"Performance Chip"
Funkmeister_Smith
PostPosted: 16:55 - 21 May 2008    Post subject: "Performance Chip" Reply with quote
Hi.
Just a quick question, has anyone ever tried these "performance chips" being sold on Ebay, claiming to increase BHP, torque, acceleration etc etc, such as the listing below...
[url] https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110254794379&ssPageName=MERCOSI_VI_ROSI_PR4_PCN_BIX_Stores&refitem=110254564865&itemcount=4&refwidgetloc=closed_view_item&refwidgettype=osi_widget&_trksid=p284.m185&_trkparms=algo%3DSI%26its%3DI%252BIA%26itu%3DIA%252BUCI%26otn%3D4%26ps%3D42 [/url]
but wth no adverse effects to your engine? Sounds a bit far fetched to me, surely there has to be some cons to it? Most of the feedback seems to be that it works but Im still dubious. I've just fitted a Scorpion can & K & N filter to my RSVR so it needs re-mapped anyway. I've booked it in to get it done on the 3rd of June, but I guess I was wondering if these done the same sort of thing. Neutral
Yamaha TDR 125 ~ Suzuki RG 125 ~ Aprilia RS 125 ~ Suzuki GSXR 600 K4 ~ 2001 Aprilia RSV 1000R (breaking for parts. Interested??) ~ Dajiang X-Stream X-Dirt 200 (stolen) ~ Suzuki DRZ400E (Stolen) ~ CCM 604E R30....
Damon
PostPosted: 17:04 - 21 May 2008    Post subject: Reply with quote
Im pretty sure they just make the bike run slightly rich. You will be better off with a powercommanded to be honest (If your bike is fuel injected)
ebay con... Rolling Eyes
Steve-D
PostPosted: 17:05 - 21 May 2008    Post subject: Reply with quote
Item location, Hungary.
Nuff said.
www.southwestbikers.com
Funkmeister_Smith
PostPosted: 17:09 - 21 May 2008    Post subject: Reply with quote
My thoughts exactly. Thumbs Up
On the subject of Power Commanders, would having a Power Commander have the same end result as just getting the bike set up properly at a garage (through the ECU etc), or would having a Power Commander give me extra power on top of it just being set up right for the can & filter? Question
tutton
PostPosted: 18:39 - 21 May 2008    Post subject: Reply with quote
They run using sensors,
when we had one for a car,
what it does is tell your airflow sensor
that theres more air going to the engine,
the ecu then riches the mixture by loads to compensate.
More fuel = More power = More money on fuel.
PostPosted: 19:03 - 21 May 2008    Post subject: Reply with quote
That thing will just screw around with the signals from a couple of sensors and richen the mixture. Might give you a tiny bit of power if the bike is running a tad lean. Suspect the only way you could get 25hp would be claiming 0.25hp at 100rpm, 0.25hp at 200rpm, etc, and then adding all those together.
As to a power commander it allows you to screw around with the signals to and from the ecu, giving an effect very close to remapping the ecu. Most ecus cannot easily be remapped properly although some can (such as most Triumph ones).
Ok, a couple of misunderstandings there. First off, you need to set up a power commander at a garage on a dyno. Secondly, the power commander goes in between the ECU, the sensors and the injectors to fool the ECU into thinking it is running normally while telling the injectors to give more fuel. This is done across the rev range, and on a power commander is sampled every 500rpm. On the Sagem fuel injection fitted to most Triumphs (and some Aprilias) the sampling is done every 250rpm, and they can be re-mapped. There is no point buying a power commander if the stock ECU can be remapped, especially if the stock ECU does more samples than a power commander. You'll get a MUCH better result with a re mapped ecu, than you will with one that is being fooled into doing something that it shouldn't.
However, that relies on the fact that your ECU is re mappable at all. If it isn't then a power commander is the best way to go. Either way you'll need some dyno time with a dyno operator that can either use the power commander equipment, or has the right tools for re-mapping your injection (Like the Triumph injection 'gameboy' or aftermarket software such as 'tune boy').
Its not as simple as bolting on a box to make your bike go faster. If it was, everyone would do it. Karma
PostPosted: 21:00 - 21 May 2008    Post subject: Reply with quote
Yeah it just alters the IAT sensor value to add more fuel. Same can be done with the barometric pressure sensor.
Some cheap nitrous kits point the nitrous jet at the IAT sensor to chill it so that the ECU adds fuel in to compensate for the gas. A good way to eventually melt your engine Smile
PostPosted: 06:00 - 22 May 2008    Post subject: Reply with quote
There are a handful of EPROM chips that alter the igition timing, so when used with a power commander would give you more power.
