| krebsy |
 krebsy World Chat Champion
 Posted: 08:09 - 28 May 2008 Post subject: Damn... stupid no good leg.... |
took the VFR out last night with Goat-Boy and after a fun cruise about through the villages, I go to u-Turn, Over goes the VFR, right onto the dodgy leg and down onto the floor.
Bent the brake lever, bent the brake pedal a bit, snapped the blob off the footrest. bar that, nothing else.
tried to straighten out the lever, ended up snapping the end off...
oh well, found one on E-Fence for 12 quid.
She's got her battle scars now.
Gusess I won't be riding again until I get the leg a bit stronger.
K. ____________________ What's my New Year's resolution?
1280 x 1024. |
| LeeR |
 LeeR World Chat Champion
 Posted: 09:11 - 28 May 2008 Post subject: |
You know when you do those things you think only you could be that stupid/unlucky/careless etc... but fear not, I done it too.
See I can look back and laugh now; have you done any exercises or phsyio to strengthen your leg? ____________________ My claim to fame: Austin Vince nicked my pen... |
| krebsy |
 Posted: 09:46 - 28 May 2008 Post subject: |
4 months worth of physio and excercise. I'm back in the gym and can do resistance weights now, but no idea on what I can lift yet. I've been walking on the leg fine and have just gotten to the stage of being able to walk without any crutches, but take one with me just in case as if I do too much then I need the extra leg..
Berating myself for being a bit stupid and too eager to get going again. Kudos to Goat-boy, without him Id've not been able to lift the bike..
1280 x 1024. |
| Timmeh |
 Timmeh World Chat Champion
 Posted: 10:43 - 28 May 2008 Post subject: |
Just take it easy.
Getting impatient will damage your biking career more in the longterm.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| veeeffarr |
 veeeffarr Super Spammer
| bigwill |
 bigwill Trackday Trickster
| krebsy |
| krebsy |
 Posted: 13:09 - 28 May 2008 Post subject: |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 21:36 - 29 May 2008 Post subject: |
you could try your hand at welding the levers back together?
i did this for my SRAD on the rear brake lever and think i did a pretty awesome job of it.
spot the weld
https://img120.imageshack.us/img120/9777/10052008082km3.jpg ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| krebsy |
 Posted: 10:01 - 30 May 2008 Post subject: |
That's a pretty good job there.
The brake pedal is usable and at £13 for a new lever (waiting for me at the post office) then I'm not in a rush to crack out the welder. The pedal will be £40 to replace so I'll grab one in a week or so if I don't bodge the current one.
Will heating with a blowtorch and hitting with a hammer work on an alloy pedal? Or, I'll support the pedal on a block of wood, heat it and then press it flat again with another wood block to do the job.
1280 x 1024. |
| MaybeGuy |
 Posted: 16:43 - 30 May 2008 Post subject: |
i very much doubt that heating and hitting it will work... give it a go, whats there to lose
if you dont want to weld, i suppose as a temporary fix you could drill a hole in either side and splint the lever with thin metal strips and bolts? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Tango675 |
 Tango675 Crazy Courier
 Posted: 20:39 - 30 May 2008 Post subject: |
The problem with alloy is, unlike steel it is never as strong when its bent back.
I would just bite the bullet and get the genuine parts (or quality copies) for things like that. At least that way you know its not going to snap off unexpectedly when you stamp on the breaks.
Also, I fell off my mountin bike a few weeks ago and knacked my shoudler so I can' lift heavy weights. soo it was Krebsy and his bad leg and Me and my bad shoulder trying to heave the VFR off the ground. We must have looked a right pair!
Do like the VFR though, even if it is a bit heavy...
Has Mrs K. found out yet?  ____________________ Somebody give that windup merchant a torque wrench.. |
There is a gap of 191 days between these two posts... |
| krebsy |
| warped one |
 warped one Banned
| baldy |
 baldy World Chat Champion
| SoND |
 SoND World Chat Champion
 Posted: 02:50 - 09 Dec 2008 Post subject: |
| the warped one wrote: | Alloy isw much the same as Aluminium, depending on thetype and quality, if you bend it a bit , then heat it, then bend it abit more and heat it again, it should go back.
The purpose of the heating is unlike when steel is heated (it get's hardened) some alloys actualy get softer (annelled) |
You can harden and soften steel with heat. Heating it up and quenching it will harden it, letting it cool slowly will anneal it.
"Alloy" isn't just aluminium. An 'alloy' is any metal that is composed of two different metals or a metal and a non-metal e.g Steel is an alloy between Iron and Carbon, Stainless Steel has chromium in it, AlMg wheels etc.
When you hammer or bend aluminium it can 'work harden' depending on what alloy it is, the more you work it, the harder it gets. Heat reduces this effect.
| Quote: | The problem with alloy is, unlike steel it is never as strong when its bent back. |
Not neccessarily, heat it before bending it, bend it, let it cool slowly, heat it again, let it cool slowly. If you have the lever off you can chuck it into a bucket of sand and this will help it cool down slower, so long as the sand isn't freezing cold.
I choose to call you a liar. ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| LeeR |
| MaybeGuy |
 Posted: 21:36 - 09 Dec 2008 Post subject: |
The last post was made 17 years, 277 days ago. Instead of replying here, would creating a new thread be more useful? |
