| Rowey |
 Rowey World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 20:28 - 21 Jan 2008 Post subject: |
Arc is cheapest and the most common DIY welder. You can buy the rods quite cheaply, it can be used outside in windy conditions, is very portable.
Mig is next-best for DIY. The sets are more expensive but it's easy to gain a reasonable weld with practice. Cannot be used in wind as it blows away the shielding gas. Downside is that you have to buy the gas, either in the tiny bottles that cost the earth for any amount of welding or by hiring a bottle of proper welding gas (like I do), which costs about £100 a year.
Tig is the most expensive of the three to buy and run. The hardware costs more and the shielding gas is pure argon which is double the cost of Mig. It cannot be used outside unless in very still air and the cost of running is higher. Once you have developed a reasonable skill it will give the tidiest results.
On balance I would say if cost, space and room are the primary considerations I would buy an arc welder (aka stick welder, more properly MMA welder). If you can afford the extra, get a tidy Mig welder, you'll get better results from a half-tidy MIG set, just don't forget to turn the as off when you're done. ____________________ a.k.a 'Geri'
| stinkwheel |
 Posted: 20:36 - 21 Jan 2008 Post subject: |
Not much of a question then.
Ok, they all do the same thing, ie melts piece of wire up against a piece of metal so they join together. In order to do this effectively, you need to exclude oxygen from the point you are welding at.
A stick welder does this using stuff called flux which is round the outside of the welding rod (the middle being the metal wire). Electricity is passed down the rod, melts at the end, burns the flux, all joins together (in theory).
Stick welders are cheap to buy but are perhaps trickier to use. They are good for thick stuff but in the hands of a novice can turn into a device for blasting holes in bits of metal. Not so easy to do fine/thin stuff with.
MIG (stands for Metal Inert Gas) has a coil of metal wire that is propelled out of the end of the welding nozzle at a speed you set. The electricity moves along the wire which melts onto the workpiece. You can get wire with a flux core, the wire is expensive but the flux-core welders are cheap.
More traditional MIG welders use plain wire and flood the area round the weld site with an inert gas which you have to buy in cylinders. MIG welders are easier to use and are good for fine/thin work. If you get a powerful enough one, they'll also do anything a stick welder will do.
TIG (Tungsten Inert Gas) welders use an even more inert gas than MIG ones and do something different with the electric current (here's where it gets beyond me). You can weld non-ferrous metals using a TIG set such as aluminium. TIG setups are expensive.
You also get oxy-acetylene welding for which you use two gas cylinders and a rod of metal. It is an old fashioned way of welding (although technically you can use it to weld anything). It is particularly good for really thin stuff.
So, a novice (like I am) is probably best off getting the most powerful MIG set he can afford. I have been told that an inverter type set is the best one to go for. This setup would be most flexible.
From personal experience, the best thing you can get is an auto-darkening welding mask. This lets you use both hands on the nozzle and importantly, lets you see what you're doing. There is nothing quite like seeing what you're doing for getting a job done properly.
I was just getting the hang of my cheap, Chinese, gassless MIG (flux cored wire, it was the wrong welder to buy, I'd get a decent, second hand, inverter MIG set next time) when the motor jammed and caught fire. Whole thing went up, it sucked.
Keep a suitable fire-extinguisher near at hand and make sure your 'welding bay' is fireproof, you WILL set stuff on fire. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Rowey |
| stinkwheel |
 Posted: 20:50 - 21 Jan 2008 Post subject: |
| Rowey wrote: | My only concern is the strength of the welds on various metals and thicknesses. |
Trial and error. The weld has to penetrate deep into the metal you are welding. A tidy weld isn't necessarily a good weld if there is no penetration.*
Preparation of your piece is important, don't try to weld rust, ideally leave a 'channel' to flow the weld into by chamfering the edges of the pieces of metal with a grinder.
In fact, get out the grinder every time you get out the welder. Don't try for immaculate welds, try for good penetration and tidy up the seagull shit later.
If you've done something structural, weld it up, then try to break it. Like my pannier racks. I welded them up, ground the spatter off then clamped them in a vice and attacked the welds with a lumphammer. Couldn't break them, test passed .
Don't try anything really structural until you are happy you are penetrating properly. The only way to check is to x-ray the piece or to chop it apart again so collect offcuts, practice welding them together and cut them up again to see if it was a truly 'good' weld.
* I have seen someone off this forum (who shall remain nameless) weld a major structural componant to his bike by joining two flats side by side. He did a lovely weld all the way round the two bits of flat, looked like a bought one right up until the point the wheel fell off (luckily while stationary). When you looked at the broken part, there was only a couple of mm penetration between the two bits of metal. It's a wonder it held together as long as it did. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Pete. |
 Pete. Super Spammer
 Posted: 20:54 - 21 Jan 2008 Post subject: |
Yes, the stick welder would do that - BUT - there are some things to consider.
You have to practice - a lot - to get even a half-tidy weld. Not a problem coz all it will cost you is a box of rods & a decent suntan.
You can burn-through on thin metals, especially if you are welding a thicker bracket to a thinner frame tube.
You must get the workpiece clean of paint, rust & other contaminants, to get a good weld and give yourself half a chance.
You need to ensure you don't expose your eyes and skin to the light. Wear sleeves and get a decent head-mounted mask, and get some welding gauntlets (aka motorcycle gloves, see other thread ) You can very easily blind yourself with arc-eye, and even mild exposure can dry out your corneas enough to make it very uncomfortable. Shutting your eyes does no good at all the ultraviolet light just goes right through your lids.
