Yamaha DT125R chain that fits??
kyledude125
PostPosted: 17:05 - 07 May 2008    Post subject: Yamaha DT125R chain that fits?? Reply with quote
I have had my Yamaha DT125R 2006 model for about a year and a half. I recently decided to replace the chain and rear sprocket as the chain slipped off and damaged the sprocket.
I Have tried two chains and so far neither of them have fit. I first tried a TKR 428-126 and it was the correct thickness but too short. I then tried a TKR 520-120 Heavy Duty but this one was abit too long and way too thick.
Does anyone please know what chain size i need because i cant find anything anywhere. Would save me forking out another 30quid on a chain that doesnt fit.
kyledude
temporary
PostPosted: 17:44 - 07 May 2008    Post subject: Reply with quote
I used a d.i.d. chain,im sure it was a 428 ?
It was a bit too long,but that's not a problem,you just have to remove a few links...
Any decent motor factor's should be able to tell you which one you need. Thumbs Up
nightshaddow
PostPosted: 19:32 - 07 May 2008    Post subject: Reply with quote
first off it is deffinatly a 428 pitch there are several options depending on year and sprocket size, i normaly buy one far to long then cut it down if required, asuming you got standard sprockets etc you should find the answer in a haynes i will search it out for you though
nightshaddow
PostPosted: 19:36 - 07 May 2008    Post subject: Reply with quote
ok here are the recomendations
428 - 134
428 pitch 134 length
Finglonga
PostPosted: 19:59 - 07 May 2008    Post subject: Reply with quote
You should be changing BOTH sprockets as for a chain to "slip" off it is either not been looked after or already worn to buggery.
Andy Sez....
F.Y.Y.F.F.
The last post was made 18 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 44.42 Kb
