Honda cg125 choke help plz
moo1971uk
PostPosted: 21:26 - 08 Aug 2005    Post subject: Honda cg125 choke help plz Reply with quote
Hello all, can anyone help me with the choke on a cg125 2002 51plate.
The problem im having is this, there are three settings for the choke, i push the choke upwards as far as it will go ( the engine cut's when ticking over) i put the choke lever down 1 level (middle) the engine is fine ticking over & runs ok, i put choke down to the last setting & it runs exactly the same as middle... doesn`t rev faster or slower between the 2.
why is the engine cutting on the top setting?
& shouldnt there be a tick over variation between settings instead of just 1 cuts engine & other 2 settings run exactly the same??
be grateful for any help people can give, im new to the bike & cant find anything out about the settings, i have tried.
Oh another thing, is there supposed to be a tiny hole in the underside of the exhaust?? its about 1cm maybe .. like a drilled hole perfect drill hole??
thanks
moo1971uk
PostPosted: 22:09 - 08 Aug 2005    Post subject: Reply with quote
Thanks for the reply Yokogeri Smile
So full choke is push it fully upwards,
Glad you could tell me the setting for the choke to be off Smile that is what i was really after knowing. as long as i can start it with no problems & it runs fine with NO choke then i feel i dont have to worry.
You have been a help & thanks again
moo1971uk
PostPosted: 22:38 - 08 Aug 2005    Post subject: Reply with quote
Im saved from the dark choke path lol
I thought the revs would have changed when it was ticking over between the 2 settings that dont cut the bike?
&... why does it cut when i put choke on full?
i thought it would have revd more with choke on or have i got it all wrong??
I need the answers oh wise one for my inquisitive mind lol
But as long as im not running with the choke on, smart mate.
mchaggis
PostPosted: 23:55 - 08 Aug 2005    Post subject: Reply with quote
The choke on a CG125 carburettor (and on most carburettors) is a plate which is actuated by a sprung lever, pushed by the hand operated lever, which has three positions.
The plate revolves about a spindle across its face. The plate is normally edge on to the airflow, and as such, presents little obstruction to the flow. As you pull the lever up, the plate turns so that it presents more of its face to the flow, blocking more of the area.
This smaller cross-sectional area makes the air flow faster (in order to fit the same amount of air through a smaller gap it has to flow faster) and so reduces the air pressure. This 'increased vacuum' sucks more fuel through the jets and so makes the engine run richer.
The reason the engine stalls when you put the choke on full is either because the choke plate entirely closes the carburettor body and no air flows, or because there simply isn't enough air to burn enough fuel to keep the engine turning over.
See the attached diagram for a very simplified schematic of a CG carburettor.
I must not be a troll...
Mmmm, Guinness
map
Mr Calendar
PostPosted: 00:19 - 09 Aug 2005    Post subject: Reply with quote
CG125 choke was covered in another thread also - click here - for info.
Without seeing it not sure but IMO the hole in the exhaust on the underside is probably a drain for condensation. When you start the bike after a spell stood idle you may notice water droplets from it. The theory is it should help slow down the exhaust corroding from the inside out (but it will eventually anyhow, due to the nature of the gasses acting on the metal - creates an acid).
HTH Thumbs Up
moo1971uk
PostPosted: 16:46 - 09 Aug 2005    Post subject: Reply with quote
a massive thanks mchaggis that is the information i was after. i appreciate your help & for taking the time to put my mind at rest
cheers mate Smile
same to you mr map Smile
only problem i have now is i bought the bike on saturday & the head is leaking slightly, there is oil underneath & last but not least the freakin fat nut for the forks/ centre nut below speedo as ya look down from above... has come off.... nice lol
bought it from a shop & its going right back to were it came from.
But i do like the cg so i will have another, but probably from somewhere else, i need it like yesterday... freedom to me cos i dont drive a crappy car, nor want too. Smile
There is a gap of 2 years, 210 days between these two posts...
xTZRx
PostPosted: 22:24 - 06 Mar 2008    Post subject: Reply with quote
Confused Confused Confused Confused Confused Confused Confused Confused
Hi, im new here i have buyed a new CG125 I started it today after 4 days and it was on high revs for some reason i dont understand why, I started it twice and both times it was reving high before i got scared and just turned to key incase the engine blows, is this what "Idle" is called? and can you tell me how long it will be on idle or high rpm. Also the choke was swicthed on first time and the second time i switched it off but same, high rpm both times.
