Crankcase bearing removal
2006 _p1
PostPosted: 16:13 - 14 May 2008    Post subject: Crankcase bearing removal Reply with quote
Im trying to take my crankcase bearings out but they don't seem to want to budge.
Ive tryed heating them up but no luck. Its hard to get behind them and knock them out.
Is it best to take it to the shop and get it done?
Or you have any neat tricks to get them out?
Thanks
2006 _p1
PostPosted: 17:11 - 14 May 2008    Post subject: Reply with quote
Anyone?
Jockey
PostPosted: 17:41 - 14 May 2008    Post subject: Reply with quote
Have you any pictures, people need them to evaluate just what you are doing, as it stands it sounds as though you are heating them instead of the surrounding casing, is that correct?-Jockey.
Current bike VFR 400 R NC30, others now gone.
PostPosted: 18:28 - 14 May 2008    Post subject: Reply with quote
what bike, and yes pics would help too Smile
2006 _p1
PostPosted: 19:08 - 14 May 2008    Post subject: Reply with quote
This is it.... i cant get in behind the bearing to give it some welly. I heated the case and the bearing.
https://i77.photobucket.com/albums/j76/pit_bike/Picture004-2.jpg
https://i77.photobucket.com/albums/j76/pit_bike/Picture003-2.jpg
PostPosted: 19:54 - 14 May 2008    Post subject: Reply with quote
No reason why it shouldn't come out. I would make a stepped drift to press it out from outside. If you have a socket that will fit through the hole in the casing and catch on the inner race, you might be able to use that as a drive. Probably will have to sacrifice the seal, better yet remove it first if possible.
2006 _p1
PostPosted: 20:08 - 14 May 2008    Post subject: Reply with quote
The inner race is like inline with the case so i doubt a socket will get on it. I dont mind about the seal really i will take it out tomorrow and see how it goes.
PostPosted: 21:09 - 14 May 2008    Post subject: Reply with quote
You are not using enough heat.
Put the whole thing in the oven and leave it there until it is fearsomely hot.
The bearings will probably fall out by themselves (listen for the clunk from the oven), if they don't, gentle tapping with a drift should persuade them out.
Remember to wear thick leather gloves to handle them. Welding gloves are ideal.
I was doing the reverse of that job this weekend. Cases in the oven, bearings in the freezer. Didn't even need my hammer, they dropped right into place. Note leather gloves, hammer and socket and extension bar "drift" on standby.
https://i48.photobucket.com/albums/f216/stinkwheel/engine3.jpg
EDIT: Remember to remove any circlips. Wink
WildGoose
White Van Man
PostPosted: 22:21 - 14 May 2008    Post subject: Reply with quote
Having had more than enough hassles from blind bearing removal lately, particularly in places where you are forced to work, underside of a van etc.
You cannot beat having the proper tool, ask around or think about renting a blind bearing puller with slide hammer.
2006 _p1
PostPosted: 05:47 - 15 May 2008    Post subject: Reply with quote
Wouldnt all the bearings come out though?...God knows what my mums going to say when i put my engine in the oven haha.
Thanks
PostPosted: 11:23 - 15 May 2008    Post subject: Reply with quote
Thanks
Yes, they might all come out. You can put them back in again though.
Incidentally, I can even see from your photo that if you remove the seal, you'll be able to see both the inner race and the balls. Plenty of room to get a drift on there, as said, a big 1/2" drive socket is usually ideal. And plenty of heat.
Do it when she's out. Really. Clean the oven out afterwards. Mums just don't understand.
2006 _p1
PostPosted: 15:40 - 15 May 2008    Post subject: Reply with quote
Il give it a go now. Shal i sit by the oven untill i hear the pops? Also shal i remove the water pump?
2006 _p1
PostPosted: 15:16 - 16 May 2008    Post subject: Reply with quote
Cheers stinkwheel put em in the oven and they came out really easy. i had to get a bearing of my crank and it was in the oven for like half hour didn't seem to want to budge but got it off.
Thanks again
The last post was made 17 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 75.65 Kb
