Damn... stupid no good leg....
krebsy
PostPosted: 08:09 - 28 May 2008    Post subject: Damn... stupid no good leg.... Reply with quote
took the VFR out last night with Goat-Boy and after a fun cruise about through the villages, I go to u-Turn, Over goes the VFR, right onto the dodgy leg and down onto the floor.
Evil or Very Mad
Bent the brake lever, bent the brake pedal a bit, snapped the blob off the footrest. bar that, nothing else.
tried to straighten out the lever, ended up snapping the end off...
Evil or Very Mad Evil or Very Mad Evil or Very Mad
oh well, found one on E-Fence for 12 quid. Thumbs Up
She's got her battle scars now.
Gusess I won't be riding again until I get the leg a bit stronger. Sad
K.
1280 x 1024.
LeeR
PostPosted: 09:11 - 28 May 2008    Post subject: Reply with quote
You know when you do those things you think only you could be that stupid/unlucky/careless etc... but fear not, I done it too. Laughing
See I can look back and laugh now; have you done any exercises or phsyio to strengthen your leg?
My claim to fame: Austin Vince nicked my pen...
krebsy
PostPosted: 09:46 - 28 May 2008    Post subject: Reply with quote
4 months worth of physio and excercise. I'm back in the gym and can do resistance weights now, but no idea on what I can lift yet. I've been walking on the leg fine and have just gotten to the stage of being able to walk without any crutches, but take one with me just in case as if I do too much then I need the extra leg.. Smile
Berating myself for being a bit stupid and too eager to get going again. Kudos to Goat-boy, without him Id've not been able to lift the bike.. Smile
K.
1280 x 1024.
Timmeh
PostPosted: 10:43 - 28 May 2008    Post subject: Reply with quote
Just take it easy.
Getting impatient will damage your biking career more in the longterm.
Karma
veeeffarr
PostPosted: 11:25 - 28 May 2008    Post subject: Reply with quote
Sickpup did me a VFR lever for around that price if you'd rather not take your chances on eBay
bigwill
PostPosted: 12:23 - 28 May 2008    Post subject: Reply with quote
sorry to hear about your fall mate. hope you get better mate.
DIdnt think anyone did u turns after passing their test. I hate em. lol
2006 Yamaha FZ1 - the comfy R1
krebsy
PostPosted: 13:08 - 28 May 2008    Post subject: Reply with quote
I'll drop him a line for a pedal then.. Smile
K.
1280 x 1024.
krebsy
PostPosted: 13:09 - 28 May 2008    Post subject: Reply with quote
Smile You've got to do it to prove you still can. Smile
The slow speed control stuff is always where I tend to have the issues, I guess my balance is borked... Sad
K.
1280 x 1024.
MaybeGuy
PostPosted: 21:36 - 29 May 2008    Post subject: Reply with quote
you could try your hand at welding the levers back together?
i did this for my SRAD on the rear brake lever and think i did a pretty awesome job of it.
spot the weld Wink
https://img120.imageshack.us/img120/9777/10052008082km3.jpg
krebsy
PostPosted: 10:01 - 30 May 2008    Post subject: Reply with quote
That's a pretty good job there. Smile
The brake pedal is usable and at £13 for a new lever (waiting for me at the post office) then I'm not in a rush to crack out the welder. The pedal will be £40 to replace so I'll grab one in a week or so if I don't bodge the current one.
Will heating with a blowtorch and hitting with a hammer work on an alloy pedal? Or, I'll support the pedal on a block of wood, heat it and then press it flat again with another wood block to do the job.
K.
1280 x 1024.
MaybeGuy
PostPosted: 16:43 - 30 May 2008    Post subject: Reply with quote
i very much doubt that heating and hitting it will work... give it a go, whats there to lose Very Happy
if you dont want to weld, i suppose as a temporary fix you could drill a hole in either side and splint the lever with thin metal strips and bolts?
Tango675
PostPosted: 20:39 - 30 May 2008    Post subject: Reply with quote
The problem with alloy is, unlike steel it is never as strong when its bent back.
I would just bite the bullet and get the genuine parts (or quality copies) for things like that. At least that way you know its not going to snap off unexpectedly when you stamp on the breaks.
Also, I fell off my mountin bike a few weeks ago and knacked my shoudler so I can' lift heavy weights. soo it was Krebsy and his bad leg and Me and my bad shoulder trying to heave the VFR off the ground. We must have looked a right pair!
Do like the VFR though, even if it is a bit heavy... Smile
Has Mrs K. found out yet? Confused
Somebody give that windup merchant a torque wrench..
There is a gap of 191 days between these two posts...
krebsy
PostPosted: 11:58 - 08 Dec 2008    Post subject: Reply with quote
Of course she hasn't. I want to be able to use the other leg don't I? Smile
K.
1280 x 1024.
baldy
PostPosted: 19:21 - 08 Dec 2008    Post subject: Reply with quote
K.
You can straighten them, but you must anneal it first. if you fut the bent bit over a fag lighter so it gets covered in soot, then put it on the gas ring untill the soot is gone and the lever is really hot and stick it in cold water.(the soot acts like a heat indicator, it s hot enough when the soot has disappeared.) it should bend back easily enough then without breaking. it works, i did one this afternoon.
One day i will rule the world, just not today.
SoND
PostPosted: 02:50 - 09 Dec 2008    Post subject: Reply with quote
the warped one wrote:
Alloy isw much the same as Aluminium, depending on thetype and quality, if you bend it a bit , then heat it, then bend it abit more and heat it again, it should go back.
The purpose of the heating is unlike when steel is heated (it get's hardened) some alloys actualy get softer (annelled)
You can harden and soften steel with heat. Heating it up and quenching it will harden it, letting it cool slowly will anneal it.
"Alloy" isn't just aluminium. An 'alloy' is any metal that is composed of two different metals or a metal and a non-metal e.g Steel is an alloy between Iron and Carbon, Stainless Steel has chromium in it, AlMg wheels etc.
When you hammer or bend aluminium it can 'work harden' depending on what alloy it is, the more you work it, the harder it gets. Heat reduces this effect.
Not neccessarily, heat it before bending it, bend it, let it cool slowly, heat it again, let it cool slowly. If you have the lever off you can chuck it into a bucket of sand and this will help it cool down slower, so long as the sand isn't freezing cold.
spot the weld Wink
I choose to call you a liar.
LeeR
PostPosted: 21:06 - 09 Dec 2008    Post subject: Reply with quote
spot the weld Wink
Though he is (in the nicest possible way) a gob-shite and not that he needs help from anyone in forming a defence, but didn't he post some pictures, ages ago, of how he fixed the snapped pegs?
MaybeGuy
PostPosted: 21:36 - 09 Dec 2008    Post subject: Reply with quote
clearly you cant weld Laughing ill take that as a compliment
you're clearly some kid with a C&G level 2 qualification under your belt and think you're the bees knees about metal treatment Cool
The last post was made 17 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 106.51 Kb
