nc 24 problem
traitor
PostPosted: 14:22 - 02 Jul 2008    Post subject: nc 24 problem Reply with quote
hi here the problem
once go over the 80 mark the bike losses power and fades down to nothing and has to be re-started, also is back firing like a cheap suit from next, have checked the plugs and cleaned them and still the same, also new oil on monday as was due, any ideas,
cheers
mike
Timmeh
PostPosted: 15:06 - 02 Jul 2008    Post subject: Reply with quote
I'd say do a compression check and look for air leaks past in the inlet manifolds.
Delvey
PostPosted: 15:40 - 02 Jul 2008    Post subject: Reply with quote
could be that your carbs need cleaning/ re-tuning
these v4 hondas are very fussy when it comes to stuff like that
what colour were your plugs btw?
Frost
PostPosted: 16:21 - 02 Jul 2008    Post subject: Reply with quote
As it's a V4 getting the carbs to sit correctly in the rubbers is a total bastard. If they arnt in perfectly and sealed with the clamps you get air leaks and the bike starts to run on 2 or 3 cylinders and cutting out.
Robby
Dirty Old Man
PostPosted: 11:08 - 03 Jul 2008    Post subject: Reply with quote
I once had an NC24. I have nothing nice to say about them.
There is a significant likelihood that the problem is electrical. The problem being that most of the NC24 electrical system is pretty weak. Reg/recs go, alternators can be quite tired by this age (epoxy insulation may have cracked off, or it could have just burnt out). CDIs are quite tough. Pickup and ignition coils are now past 20 years old, as is the wiring harness. HT leads run in a very confined, very hot space.
Has it started doing it recently, or have you not had the bike for long?
The carbs are total bastards to get seated on the rubbers, and if someone has made a ham fisted approach to getting them back on you may have a split carb rubber.
Mine did the same thing. Never really got it sorted, depsite a lot of time, effort, and money poured into the thing. Don't spend more than the value of the bike (about £200-300) on fixing it, something else will fail soon afterwards.
The last post was made 17 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 42.93 Kb
