| moo1971uk |
 moo1971uk L Plate Warrior
| moo1971uk |
 Posted: 22:09 - 08 Aug 2005 Post subject: |
Thanks for the reply Yokogeri
So full choke is push it fully upwards,
Glad you could tell me the setting for the choke to be off that is what i was really after knowing. as long as i can start it with no problems & it runs fine with NO choke then i feel i dont have to worry.
You have been a help & thanks again |
| moo1971uk |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 23:55 - 08 Aug 2005 Post subject: |
The choke on a CG125 carburettor (and on most carburettors) is a plate which is actuated by a sprung lever, pushed by the hand operated lever, which has three positions.
The plate revolves about a spindle across its face. The plate is normally edge on to the airflow, and as such, presents little obstruction to the flow. As you pull the lever up, the plate turns so that it presents more of its face to the flow, blocking more of the area.
This smaller cross-sectional area makes the air flow faster (in order to fit the same amount of air through a smaller gap it has to flow faster) and so reduces the air pressure. This 'increased vacuum' sucks more fuel through the jets and so makes the engine run richer.
The reason the engine stalls when you put the choke on full is either because the choke plate entirely closes the carburettor body and no air flows, or because there simply isn't enough air to burn enough fuel to keep the engine turning over.
See the attached diagram for a very simplified schematic of a CG carburettor. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| map |
 map Mr Calendar
 Posted: 00:19 - 09 Aug 2005 Post subject: |
CG125 choke was covered in another thread also - click here - for info.
Without seeing it not sure but IMO the hole in the exhaust on the underside is probably a drain for condensation. When you start the bike after a spell stood idle you may notice water droplets from it. The theory is it should help slow down the exhaust corroding from the inside out (but it will eventually anyhow, due to the nature of the gasses acting on the metal - creates an acid).
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| moo1971uk |
 Posted: 16:46 - 09 Aug 2005 Post subject: |
a massive thanks mchaggis that is the information i was after. i appreciate your help & for taking the time to put my mind at rest
cheers mate
same to you mr map
only problem i have now is i bought the bike on saturday & the head is leaking slightly, there is oil underneath & last but not least the freakin fat nut for the forks/ centre nut below speedo as ya look down from above... has come off.... nice lol
bought it from a shop & its going right back to were it came from.
But i do like the cg so i will have another, but probably from somewhere else, i need it like yesterday... freedom to me cos i dont drive a crappy car, nor want too.  |
There is a gap of 2 years, 210 days between these two posts... |
| xTZRx |
 xTZRx Derestricted Danger
 Posted: 22:24 - 06 Mar 2008 Post subject: |
Hi, im new here i have buyed a new CG125 I started it today after 4 days and it was on high revs for some reason i dont understand why, I started it twice and both times it was reving high before i got scared and just turned to key incase the engine blows, is this what "Idle" is called? and can you tell me how long it will be on idle or high rpm. Also the choke was swicthed on first time and the second time i switched it off but same, high rpm both times.
PLZ PLZ help me i've just bought this and its my first bike! ____________________ xCDIx125x
Razz39@hotmail.com |
| tutton |
 tutton World Chat Champion
| xTZRx |
 Posted: 23:11 - 06 Mar 2008 Post subject: |
Yh i went and checked my Bike now and noticed that after i accelerate it doesn't seem to release the throttle so i need to push it to release the throttle, this might have been the problem but im gonna check it out in the morning as i have no college. ____________________ xCDIx125x
| xTZRx |
 Posted: 12:44 - 07 Mar 2008 Post subject: |
I just went out and checked with choke off, but bike was still idling very high sounds like 4500+ RPM, how can i sort this out?
MSN Razz39athotmaildotcom ____________________ xCDIx125x
| tutton |
 Posted: 19:12 - 07 Mar 2008 Post subject: |
Id guess the cg125 is still a carbed bike,
Find your carb, has pipes down from fuel tank, and a air pipe in from the airbox,
and adjust the screw when bike is hot like in the picture below
https://www.teamcalamari.com/pix/24mm/7a.jpg
or its just the screw on your carb on the far left usually. sometimes middle, just count how many times uve wound incase u need to get it back to what it previously was. ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
Current: '02 ZX636 A1P '51 CCM R30 |
| xTZRx |
 Posted: 23:29 - 07 Mar 2008 Post subject: |
THNX alot TUT,
i found the screw but still no luck, i think the cable is sticking, gonna open it tomorrow and check it out.
I was gonna say something but i have forgotten now lol  ____________________ xCDIx125x
| xTZRx |
There is a gap of 2 years, 339 days between these two posts... |
| herbert111 |
 herbert111 L Plate Warrior
There is a gap of 206 days between these two posts... |
| LittleWoman |
 LittleWoman L Plate Warrior
The last post was made 14 years, 191 days ago. Instead of replying here, would creating a new thread be more useful? |