PLZ PLZ help me i've just bought this and its my first bike!
xCDIx125x
Razz39@hotmail.com
tutton
PostPosted: 22:55 - 06 Mar 2008    Post subject: Reply with quote
^ Idle is what the bike ticks over at when no throttle is being subjected.
Maybe your chokes stuck on, as my rpms rise high with choke on,
or maybe just your idle screw is would in too much.
xTZRx
PostPosted: 23:11 - 06 Mar 2008    Post subject: Reply with quote
Yh i went and checked my Bike now and noticed that after i accelerate it doesn't seem to release the throttle so i need to push it to release the throttle, this might have been the problem but im gonna check it out in the morning as i have no college.
xCDIx125x
Razz39@hotmail.com
xTZRx
PostPosted: 12:44 - 07 Mar 2008    Post subject: Reply with quote
I just went out and checked with choke off, but bike was still idling very high sounds like 4500+ RPM, how can i sort this out?
MSN Razz39athotmaildotcom
xCDIx125x
Razz39@hotmail.com
tutton
PostPosted: 19:12 - 07 Mar 2008    Post subject: Reply with quote
Id guess the cg125 is still a carbed bike,
Find your carb, has pipes down from fuel tank, and a air pipe in from the airbox,
and adjust the screw when bike is hot like in the picture below
https://www.teamcalamari.com/pix/24mm/7a.jpg
or its just the screw on your carb on the far left usually. sometimes middle, just count how many times uve wound incase u need to get it back to what it previously was.
xTZRx
PostPosted: 23:29 - 07 Mar 2008    Post subject: Reply with quote
THNX alot TUT,
i found the screw but still no luck, i think the cable is sticking, gonna open it tomorrow and check it out.
I was gonna say something but i have forgotten now lol Confused
xCDIx125x
Razz39@hotmail.com
xTZRx
PostPosted: 22:09 - 09 Mar 2008    Post subject: Reply with quote
xTZRx wrote:
THNX alot TUT,
Update on this screw thing, It's sorted the Idling problem out
THNX for the support
xCDIx125x
Razz39@hotmail.com
There is a gap of 2 years, 339 days between these two posts...
herbert111
PostPosted: 18:17 - 12 Feb 2011    Post subject: Reply with quote
I was riding my cg125 the other day and found whenever I went over about 60 my choke leaver would vibrate itself into the on postions. This caused the fuel to become too rich and leave me at the side of the road for a bit until I sort it out.
I was wondering if anyone else had a similar problem and found a cure for it, or if it is to do with the fact that when I was investiating the leaver at home found that it is sprung into the on position, relying on the friction of the switch next to the bracket to hold it in the off position?
There is a gap of 206 days between these two posts...
LittleWoman
PostPosted: 11:39 - 07 Sep 2011    Post subject: Reply with quote
I have that problem myself, some days baby will start fine others she hates my guts and I nearly give myself a hernia trying to kick start her. Herbert you say you end up at the side of the road, do you mean she cuts out at speed and you have to make an emergency bank over to the side because the engine isn't responding to more throttle.... shes just stopping regardless? If so I think we have the same problem.
First time it happened I thought it was just crap in the fuel line. My choke all the way up will result in a total engine stall. half mast and all the way down and she runs fine, but I wonder if maybe this is affecting her fuel consumption (though she seems to run on happy thoughts and pixie dust regardless).
I am a new rider as of may this year so I've been a touch clueless but I recently got hold of a CG haynes. I've tried several little experiments to keep her going since I've had her:
2nd fuel filter attached,
riding with choke on the half setting (thats fine all the time i the engine is warmed up and i only want to go 40mph or less),
fiddling with the idle screw.
Yet she still has her occasional bad day. so maybe I'm not doing it right or I'm looking to solve the problem on the wrong parts of the engine.
My CG runs a bit rich also, but I wont know wether thats the norm atm or just because I recently ran her dry by accident. (no fuel guage or fuel light or lil window on the tank makes guessing how much you got left a total stab in the dark haha)
I will be keeping an eye on this thread, hopefully we can figure it out together. If I ever find the 100% cure though through my fiddling I will forward it on......
P.s. I dont know if this is of any use to anybody but I found this on my search for an answer: https://hondacg125.awardspace.com/idle_screws.htm
The last post was made 14 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 90.47 Kb
