| Valentino Mossy |
 Valentino Mossy World Chat Champion
| AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
| Valentino Mossy |
| Scotty |
 Scotty Scooter Boi
| Valentino Mossy |
| Scotty |
 Scotty Scooter Boi
 Posted: 16:20 - 15 Feb 2004 Post subject: |
Your top end looks completely shagged in all honesty.
The pitting on the cylinder head is way yo much to get away with.
Same as the piston.
Even with the low quality photos you can see the barrel is also damaged a fair bit.
these prices are for official OE honda parts from
www.davidsilverspares.com
(NS parts seem to cost more than NSR for some reason...)
NS125F/RK : Cylinder barrel and piston .... £99.00
NS125F/RK : Cylinder base gasket .... £2.50
NS125F/RK : Cylinder head gasket .... £10.00
NS125F/RK : Piston ring set .... £22.00
You'd have to send them an email about other such parts like small end bearings, gudgeon pin, and the cylinder head. (shouldn't be any more than £30 as the NSR is only £20) ____________________ Regards
Scott |
| Valentino Mossy |
| Valentino Mossy |
| chunkielad |
 chunkielad Nearly there...
| Scotty |
 Scotty Scooter Boi
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 18:07 - 15 Feb 2004 Post subject: |
hmmm did using cheap 2 stroke oil really save money?? ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| Scotty |
 Scotty Scooter Boi
 Posted: 18:22 - 15 Feb 2004 Post subject: |
What exactly happened to the bike?
Looks like parts of the piston broke up and then bounced round the bore a few thousand times  ____________________ Regards
Scott |
| Robby |
 Robby Dirty Old Man
| Kickstart |
 Kickstart The Oracle
 Posted: 20:09 - 15 Feb 2004 Post subject: |
That piston is scrap. Well, it might make an ash tray.
The head might clean up. For the best performance then you should replace it, but if you clean up all the sharp edges then it should work OK (the sharp bits would get hot and could cause detonation).
The bits of the barrel I can see look like they have bits of piston smeared on them. If that is all the damage then it can be cleaned up. If it is scored then it needs replating (around £100 plus a piston) or replacing (around £100 with a piston, but plus rings).
I would suspect that you have either had a ring snap, or a circlip jump out. Then the remains have bounced around the combustion chamber, getting hammered between the piston and head.
By the way, with the corrosion it looks like there is not enough antifreeze in there. When you rebuild it make sure there is enough in the coolant.
| Valentino Mossy |
 Posted: 21:23 - 15 Feb 2004 Post subject: |
The two stroke oil i was using was a good make i think, i'll try and dig the name out tomorrow.
I was talking to the guy who i bought the bike off today.
I was joking to him about the "dodgy" engine in that bike and how it locked up on me.
He then said that has happened to him before with the bike!
He said it's not cut out for that kind of constant runing and high speeds  ____________________ Ducati 916,white framed corse replica https://www.bikechatforums.com/viewtopic.php?t=239309
https://blauschatfroums.freeforums.net/ |
| Danny |
 Danny Ask Me About Stoppie School
| Ian (GPX) |
 Ian (GPX) Brolly Dolly
| Ian (GPX) |
| Scotty |
 Scotty Scooter Boi
| chunkielad |
 Posted: 00:14 - 16 Feb 2004 Post subject: |
Man - get the lot - all looks great and if it's at the right price
then it's better than trying to fix what you got. ____________________ Mark Harrison R.I.P - 26th March 2003.
Remember you always and will ride in your honour.
Big revvs up for Mark! |
| Valentino Mossy |
| Ian (GPX) |
| Valentino Mossy |
| Ian (GPX) |
| Diehard |
 Diehard Trackday Trickster
 Posted: 23:56 - 17 Feb 2004 Post subject: |
Ah this takes me back, mine over heated and siezed 100yards from home! Welded the barrel to the piston, right carry on to fix it, Barrel, piston, gasgets, clips, rings, head all in excess of £350! Could have cried. I could have had the barrel reboared for £150, wasn't worth it. Bare in mind tho people, when you buy the barrel and piston set from honda, you get no rings with it! they are £30 extra! Real rip off merchants. The little clips for the piston to rod are £20! Wish I knew about this forum back in sept. Could have saved some money! Oh well. ____________________ If I Die... I Die! |
The last post was made 22 years, 181 days ago. Instead of replying here, would creating a new thread be more useful? |
