| nightshaddow |
 nightshaddow Nearly there...
 Posted: 20:12 - 18 Feb 2008 Post subject: yamaha sr125 inlet valve |
hi this is my problem
i have a 1991 yamaha sr 125 and i had some really bad rattleing l8ly, i reset the tappets and it ran smooth for about 250 miles, then it started again, so i looks at the tappet again and the bottom of it was compleatly crushed, i replaced the tappet thinking old bike needs replacing so did the inlet and the exhaust tapets, i have done about 500 mile since then and the inlet tappet has been crushed again, i have ajusted it twice (second this weekend) and a bit worried anyone have any ideas, could it be a dodgy valve or something more serious
cheers ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| Ichy |
 Ichy World Chat Champion
| TUG |
 TUG World Chat Champion
 Posted: 23:24 - 18 Feb 2008 Post subject: |
My god, sounds like you set the gap at the wrong point maybe???
250-500 miles and it died again thats really bad, if its not you setting it wrong then there is something seriously wrong. ____________________ Haz ER-5, innit! |
| aero |
 aero Nova Slayer
| nightshaddow |
 Posted: 17:39 - 19 Feb 2008 Post subject: |
i will take photos of current tappet at the weekend when it's light, i sould explain i am no newbee wen it comes to mechanics i set it right everytime,
engine tdc bothe valves are closed
set inlet to bettween 0.05 - 0.09 mm (as stated in haynes manuel)
set exhaust to between 0.11 - 0.15 (same sorce)
runs beautifully for about 50 -60 miles then you get a slight tap which gets worse till ajusted
i do roughly 25 miles a day and i check most weekends the distance due to the amount of tapping it will incure in a week
camchain is prety clean and at correct tensionand the cam cog is clean with no broken teeth
any ideas ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
| aero |
 aero Nova Slayer
 Posted: 21:24 - 19 Feb 2008 Post subject: |
Taken from a 'tapetty' SR engine where the owner had , surprizingly, been chasing the valve adjustment. It did sound a bit rough as he pulled up.
https://i29.tinypic.com/jv10s0.jpg ____________________ 70's & 80's 4 stoke Yamaha Guru and professional workshop dweller. |
| Billd |
 Billd Nova Slayer
 Posted: 18:27 - 21 Feb 2008 Post subject: |
I had an SR125 in about '88. I know it's a lot older than yours but I corcscrewed several valve stems just from red lining it too much. In fact, I still have a brand new valve somewhere from these days...  |
| nightshaddow |
 Posted: 19:34 - 22 Feb 2008 Post subject: |
there is another symptom.... it my not be related, thought i have a sneaking suspision it is
it has developed over the past few months a backfire, not a miss fire but a true back fire, it doesnt do it on tick over steady revs or high revs but when i throtle of or down shift it dont half pop.... normaly wen the revs get to 3000rpm wen slowing down,,,, any ideas ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
| nightshaddow |
| Pete. |
 Pete. Super Spammer
 Posted: 19:06 - 23 Feb 2008 Post subject: |
Bit of a toughie this one but I would suspect one of two things:
1) Poor oiling at the top-end, causing the follower to wear against the cam until it's got so loose it's hammering the adjuster down. Could be from a clogged strainer or more likely an oil passage up to the head is restricted. Only a strip-down would reveal the fault. The cam is probably scrap.
2.) You've suffered a bit of valve float causing a piston-valve strike and bent the valve a bit. The valve is slightly open causing loss of compression and too small a piston/valve clearance, and the piston is just clipping the valve at revs.
I prefer the 1st option, the 2nd is frankly unlikely on the SR engine. ____________________ a.k.a 'Geri'
| nightshaddow |
| aero |
 aero Nova Slayer
| Pete. |
 Pete. Super Spammer
 Posted: 19:51 - 23 Feb 2008 Post subject: |
When you rebuilt the top-end, did you use any hylomar/instant gasket anywhere? ____________________ a.k.a 'Geri'
| aero |
 aero Nova Slayer
| nightshaddow |
 Posted: 20:29 - 23 Feb 2008 Post subject: |
ok firstly these are good genuine brand new tappets from yamaha i have one left after replacing it today,
second i use genuine engine gaskets again ordered from local bike shop
third yes always plenty of oil at the top end (latly i had to check the clearences every few days... these are no standard 8 mm nuts these are 10mm nuts suplyed with the tappets(at my request)
and finally as i stated earlyer in the thread when i have ajusted it up it runs absalutly perfectly for a few hundred miles till the tapping starts again,
i have been working on bikes and cars since i was about 5 with my dad but never have i seen anything like this, i have alot of people stumped with this if i can find a good stockinst i will rip the engine down and replace what needs ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
| Pete. |
 Pete. Super Spammer
 Posted: 21:38 - 23 Feb 2008 Post subject: |
The adjusters shold not wear with normal clearances. The few thou gap isn't enough for the adjuster to gain enough momentum to peen the end over - essentially they are "pressing" on the valve stem rather than "hitting" it. If the adjuster is wearing down there must be another reason for the clearance to increase, and that usually means the cam follower is worn out. This would be evidenced by you having to screw each new adjuster down a little further to attain the proper valve clearance. If this is happening I would check the follower and cam for wear.
If you have used any liquid gasket in any of your rebuilds I would check the oil strainer and ensure that the oil passage to the head is not partially blocked. ____________________ a.k.a 'Geri'
| nightshaddow |
 Posted: 21:49 - 23 Feb 2008 Post subject: |
this machine is coming off the road next week i will recheck the cam and rocker as well as the valves, if i still see no problems i will post more pics see if anyone can decifer the problem...... general intrest could it be down to valve springs no one seemed to mention this yet but i just hitting into space on this one, it been just over 1000 miles since the problem started so maybe the internal problem will be more pronounced ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
| Pete. |
 Pete. Super Spammer
 Posted: 22:06 - 23 Feb 2008 Post subject: |
I was going to suggest checking for a broken spring, but in my opinion it would have dropped the valve by now with that much rattling going on. It doesn't take much to sling the collets out. Good thinking though and it might yet be the cause. ____________________ a.k.a 'Geri'
| aero |
 aero Nova Slayer
| Trilby |
 Trilby L Plate Warrior
| Pete. |
 Pete. Super Spammer
| prawny1 |
 prawny1 World Chat Champion
| smegballs |
 smegballs World Chat Champion
| nightshaddow |
 Posted: 17:54 - 23 Mar 2008 Post subject: |
true the engines are bullet proof but this machine is a backup and reliable as hell wen my other is being serviced or off road for repair,
but it is damaging itself and it is no quiet tap, latest symptom loosing power mid range loads of power and torque low and high but splutters mid range ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 12:36 - 24 Mar 2008 Post subject: |
get a compressoion check mate, sr's arnt as bullet proof as poeple think... they are terrible for dropping there exhaust valves.. the ones ive seen sound like a bag of spanners but do still run after the piston hits the valve because the gap at tdc is fairly big, the valves get rammed up damaging the collets and some times valve guids but ofter the rocker and cam gets damaged ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
The last post was made 17 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
