yamaha sr125 inlet valve
nightshaddow
PostPosted: 20:12 - 18 Feb 2008    Post subject: yamaha sr125 inlet valve Reply with quote
hi this is my problem
i have a 1991 yamaha sr 125 and i had some really bad rattleing l8ly, i reset the tappets and it ran smooth for about 250 miles, then it started again, so i looks at the tappet again and the bottom of it was compleatly crushed, i replaced the tappet thinking old bike needs replacing so did the inlet and the exhaust tapets, i have done about 500 mile since then and the inlet tappet has been crushed again, i have ajusted it twice (second this weekend) and a bit worried anyone have any ideas, could it be a dodgy valve or something more serious
cheers
Ichy
PostPosted: 22:24 - 18 Feb 2008    Post subject: Reply with quote
Do you have any photo's? It takes a hell of a lot to damage a healthy tappet, they tend to be at least surface hardened.
Did you adjust it correctly, ensuring there was a gap when the valve was closed?
TUG
PostPosted: 23:24 - 18 Feb 2008    Post subject: Reply with quote
My god, sounds like you set the gap at the wrong point maybe??? Shocked
250-500 miles and it died again thats really bad, if its not you setting it wrong then there is something seriously wrong.
Haz ER-5, innit!
aero
PostPosted: 10:06 - 19 Feb 2008    Post subject: Reply with quote
Those engines tend to suffer from a lack of lube at the top end. It maybe that the cam is wearing away at the cam follower.
70's & 80's 4 stoke Yamaha Guru and professional workshop dweller.
nightshaddow
PostPosted: 17:39 - 19 Feb 2008    Post subject: Reply with quote
i will take photos of current tappet at the weekend when it's light, i sould explain i am no newbee wen it comes to mechanics i set it right everytime,
engine tdc bothe valves are closed
set inlet to bettween 0.05 - 0.09 mm (as stated in haynes manuel)
set exhaust to between 0.11 - 0.15 (same sorce)
runs beautifully for about 50 -60 miles then you get a slight tap which gets worse till ajusted
i do roughly 25 miles a day and i check most weekends the distance due to the amount of tapping it will incure in a week
camchain is prety clean and at correct tensionand the cam cog is clean with no broken teeth
any ideas
aero
PostPosted: 21:24 - 19 Feb 2008    Post subject: Reply with quote
Taken from a 'tapetty' SR engine where the owner had , surprizingly, been chasing the valve adjustment. It did sound a bit rough as he pulled up. Very Happy
https://i29.tinypic.com/jv10s0.jpg
Billd
PostPosted: 18:27 - 21 Feb 2008    Post subject: Reply with quote
I had an SR125 in about '88. I know it's a lot older than yours but I corcscrewed several valve stems just from red lining it too much. In fact, I still have a brand new valve somewhere from these days... Smile
nightshaddow
PostPosted: 19:34 - 22 Feb 2008    Post subject: Reply with quote
there is another symptom.... it my not be related, thought i have a sneaking suspision it is
it has developed over the past few months a backfire, not a miss fire but a true back fire, it doesnt do it on tick over steady revs or high revs but when i throtle of or down shift it dont half pop.... normaly wen the revs get to 3000rpm wen slowing down,,,, any ideas
nightshaddow
PostPosted: 17:15 - 23 Feb 2008    Post subject: Reply with quote
ok these are from the new tappet put in around 500 miles ago Evil or Very Mad
https://img184.imageshack.us/img184/461/imag0011qt5.jpg
https://img519.imageshack.us/img519/9311/imag0012ln5.jpg
I am now on a new tappet 3rd one in 2 months plz help
PostPosted: 19:06 - 23 Feb 2008    Post subject: Reply with quote
Bit of a toughie this one but I would suspect one of two things:
1) Poor oiling at the top-end, causing the follower to wear against the cam until it's got so loose it's hammering the adjuster down. Could be from a clogged strainer or more likely an oil passage up to the head is restricted. Only a strip-down would reveal the fault. The cam is probably scrap.
2.) You've suffered a bit of valve float causing a piston-valve strike and bent the valve a bit. The valve is slightly open causing loss of compression and too small a piston/valve clearance, and the piston is just clipping the valve at revs.
I prefer the 1st option, the 2nd is frankly unlikely on the SR engine.
nightshaddow
PostPosted: 19:43 - 23 Feb 2008    Post subject: Reply with quote
ok so this is my fav option i striped down the head barrel already, bout 3 months ago i lost all power on my way home from harrogate to york (18 miles or so) managed to limp home then started work on her,
my findings were the same valve had lost the nut and the tappet had worked loose all inspection revealed all to be fine and no dammage to cam or head valves *looked* fine (i did not inspect local garrage took in the head and checked it) at the same time i serviced and checked all the way down to the conrod, piston and barrel also removed,
https://img408.imageshack.us/img408/2880/imag0018sv7.jpg
about the end of december this problem started
anyone know of any good stockest for sr parts and plz dont say a breakers i never use used parts in the engine Smile
aero
PostPosted: 19:50 - 23 Feb 2008    Post subject: Reply with quote
Utter schisse! If you bent a valve even a thou or so it would stick in the valve guide and wreck the piston. Situtation two is that just the head gets bent a little in which case it wouldn't seal and the engine won't run!
