where impurities lie.
Buy the book too. Or get your smelly-arse into night-school. Welding is still respected as a 'trade'. It is not a paper-round.
Enjoy and work safe. Arc-Eye is worse than carpet burns on your knees
Jamie S
PostPosted: 17:31 - 22 Jan 2008    Post subject: Reply with quote
The reason being that the slag is not magnetic , there for if you get it in your eyes the hospital have a harder job getting it out, thus equals more pain for you. It happened to a lad in college a few weeks back, just get a nice pair of goggles that are comfy to wear and it will be come common practice to use them.
PostPosted: 17:39 - 22 Jan 2008    Post subject: Reply with quote
Also, make sure the legs of your jeans are over your boots/trainers, because a piece of hot slag down the front of your footwear burns like a beeeeatch. Happened to me at college and it burnt a hole in my foot about 8mm deep.
Walloper
PostPosted: 18:09 - 22 Jan 2008    Post subject: Reply with quote
I'd advise getting some decent PPE too BTW.
PostPosted: 18:12 - 22 Jan 2008    Post subject: Reply with quote
Ex RAF flying suits make good welding overalls. They are flame retardant cotton, pretty thick and have fastenings round the wrists and ankles.
aero
PostPosted: 19:14 - 22 Jan 2008    Post subject: Reply with quote
The last frame I built was stick welded, so were many Norton frames. Now I have a MIG. The thing is when welding thin tube, which is what you'll find on your average bike frame, you will need a DECENT stick set. a £50 one will not give a very stable arc.
You can get a decent set from ebay, IE and Oxford or a Pickhill for similiar sums. These are heavy oiled filled sets with high quality transformers that will last a life time.
I use a MIG now for two rerasons, one the smoke you get from stick welding is very unpleasant and fills your workshop very quicky. Stainless rods will require a extractor fan as the fumes are highly toxic. Two chipping the slag off is a real pain in the backside.
The other 'problem' with stick welding is that you have to be very skilled to use it. Especially on thin stuff. You need a set that is stable and highly controlable and a lot of practise at it. Personally I think it makes you a better welder, so never saw learning to stick weld as a problem.
Avoid Cheap MIG welders too. More trouble then they are worth. I bought a professional machine this time, well worth the extra, But a £350 Clarke machine will do a good job too. Clarke are the best of the available to all machines
https://i27.tinypic.com/2iuffdf.jpg
One of my old Oxfords
https://i26.tinypic.com/11rx0n5.jpg
70's & 80's 4 stoke Yamaha Guru and professional workshop dweller.
Whosthedaddy
PostPosted: 19:19 - 22 Jan 2008    Post subject: Reply with quote
I have absolutely no idea how the hell you think they remove the FB? With a magnet?
On a completely pointless piece of information regarding stick welding is the fact that you can use metal coat hangers instead of welding rods if in a push.
aero
PostPosted: 19:27 - 22 Jan 2008    Post subject: Reply with quote
I'm not riding anything you've welded! Shocked Shocked Shocked
Walloper
PostPosted: 20:58 - 22 Jan 2008    Post subject: Reply with quote
You can get an excellent finish using the wavy wire from Chain-link fencing too.
Ask for 'ferrous flux' so the nurse can draw the slag out your eyes with a magnet just to be on the safe side. Wink
Ichy
PostPosted: 21:10 - 22 Jan 2008    Post subject: Reply with quote
Nice frame, what do you use to bend the pipe, what size and spec pipe are you using? Any jigs or all by hand?
Whosthedaddy
PostPosted: 21:17 - 22 Jan 2008    Post subject: Reply with quote
Clicky
Thats a safe bet as I have yet to have a go. Do they do evening courses in welding, could be good if not just something to get for the evening away from the wife, kids, dog...
SoND
PostPosted: 21:22 - 22 Jan 2008    Post subject: Reply with quote
The reason being that slag is fucking hot and it's going to hurt more putting it into your eye that taking it out.
No way, even if you did manage to get an arc started without sheilding it will spatter and cover you in hot molten balls.
TIG works by striking an arc with an unconsumable tungsten electrode while shielded with either 100% argon or helium. It acts like a very focused oxyacetalyne welder by melting exactly where you point the tungsten and you add the filler rod manually.
You can convert a stick welder into a cheap DC TIG setup if you connect a torch and gas to it. With this you can weld pretty much anything (steel, stainless, copper, titanium etc) but it will not have any of the features of a dedicated TIG machine (pre/post gas flow, high frequency starting etc)
If you want to weld aluminium you need an AC TIG machine which is very expensive in comparison (~2000 for a half decent one + equipment) to the others and not for beginners.
MattEMulsion
PostPosted: 21:25 - 22 Jan 2008    Post subject: Reply with quote
I go for a MIG everytime when choosing a welder to suit your particular needs.
Yamaha YZF-R6
Blackwolf
Burgerfist
PostPosted: 22:37 - 22 Jan 2008    Post subject: Reply with quote
On the contrary, i found using a TIG welder for the first time easy, never know perhaps i'm a natural Laughing but i found MIG the best for the amusement factor of all the sparks (slag??) flying off Smile
PostPosted: 12:13 - 23 Jan 2008    Post subject: Reply with quote
I spent ages learning to TIG weld. I found that I could quite easily get a lovely neat weld, but the penetration was always crap.
I found that if I spent a little more time on the weld, didn't worry so much about neatness and twisted the rod as I go (just a little left and right) and brought the rod in using a smooth slightly back and forth movement, I could get a lovely weld with good penetration that looks a little bit like the welds you see on ally bike frames. Obviously a lot less neat, but it still had that 'cake icing' look to it.
That took me two full days of near non stop welding to get to that point, and I got serious welders flash on my arms. D'oh!
Still, the structure I made held together, which surprised me considering how heavy it was and how much weight it had to carry.
Just to give you an idea, I built a steel raft out of six oil barrels and some 20mm box section. The whole thing weighed a LOT, and it carried six people, a plywood deck and a fake boxing ring, with four rowers and two people mock boxing! It also carried a car battery, two huge speakers and an expensive 12v amp, playing the rocky theme tune on a loop! It was then rowed around half a mile up the thames, and back again, and was also towed by a motorboat.
It was so heavy the raft came last in the race, and even the motorboat struggled to tow it!! Very Happy
Whosthedaddy
PostPosted: 12:16 - 23 Jan 2008    Post subject: Reply with quote
2 inch of weld will hold / support 2 tonnes (according to a Car is Born anyways).
Jamie S
PostPosted: 12:44 - 23 Jan 2008    Post subject: Reply with quote
If it was the land rover restoration one that you watched then he actually said an inch of weld will hold a tonne, he tested his theory with a half tonne bag of fertilizer and half an inch of weld between two plates , he lifted it up using a tractor and it held perfectly.
The last post was made 18 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 141.56 Kb
