accelerator mechanism
lee8040
PostPosted: 12:55 - 18 Jun 2008    Post subject: accelerator mechanism Reply with quote
who does the accelerator mechanism work, my bandit 600 wont retract back when i turn the accelrator. i fitted a heated grip and it wont retract back when i remove the grip it will retract. sounds like the spring isnt strong enough if thats what it works on, how will i fix this?
T1z3R
PostPosted: 12:58 - 18 Jun 2008    Post subject: Reply with quote
the grips probably rubbing against the switchgear and holding the throttle back. can you move it away from the switchgear? so theres a few mm gap then it wont stick.
duck my sick!
lee8040
PostPosted: 13:01 - 18 Jun 2008    Post subject: Reply with quote
there is already a few mms away from the switch gear
SimonB
PostPosted: 13:03 - 18 Jun 2008    Post subject: Reply with quote
Could possibly be duff throttle cables or perhaps your bar end is making it stick.
Bikes: Honda CBR250RR [sold], Yamaha FZR600 [sold], Honda CBR600RR6
calum17
PostPosted: 17:39 - 18 Jun 2008    Post subject: Reply with quote
check the spacing at the bar end, end. i fitted heated grips on my ZZR and had the same problem, it had to be manually closed, or it would only partially close. i took the bar end off, added a washer then put it back on - just enough space now for everything to work freely.
lee8040
PostPosted: 17:47 - 18 Jun 2008    Post subject: Reply with quote
theres no bar end on it, any other suggestions?
PostPosted: 18:49 - 18 Jun 2008    Post subject: Reply with quote
Check that the heated grips aren't rubbing on the end of the handlebars.
calum17
PostPosted: 18:52 - 18 Jun 2008    Post subject: Reply with quote
also check that the cable going to the heated grips isnt getting caught against anything like your brake lever or frame maybe. i wouldnt have thought it would stop it turning that much but it can make a difference.
just trying to think of what could cause it to not spin freely.
Timmeh
PostPosted: 15:13 - 20 Jun 2008    Post subject: Reply with quote
Take the heated grip off, see if that sorts the problem.
If it doesn't, loosen the cable adjuster at the throttle end and see if that works. An overly-tight cable will stop the return working properly.
If it still doesn't work, then you'll have to take the tank and airbox off and inspect the cables at the carb end. It could be just that the springs are in need of some lubrication, or the cables are rusty.
If the cables are rusty, dismantle the twistgrip and use a pressure applicator to force oil down the sleeves to the other end of the cable.
If it still doesn't work, then you'll have to replace the cables, which will most likely involve you taking the carbs off the engine.
The last post was made 17 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 58.84 Kb