These are either cheap crap adjusters from India or the clearence has been badly wrong. In either case you need to look at the cam and the other ends of rocker arms to what's going on.
PostPosted: 19:51 - 23 Feb 2008    Post subject: Reply with quote
When you rebuilt the top-end, did you use any hylomar/instant gasket anywhere?
aero
PostPosted: 19:55 - 23 Feb 2008    Post subject: Reply with quote
Looking at that there is loads of oil up there.
The only other thing I can think of is - has someone wound on a standard 8mm nut on to the adjuster? The adjuster has a 1mm thread pitch, where as the 8mm nut has 1.25. The adjuster being a harder metal wins every time, leaving the lock nut in capable of locking.
Or has the adjuster lock nut simply not been tightened up enough?
Its odd that the engine runs fine but the lock nut comes undone on its own!
nightshaddow
PostPosted: 20:29 - 23 Feb 2008    Post subject: Reply with quote
ok firstly these are good genuine brand new tappets from yamaha i have one left after replacing it today,
second i use genuine engine gaskets again ordered from local bike shop
third yes always plenty of oil at the top end (latly i had to check the clearences every few days... these are no standard 8 mm nuts these are 10mm nuts suplyed with the tappets(at my request)
and finally as i stated earlyer in the thread when i have ajusted it up it runs absalutly perfectly for a few hundred miles till the tapping starts again,
i have been working on bikes and cars since i was about 5 with my dad but never have i seen anything like this, i have alot of people stumped with this if i can find a good stockinst i will rip the engine down and replace what needs
PostPosted: 21:38 - 23 Feb 2008    Post subject: Reply with quote
The adjusters shold not wear with normal clearances. The few thou gap isn't enough for the adjuster to gain enough momentum to peen the end over - essentially they are "pressing" on the valve stem rather than "hitting" it. If the adjuster is wearing down there must be another reason for the clearance to increase, and that usually means the cam follower is worn out. This would be evidenced by you having to screw each new adjuster down a little further to attain the proper valve clearance. If this is happening I would check the follower and cam for wear.
If you have used any liquid gasket in any of your rebuilds I would check the oil strainer and ensure that the oil passage to the head is not partially blocked.
nightshaddow
PostPosted: 21:49 - 23 Feb 2008    Post subject: Reply with quote
this machine is coming off the road next week i will recheck the cam and rocker as well as the valves, if i still see no problems i will post more pics see if anyone can decifer the problem...... general intrest could it be down to valve springs no one seemed to mention this yet but i just hitting into space on this one, it been just over 1000 miles since the problem started so maybe the internal problem will be more pronounced
PostPosted: 22:06 - 23 Feb 2008    Post subject: Reply with quote
I was going to suggest checking for a broken spring, but in my opinion it would have dropped the valve by now with that much rattling going on. It doesn't take much to sling the collets out. Good thinking though and it might yet be the cause.
aero
PostPosted: 11:06 - 24 Feb 2008    Post subject: Reply with quote
We replaced several top ends from these engines under warranty from new due to excessive wear on the cams.
Two springs breaking (inner and the outter)? Don't think so. Either will hold the valve tightly closed, you'd get problems as the revs build with one broken spring though.
Trilby
PostPosted: 13:38 - 19 Mar 2008    Post subject: Reply with quote
I think I may the same trouble. My bike has only just done 5000 miles....and I hear this constant tapping noise, but it only seems to happen on tick over. I have set the timing correctly and the tappets but it just seems to revert back to this god awful noise.
TrIbZ
PostPosted: 17:22 - 19 Mar 2008    Post subject: Reply with quote
Sounds more like the exhaust gasket is blowing. Did you fit a new gasket/crush ring when you re-fitted the exhaust?
prawny1
PostPosted: 17:35 - 19 Mar 2008    Post subject: Reply with quote
check the condition of the cam follower shaft and bush, if they are worn it wil lead to noisy top end and difficult to set valve clearence as the follower will be all over the place. anyone with experience of the a-series mini and metro will agree.
smegballs
PostPosted: 15:48 - 21 Mar 2008    Post subject: Reply with quote
on my 1998 SR 125 i have a similar thing going on, after setting the valves it starts tapping after around 200 miles, its only a very quite tap tho and only under load so i havent bothered with it to be honest, generally ive found the engine pretty bulletproof.
nightshaddow
PostPosted: 17:54 - 23 Mar 2008    Post subject: Reply with quote
true the engines are bullet proof but this machine is a backup and reliable as hell wen my other is being serviced or off road for repair,
but it is damaging itself and it is no quiet tap, latest symptom loosing power mid range loads of power and torque low and high but splutters mid range
craigT19
Jolly Green Giant
PostPosted: 12:36 - 24 Mar 2008    Post subject: Reply with quote
get a compressoion check mate, sr's arnt as bullet proof as poeple think... they are terrible for dropping there exhaust valves.. the ones ive seen sound like a bag of spanners but do still run after the piston hits the valve because the gap at tdc is fairly big, the valves get rammed up damaging the collets and some times valve guids but ofter the rocker and cam gets damaged
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
The last post was made 17 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 136.32 Kb
