HELP!! NSR screwed yet again
Cwizard
PostPosted: 17:51 - 08 May 2008    Post subject: HELP!! NSR screwed yet again Reply with quote
Just driving home from work, *clunk* Then neutral light comes on, but still driving along Shocked Pulled over, flicked through the gears, found neutral. Then went through, still same, when pulled up at home, theres a rubbing/whirring noise. Typical bike is having its MOT this month, anyone got any ideas??? Sad
Honda NSR 125 R1 (51)
Back and better than ever!!
2006 _p1
PostPosted: 17:56 - 08 May 2008    Post subject: Re: HELP!! NSR screwed yet again Reply with quote
I dont get whats wrong explain in more detain...
Cwizard
PostPosted: 17:59 - 08 May 2008    Post subject: Reply with quote
Was driving down the road from work and a clunk come from the gearbox, then neutral light came on, no matter what gear it stays on and theres a kinda whirring noise coming from the gearbox, wouldnt give a toss usually but needs to pass mot and it wont like that, plus dont want it leading to worse
2006 _p1
PostPosted: 18:04 - 08 May 2008    Post subject: Reply with quote
Have you checked your oil?
Cwizard
PostPosted: 18:06 - 08 May 2008    Post subject: Reply with quote
yeh y would that cause the neutral light to stay on? Eh?
2006 _p1
PostPosted: 18:08 - 08 May 2008    Post subject: Reply with quote
Oh sorry i read it wrong Embarassed sorry carnt help
ZRX61
Victor Meldrew
PostPosted: 18:55 - 08 May 2008    Post subject: Reply with quote
The switch is stuck, just unscrew it from the engine, clean it up & put it back in... or just replace it. cheap as chips.
The switch has a spring & a ballbearing, the shifter drum has a bump on the end that pushes the ball down to make the light come on. I'm guessing it's either stuck down, or mullared. May have a bit of clag stuck in it, or the spring may have broke.
They're usually a 14mm head.
Cwizard
PostPosted: 19:02 - 08 May 2008    Post subject: Reply with quote
had a read about and think it is, any idea where the hell it is? also how hard to remove? Rolling Eyes
nightshaddow
PostPosted: 19:09 - 08 May 2008    Post subject: Reply with quote
it should be just under the sprocket cover and you probably find as zrx61 said it easy you might have cought the wire in the sprocket i known that before
ZRX61
Victor Meldrew
PostPosted: 19:15 - 08 May 2008    Post subject: Reply with quote
It's a piece of piss to remove if you have the right socket.. If I coud lay my hands on one quickly I'd post a pic of it but I'm not sure where they are buried ion my garage..Smile
ZRX61
Victor Meldrew
PostPosted: 19:24 - 08 May 2008    Post subject: Reply with quote
ok, found one. It looks like this:
https://img.photobucket.com/albums/v317/ZRX61/ZRXGarage/NS001.jpg
The wire will go on the pointy end, the other end with the ball goes into the casing. This one has 17mm head
alains
PostPosted: 21:05 - 08 May 2008    Post subject: Reply with quote
yes , spot on (assembly 11) . it's also an auxillary wire comes with it (10) and the washer (22)
Cwizard
PostPosted: 21:47 - 08 May 2008    Post subject: Reply with quote
diamond, hopefully that will sort it, think may have a spare from old engine too. will check tomoz, cheers people
ZRX61
Victor Meldrew
PostPosted: 00:11 - 09 May 2008    Post subject: Reply with quote
Step one:
Take the one out of the old engine & make sure it works. Then you'l have it ready to swap... Wink
The test involves picking it up & giving the ball a squeeze... Shocked
It's not actually a ball, just looks like half of one. Usually copper.
The last post was made 18 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 78.72 Kb
