TL1000S
garth
PostPosted: 09:06 - 12 Feb 2008    Post subject: TL1000S Reply with quote
Anyone own one?
Common faults, opinions, what to look for?
Cheers.
PostPosted: 09:46 - 12 Feb 2008    Post subject: Reply with quote
Oil sight glass in the wrong place on earlier models.
Ideally you want better suspension, that's about it I think......
PostPosted: 09:48 - 12 Feb 2008    Post subject: Re: TL1000S Reply with quote
Haven't owned, or infact ridden one, though have ridden a TL-R.
I'd go with another owner's (another racer) opinion "not all their cracked up to be, I'd take my J model ZX6 out for fun anyday".
But then I have a well known dislike of twins.
Am still tempted to get one for a fairly boring 'get to work bike' some day.
Fawbish
PostPosted: 09:51 - 12 Feb 2008    Post subject: Reply with quote
I believe the earlier models with the rotary rear suspension were dubbed the "Widowmaker" Thumbs Up
Not ridden one however....though my mate rides a TL1000R. And he loves that, and it still has that rotary suspension methinks. He doesnt seem to have a massive problem with it *shrugs*
phk6
PostPosted: 09:53 - 12 Feb 2008    Post subject: Reply with quote
yea d's bike stil has the rotary damper but he's not made any major comments about it i dont think.
Current .. 2008 BMW R 1200 GS Adventure ..
Before .. 2003 Yamaha Fazer 1000 .. 2004 Kawazaki Z1000 .. 2003 Suzuki Sv1000s .. 1999 zx6r Track Bike .. 1999 CB 500 Cup ..
/Phil
garth
PostPosted: 10:10 - 12 Feb 2008    Post subject: Reply with quote
Engine is pretty similar (slightly less power on the S)
Go on..
Dav1son
PostPosted: 10:53 - 12 Feb 2008    Post subject: Reply with quote
Do it...
think of the front tyres you will save having a wheelie machine.
Future: ....
Present: GSXR-750 L0
Past: ZX10R C2H, TL1000R, CBR400 NC29, GPR50RR/RS50
killa
Won't Shut Up
PostPosted: 11:47 - 12 Feb 2008    Post subject: Reply with quote
You'll need a keen eye for picking up a second hand one, sometimes can be a well used, nutters tool.
Fork seals
Bearings
Calipers
Head stock
etc...
A guy at work has one with welded VTR cans on it, never heard a TL-S like it, ever. Maybe it's the way he rides it, but it actually freaks me out. Confused
PostPosted: 13:32 - 12 Feb 2008    Post subject: Reply with quote
You need to go for an early S to get the full power engine, later ones have dropped power, as has the R. However this ‘R’ model was lightly tuned – filter, full system and fuelling setup to suit.
This one did have Ohlins shock and fork internals as well as steering damper.
As with any twin, it needs to be revved to make properly decent progress, yet doesn’t seem to reward as much when you do.
It’s far from light and does feel a bit barge-like in handling compared to a bit sportier bikes. With the Ohlins stuff it seemed pretty stable, which some consider to be a good thing; but then some consider cruisers to be a good thing Razz (admittedly a bit more stability would be useful on my 675, though).
The power does come in fairly strong from mid revs, but feels more train-like than my slightly-trick zx9 which feels a bit more ‘lively’ (and has about an extra 20hp on top as well as maybe 30kg less, so not too surprising).
TUG
PostPosted: 20:20 - 12 Feb 2008    Post subject: Reply with quote
Widow maker!!!! WHere Where!? I want!!!!
Get one, there a beast of a machine, if you cant hack it.... Well the clues in the name! Thumbs Up Laughing
Haz ER-5, innit!
Jack_Cheese
PostPosted: 20:21 - 12 Feb 2008    Post subject: Reply with quote
Just make sure it was recalled under warranty. I'm sure there were a few recalls made, one of which was to replace the frame. IIRC the damper not only contributed to a nasty tank-slapping tendancy, but also cracked the frame. Can anyone confirm this? Im fairly certain but not 100% sure.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
TUG
PostPosted: 20:23 - 12 Feb 2008    Post subject: Reply with quote
Jack
We had a discussion about this last time, and i said they were re called but i was wrong aparantly...
they fitted a normal damper in the end.
Haz ER-5, innit!