I would advise:
Get some off-cuts from your local sheet metalworks. Just small stuff 2-3mm thick. If you tell them what you're about they will probably let you raid the scrap bin. Buy a 5" angle grinder, and get an abrasive flap disc like this:
https://www.abbeypowertools.co.uk/webupload/APOWER/DRAPER/APOWERLARGE41468_APT112.jpg
This disc is great for removing paint & rust without taking off too much material. I suggest 60 and 120 grit. ____________________ a.k.a 'Geri'
| Big Pete |
 Big Pete Spanner Monkey
| MarJay |
 MarJay But it's British!
| Walloper |
 Walloper Super Spammer
| Jamie S |
 Jamie S World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 17:39 - 22 Jan 2008 Post subject: |
Also, make sure the legs of your jeans are over your boots/trainers, because a piece of hot slag down the front of your footwear burns like a beeeeatch. Happened to me at college and it burnt a hole in my foot about 8mm deep. ____________________ a.k.a 'Geri'
| Walloper |
| stinkwheel |
| aero |
 aero Nova Slayer
 Posted: 19:14 - 22 Jan 2008 Post subject: |
The last frame I built was stick welded, so were many Norton frames. Now I have a MIG. The thing is when welding thin tube, which is what you'll find on your average bike frame, you will need a DECENT stick set. a £50 one will not give a very stable arc.
You can get a decent set from ebay, IE and Oxford or a Pickhill for similiar sums. These are heavy oiled filled sets with high quality transformers that will last a life time.
I use a MIG now for two rerasons, one the smoke you get from stick welding is very unpleasant and fills your workshop very quicky. Stainless rods will require a extractor fan as the fumes are highly toxic. Two chipping the slag off is a real pain in the backside.
The other 'problem' with stick welding is that you have to be very skilled to use it. Especially on thin stuff. You need a set that is stable and highly controlable and a lot of practise at it. Personally I think it makes you a better welder, so never saw learning to stick weld as a problem.
Avoid Cheap MIG welders too. More trouble then they are worth. I bought a professional machine this time, well worth the extra, But a £350 Clarke machine will do a good job too. Clarke are the best of the available to all machines
https://i27.tinypic.com/2iuffdf.jpg
One of my old Oxfords
https://i26.tinypic.com/11rx0n5.jpg ____________________ 70's & 80's 4 stoke Yamaha Guru and professional workshop dweller. |
| Whosthedaddy |
 Whosthedaddy Super Spammer
| aero |
 aero Nova Slayer
 Posted: 19:27 - 22 Jan 2008 Post subject: |
I'm not riding anything you've welded!  ____________________ 70's & 80's 4 stoke Yamaha Guru and professional workshop dweller. |
| Walloper |
 Posted: 20:58 - 22 Jan 2008 Post subject: |
You can get an excellent finish using the wavy wire from Chain-link fencing too.
Ask for 'ferrous flux' so the nurse can draw the slag out your eyes with a magnet just to be on the safe side.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Ichy |
 Ichy World Chat Champion
| Whosthedaddy |
 Posted: 21:17 - 22 Jan 2008 Post subject: |
Clicky
Thats a safe bet as I have yet to have a go. Do they do evening courses in welding, could be good if not just something to get for the evening away from the wife, kids, dog... ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| SoND |
 SoND World Chat Champion
| MattEMulsion |
 MattEMulsion World Chat Champion
| Blackwolf |
 Blackwolf Burgerfist
 Posted: 22:37 - 22 Jan 2008 Post subject: |
On the contrary, i found using a TIG welder for the first time easy, never know perhaps i'm a natural but i found MIG the best for the amusement factor of all the sparks (slag??) flying off  ____________________ Current: Ducati Multistrada 1200s |
| MarJay |
 Posted: 12:13 - 23 Jan 2008 Post subject: |
| Blackwolf wrote: | On the contrary, i found using a TIG welder for the first time easy, never know perhaps i'm a natural  but i found MIG the best for the amusement factor of all the sparks (slag??) flying off  |
I spent ages learning to TIG weld. I found that I could quite easily get a lovely neat weld, but the penetration was always crap.
I found that if I spent a little more time on the weld, didn't worry so much about neatness and twisted the rod as I go (just a little left and right) and brought the rod in using a smooth slightly back and forth movement, I could get a lovely weld with good penetration that looks a little bit like the welds you see on ally bike frames. Obviously a lot less neat, but it still had that 'cake icing' look to it.
That took me two full days of near non stop welding to get to that point, and I got serious welders flash on my arms. D'oh!
Still, the structure I made held together, which surprised me considering how heavy it was and how much weight it had to carry.
Just to give you an idea, I built a steel raft out of six oil barrels and some 20mm box section. The whole thing weighed a LOT, and it carried six people, a plywood deck and a fake boxing ring, with four rowers and two people mock boxing! It also carried a car battery, two huge speakers and an expensive 12v amp, playing the rocky theme tune on a loop! It was then rowed around half a mile up the thames, and back again, and was also towed by a motorboat.
It was so heavy the raft came last in the race, and even the motorboat struggled to tow it!!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Whosthedaddy |
 Posted: 12:16 - 23 Jan 2008 Post subject: |
2 inch of weld will hold / support 2 tonnes (according to a Car is Born anyways). ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| Jamie S |
The last post was made 18 years, 275 days ago. Instead of replying here, would creating a new thread be more useful? |