You also have to consider that the map on the EPROM is designed to work with all mille's with various mods, whereas a PCIII is a bespoke solution and gives optimum performance to your bike and your bike alone.
IMO forget the EPROM crap and just PCIII it. I got 119 out of my 02 mille with a PCIII and Aprilia Race can.
krebsy
PostPosted: 08:32 - 22 May 2008    Post subject: Reply with quote
Goat-Boy I think has chipped his car and gotten more go out of it. I've the same engine block (resplendant with new head gasket, turbo, pistons and con-rods after the turbo exploded and trollied the engine) so I was thinking of getting it done. Not cheap though...
I was outside at lunchtime yesterday and two blokes were stood around a black CBR600RR with the seat off and a laptop plugged into the power commander box, adjusting the fueling/timings.. Smile
K.
1280 x 1024.
PostPosted: 09:16 - 22 May 2008    Post subject: Reply with quote
With a turbo car engines there are often easy gains to be had from properly chipping it (ie, upping the boost and fueling).
This plug in thing is akin to replacing a knock sensor with a resistor on a turbo engine to up the boost. Crude and likely to result in engine damage (although with a turbo car the damage would likely be more sudden and spectacular).
PostPosted: 09:59 - 22 May 2008    Post subject: Reply with quote
It really isn't worth "self-adjusting" the PCIII, unless you have a dyno to analyse the exhaust gasses it's rather tricky to get it half decent IMO.
matt_uk
PostPosted: 12:34 - 22 May 2008    Post subject: Reply with quote
If you really wanted to " perfomance chip " your car you can buy them for like 5 quid off ebay if you look, although i personally wouldnt.
- - - BIKE - - - Passed CBT : 21/07/06 - - - Currently : Riding a 2001 Aprilia rs125 (SOLD)
- - - CAR - - - Passed Theory 20/07/06 - - - Lessons, Test on 15th Jan 08... Passed 2 minors
PostPosted: 12:49 - 22 May 2008    Post subject: Reply with quote
Maplins will sell you a "chip" to do the same for nearer 5p. Just a resistor to put into the circuit for the temperature sensor to fool the injection system into a richer mixture. Crude and out of date bodging with the injection.
Ravo
PostPosted: 22:01 - 22 May 2008    Post subject: Reply with quote
The RSVR has more horsepower than a Honda Civic. Why do you need to chip it again? Just wondering...
Tango675
PostPosted: 15:50 - 23 May 2008    Post subject: Reply with quote
Seat Leon TDI 110 with a Revo custom map. Good for +25bhp with no further modifications. Down side is that you do need to keep on top of the servicing and you may loose 10,000 miles of engine life if you live with your foot in the carpet (out of a practical 300K+ life).
Because it was a TDI it was just an ECU update to allow more fuel and boost. (better and safer than any of these cheep plug in units as it does not try and fool the ecu) However the same principles apply to tuning a bike, More air+fuel = more power!!!.
A DynoJet kit (for Carbs) or Power Commander (ECU+Injection) can probibly improve engine responce and remove flatspots (put in for drive by or emissions) but most motorbike engines are fairly well tuned from the factory. For performace gains, you need to consider combining the better air/fuel mix with a freeier flowing exaust and air filter. Some manufacturers (KTM, Triumph) can even supply you with a factory fuel map to go with some approved brands of exaust.
Somebody give that windup merchant a torque wrench..
Doddmaster
PostPosted: 16:24 - 23 May 2008    Post subject: Reply with quote
On the Harley forum I use, there are loads of people with similar set-ups on their V-Rods so a lot of them make their own PCIII maps up and share them
Funkmeister_Smith
PostPosted: 19:54 - 23 May 2008    Post subject: Reply with quote
Thanks for all the replies. Thumbs Up
I defo wont bother with the chip, sounds like it may have more cons than it lets on! Rolling Eyes I suspected as much mind seeing as its only £20 or less.
I'll see what happens after the garage take a look at it & re-map it. They were pretty confident that it'd give me a noticable increase in power (and no flat spots). I'm also going a tooth down on the front sprocket so that should make her a bit nippier too! Mr. Green I'm not particularly fussed about breaking the sound barrier, so I'd rather have better acceleration with a lower top speed. Thumbs Up
Cheers!
The last post was made 17 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.65 - MySQL Queries: 13 - Page Size: 107.45 Kb