Misc
PostPosted: 20:46 - 12 Feb 2008    Post subject: Reply with quote
I see the selling the Gsxr for a more sensible bike is out of the window then Garth? Smile
Good luck with your findings.
McJamweasel
BCF Junkie
PostPosted: 21:14 - 12 Feb 2008    Post subject: Reply with quote
One of the mechanics at work has got a '97 model that he bought new, it's still going strong as his summer commuter bike 50-odd thousand miles later. He's replaced the suspension with Ohlins kit and reckons that you do need to ditch the rotary damper. His is kicking out around 120rwhp, thats with a full akra system, power commander and a filter.
They were recalled to be fitted with a steering damper, later models came with them as standard. One of the mags tested an early one a couple of months ago and they said that they're actually pretty tame compared to the modern thou's.
the grim reaper
PostPosted: 21:18 - 12 Feb 2008    Post subject: Reply with quote
The rear damper is rubbish, as is the standard steering damper. They never recalled for the frame, although only a handful cracked. The point to check is where the spring of the seperate pre-load damper mounts, on the right hand side at the rear.
The engine is a good 'un and less 'twin-like' than a lot of other twins, rewarding revs as opposed to midrange. They were torque limited (by way of the ignition) in the first three gears, you can buy a tre (timing retard eliminator) to remove this but it's basically a 15 ohm resistor.
I quite liked the one my ex had and I don't like twins, as a rule. It reached it's limit much sooner than my Blade though, knee down felt lively, although that was from the reart and was almost certainly that damper.
I'd have one as a wheelie bike but not as a first bike.
Grim
garth
PostPosted: 21:30 - 12 Feb 2008    Post subject: Reply with quote
Pfft
I've a very short attention span.
Not done with the Gsxr yet. There was someone interested in a swap and was weighing up my options.
Irezumi aka Reuben
Carrot Top
PostPosted: 21:41 - 12 Feb 2008    Post subject: Reply with quote
Ridden an SRAD 750 and a TLS. I'd take the GSXR every time.
TLS was a bit tame and dissapointing tbh. I was expecting a bike that was a mental handful. Feel's like all 1000cc twins I've ridden, deceptively quick but quite boring.
I have to agree with G! Mad
oddkid
PostPosted: 01:41 - 13 Feb 2008    Post subject: Reply with quote
I was talking about getting one not long ago. According to a reliable source though i havn't had chance to ride either myself, the TLS is faster and more aggressive then a 996 on the power delivery. Sounds like an excellent fun ride to me.
Always read the destructions.
ZRX61
Victor Meldrew
PostPosted: 02:03 - 13 Feb 2008    Post subject: Reply with quote
Grim
Somewhat more than "a handful". In the US they are hard to find owing to Suzuki *alledgedly* buying them up & *making them disappear". Neighbor had one that went thru 3 frames in less than a year. Suzuki paid him enough to allow him to buy a brand new fully optioned G'Wing... Affadavits were signed & he legally can't own another Suzuki in this lifetime.... he unwittingly left the paperwork on the coffee table while I was over there...
veeeffarr
PostPosted: 02:05 - 13 Feb 2008    Post subject: Reply with quote
Suzukis are wank anyway
2004 SV, never ridden in shit weather, flaking engine paint, shitted down pipes, corroded radiator.
garth
PostPosted: 08:59 - 13 Feb 2008    Post subject: Reply with quote
And one lying through his teeth owner?
PostPosted: 09:06 - 13 Feb 2008    Post subject: Reply with quote
XlonewolfX wrote:
Jack
The rotary damper was never changed. It was rotary from the start of the TL-S' life until the end.
They fitted cheapo steering dampers to try and cure the slapping.
Jack_Cheese
PostPosted: 10:25 - 13 Feb 2008    Post subject: Reply with quote
Quite correct Thumbs Up Suzuki being Suzuki, they decided not to bother re-engineering the suspension and sorting it properly, so they just bodged it instead!
Kris
PostPosted: 10:47 - 13 Feb 2008    Post subject: Reply with quote
Grim
Quite believable.
Remember the Hayabusa subframe 'issues' a few years ago?
Tut Tut
www.prisonplanet.com
veeeffarr
PostPosted: 11:14 - 13 Feb 2008    Post subject: Reply with quote
Nah, it didn't show any evidence of poor weather riding, just the paint finish and corrosion in some places, even the undertray was spotlessly clean.
Is a good enough bike, just I can't believe the finish.
T
The last post was made 18 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 131.71 Kb
