| lee8040 |
 lee8040 Nearly there...
| T1z3R |
 T1z3R World Chat Champion
| lee8040 |
| SimonB |
 SimonB Brolly Dolly
| calum17 |
 calum17 Brolly Dolly
| lee8040 |
 Posted: 18:49 - 18 Jun 2008 Post subject: |
Check that the heated grips aren't rubbing on the end of the handlebars. ____________________ a.k.a 'Geri'
| calum17 |
| Timmeh |
 Timmeh World Chat Champion
 Posted: 15:13 - 20 Jun 2008 Post subject: |
Take the heated grip off, see if that sorts the problem.
If it doesn't, loosen the cable adjuster at the throttle end and see if that works. An overly-tight cable will stop the return working properly.
If it still doesn't work, then you'll have to take the tank and airbox off and inspect the cables at the carb end. It could be just that the springs are in need of some lubrication, or the cables are rusty.
If the cables are rusty, dismantle the twistgrip and use a pressure applicator to force oil down the sleeves to the other end of the cable.
If it still doesn't work, then you'll have to replace the cables, which will most likely involve you taking the carbs off the engine.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
The last post was made 17 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
