Jolting in 2nd gear
Mellow Matt
PostPosted: 14:24 - 14 Jun 2008    Post subject: Jolting in 2nd gear Reply with quote
My SRAD GSXR 600 is jerking in 2nd gear sometimes Confused If I roll on at low revs (~3k) it sometimes jolts at about 6/7k (I think) for a split second, then carries on accellerating. I'm pretty sure the revs aren't rising in that split second, so I'm thinking it's either fuelling or gearbox? It seems to only happen in 2nd gear though, so probably more likely to be gearbox? That's as far a my mechanical knowledge goes atm (I'm learning!) so what do you guys reckon?
Thanks a lot.
(The bike is new to me btw, so if this is something like damage from clutching up wheelies it's not my fault Sad)
1999 GSX-R 600, 1999 TL1000R
PostPosted: 16:06 - 14 Jun 2008    Post subject: Reply with quote
£10 says it's jumping the gear selector dogs in 2nd.
Mellow Matt
PostPosted: 16:29 - 14 Jun 2008    Post subject: Reply with quote
Thanks, what would that entail in order to fix if that's what's wrong? Lotsa money?
PostPosted: 22:31 - 14 Jun 2008    Post subject: Reply with quote
You'll need to remove the engine. Now depending on whether the cases are splittable without removing the head or not will determine the cost and difficulty of the job. If you can, then you need simply to split the cases, remove the gearbox, replace or repair the knackered gears then re-assemble. Likely to cost ~£200 in parts. If you have to strip the engine totally you'll be looking to add another £100 or so to that for gaskets & sundries, at a guess.
Mellow Matt
PostPosted: 19:23 - 15 Jun 2008    Post subject: Reply with quote
OK, thanks for the info Thumbs Up
Ariel Badger
PostPosted: 20:57 - 15 Jun 2008    Post subject: Reply with quote
Could just be chain or sprokets.
I know it only shows in second gear but that could just be the amount or torque in that gear being ideal to trigger the fault.
PostPosted: 21:47 - 15 Jun 2008    Post subject: Reply with quote
Yes it could be, no advice shoul dbe taken as gospel especially on here as there's first-hand inspection. Very good point.
Gixxers do have a rep for jumping the 2nd gear dogs though.
Andy levitt
PostPosted: 16:52 - 20 Jun 2008    Post subject: Reply with quote
Isnt it r6s that have that problem? Unless it must be both Shocked
Speedfight 50 -> Honda NSR 125 -> Y reg YAMAHA YZF R6 -> 08 YAMAHA YZF R6 -> Honda CBR1000RR
Theory test Done 4/6/07
Practical test Done 21/12/07
PostPosted: 17:40 - 20 Jun 2008    Post subject: Reply with quote
Suzukis suffer it because for some reason they don't under-cut the 2nd gear dog. My own theory is that it's something to do with the wider ratio differential between 1st and 2nd than the other gears but TBH who knows?
The last post was made 17 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 61.82 Kb
