Two Stroke Oil
Matthie
PostPosted: 21:46 - 10 May 2008    Post subject: Two Stroke Oil Reply with quote
My oil light came on on the way home today but halfords was already shut.
I need to travel about 8miles tomorrow early in the morning.
If i was desperately low on oil, would it wreak the engine if I put a small bit of normal oil in there?
Cheers,
Matt
Ant132
PostPosted: 21:51 - 10 May 2008    Post subject: Reply with quote
Normal oil?
You just need to fill up with 2-stroke oil, personally i wouldnt go anywhere with an oil light on without checking the oil tank first to make sure there was sufficient oil, and even then i would only be travelling to the nearest place that sells oil.
If, by normal oil, you mean mixing two different brands of 2-stroke oil, you will be fine! Im unsure by your post, wether you are getting confused with gearbox oil? Might be just me.. Confused
Ant.
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
Matthie
PostPosted: 22:08 - 10 May 2008    Post subject: Reply with quote
I am leaving so early in the morning that there is going to be no where open selling oil. I have just been to tescos but they are sold out.
I think I should be ok on what I have got as I have kept an eye on the actual oil level in the tank since the light came on earlier.
petemell
PostPosted: 22:46 - 10 May 2008    Post subject: Reply with quote
Not worth the risk running a 2 stroke with no oil, if it runs out the engine will be knackered, it isn't like running out of petrol. The 2t oil lubes the crank and piston on a 2 stroke, I would fill it before taking it out.
Matthie
PostPosted: 07:01 - 11 May 2008    Post subject: Reply with quote
Yeh I know the risk and thats why I have tried my hardest, and now have a lift to where I am going today.
Thanks for the help Thumbs Up
Finglonga
PostPosted: 07:13 - 11 May 2008    Post subject: Reply with quote
You have no petrol stations near you? Confused
Andy Sez....
F.Y.Y.F.F.
MaybeGuy
PostPosted: 23:28 - 12 May 2008    Post subject: Reply with quote
try vegetable oil... its the same consistency as 2 stroke oil (near enough) and if its soon to be topped up with 2 stroke, i doubt it will do much harm.
NSR Mick
PostPosted: 08:59 - 13 May 2008    Post subject: Reply with quote
Are you for real?
May be a little late now but your not going to run out in 8 miles anyhow so just get some when you can.
Quite possible that would cause a major problem. Castor based oils will not mix with mineral oils, and suspect vegitable oils might have the same problem.
That said on most 2 stroke bikes you have a fair distance from the warning light coming on to actually running out of 2 stroke oil. Check the tank.
StealthDJ
PostPosted: 09:11 - 13 May 2008    Post subject: Reply with quote
If I was absolutely desperate, I'd maybe use a non-detergent straight 30 grade oil as a substitute. Given that it's what people used prior to the invention of two stroke specific oil, it'll work. Then again, engines weren't as highly tuned at the time.
Even then, I'd be emptying the oil tank out before putting anything new in afterwards, so if there's still proper two stroke left, use it - just don't let it run out.
(There's no real reason why vegetable oil wouldn't work in a two stroke, but agree with the above - you don't want to be mixing it with mineral oil. If you were pre-mixing, fair enough, but otherwise it's a bad idea)
Current garage: VFR800 FI-W | RD500LC YPVS | SV650 K2 | MZ TS250/1 | MZ ETZ251 | BSA WDB40
Previous notables: H100 S2 | CB250NA/B | CB250T | GT250X7 | Z650 B1 | SR650
Still owned, but long gone: RD250LC | CB750F2 SOHC | C50
The last post was made 17 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 67.14 Kb
