| dheselwood |
 dheselwood Derestricted Danger
| dheselwood |
| dheselwood |
| stu_m |
 stu_m Crazy Courier
 Posted: 23:35 - 04 May 2008 Post subject: |
its your regulator/rectifier i had the same thing on my 99 model srad
your battery will eventually go flat too
Stu |
| dr_adams |
 dr_adams Borekit Bruiser
| stu_m |
 stu_m Crazy Courier
| dheselwood |
| stu_m |
 stu_m Crazy Courier
 Posted: 17:26 - 05 May 2008 Post subject: |
it regulates the voltage from the genarator to the battery  |
| smeg918 |
 smeg918 Derestricted Danger
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 21:41 - 05 May 2008 Post subject: |
Even though you hear the fuel pump whirring it doesn't mean that it's working properly. You need to check that first. Is the pump inside the tank on the SRAD? I think it is; there's a filter in there too.
The regulator/rectifier doesn't just regulate current it also converts it from AC to DC voltage. You can tell if the reg/rec is working by putting a test meter across your battery terminals. At idle it should read about 12 to 12.5 Volts and when you rev the engine it should increase to a maximum of about 14 volts. If the voltage stays at 12 volts or decreases then you could have a problem with either your alternator, reg/rec or wiring.
 ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| dheselwood |
| dr_adams |
| dheselwood |
| stu_m |
 stu_m Crazy Courier
 Posted: 07:02 - 06 May 2008 Post subject: |
its breaking down as it heats up
hence it only does it when you have been riding for a bit  |
| stu_m |
 stu_m Crazy Courier
| ZaphodBeeble |
| stu_m |
 stu_m Crazy Courier
| dheselwood |
| D O G |
 D O G World Chat Champion
| dheselwood |
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 19:23 - 12 May 2008 Post subject: |
if your fireing on 3 cylinders first thing you need to check is which cylinder is not fireing, many ways you can do this but with out buying special equipment i let the bike idle for a few mins then see how hot the down pipes the cold one is the culpret,
check the plug again and go through all your checks again you might find you missed some thing,
also you might need your carbs setting up could cause it to run rough if they not ballenced it could be something simple like a sticking slide, ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| dheselwood |
The last post was made 17 years, 231 days ago. Instead of replying here, would creating a new thread be more useful? |
