Arrgh! Raging!
StevenF
PostPosted: 19:46 - 05 Aug 2008    Post subject: Arrgh! Raging! Reply with quote
Hi,
My battery was flat, so I decided to take out it so I could charge it. After doing that, I thought I may as well check the air filter while the bike isn't going anywhere. So I take the bolt off the tank and try to lift it up, but it's stuck. I go onto https://www.korider.com/ (for the first time) and have a search around, apparently you need to disconnect the fuel lines first.
Sounds easy? Again, apparently they are vacumed, so that when you take it off, no fuel leeks. I take the first line off, fine no problems, I take the next one off and fuel starts spurting out everywhere! I panic, grab a basin near by and try to catch as much as I can. It got so awkward that I had to go in and get some take away dishes which my mum keeps for cooking. In the mean time the fuel is dripping out and all over my bike. I ended up filling around 8 of the containers with fuel!
The garage floor turned in to a pool of fuel and my bike was/is dripping wet.
I put the hose on, trying to get it all out, then grab a brush and fairy liquid to scrub it off. Gave my bike a quick soak as well.
Then a guy from across the road comes over and says: "Have you spilt fuel again?" Again.... again! "Yea I was trying to...." "It's making me sick, again" he said Evil or Very Mad This is the guy who's in his garage 24/7 building his own kitchen, the cheek! As if it's no bad enough that I've got fuel spilt everywhere, he comes over and nags at me - how does that help!
/rant over
I think I'm going to puke Sick
Thom
PostPosted: 19:49 - 05 Aug 2008    Post subject: Reply with quote
What you want is my old nsr i regularly make reference to!
Some arsehole from out the back came round complaining my "lawn mover" was making too much noise and smelt bad, so i revved it up in nutral and smogged him home Laughing
Never seen 1 acre of land covered with so much blue smoke Very Happy
S13JYM
PostPosted: 19:50 - 05 Aug 2008    Post subject: Reply with quote
tell the twat too f**k off nosey c**t and get a pro 2 build his kitchen misreble git Very Happy
StevenF
PostPosted: 19:51 - 05 Aug 2008    Post subject: Reply with quote
Actually my brother has a NSR. He was trying to fix his last week, when the same guy came over complaining about the "Smoke" and smell.
Oz.
PostPosted: 20:24 - 05 Aug 2008    Post subject: Reply with quote
+1
I'd go shit on his lawn as well just to let him no whose boss!
PostPosted: 20:58 - 05 Aug 2008    Post subject: Re: Arrgh! Raging! Reply with quote
Steven001 wrote:
Hi,
Would the best thing have been just to put the fuel line back on rather than filling up all your mums takeaway containers?
What you also could have done is found an off cutting of pipe, taken it from 1 part of the fuel tap to the other, thus no leaks and you can still remove your tank.
PostPosted: 21:01 - 05 Aug 2008    Post subject: Reply with quote
Suspect you had the fuel tap on "prime". Which means fuel flows even when the engine isn't running. On and reserve settings will probably need the engine to be running.
PostPosted: 21:02 - 05 Aug 2008    Post subject: Reply with quote
He said it was a vacuum tap. Surely it wouldn't have a lever then.
PostPosted: 21:06 - 05 Aug 2008    Post subject: Reply with quote
Most fuel taps on larger bikes are vacuum taps. Only real difference is that they normally have "on", "prime" and "res" positions rather than "on", "off" and "res" positions.
Problem on comes if someone switches it to the middle position assuming it is off when in fact it is on all the time.
StevenF
PostPosted: 21:19 - 05 Aug 2008    Post subject: Reply with quote
Oz. wrote:
+1
The next time he's out working in the garage, I should go and ask him to stop because the sawdust is blowing in my eyes... Laughing
Yes that would've been the best thing to do, unfortunately, it wasn't as easy as it sounds. The fuel tank was still attached by another two lines, meaning it would only lift up about 3cms. I couldn't get my hand in to find it and then shove it back in.
Eventually when it had semi drained, I managed to stop the flow because all the fuel was towards the back of the tank. This gave me time to find the line and push it back in.
I had the fuel tap switched to "off", presumed this would stop all fuel coming from the tank. Also I read that the hoses were vacuumed, again, suggesting that no fuel would come through.
Oh well... House smells a little of fuel now and I feel a little sick
Sick Going to sort it all out tomorrow.
PostPosted: 21:30 - 05 Aug 2008    Post subject: Reply with quote
Check it really is "off". With a vacuum tap there is no need for an off position, so often the middle position is a prime setting (to allow fuel to flow when the engine isn't running, so filling the carbs if the carbs have been drained without having to crank the engine for ages).
StevenF
PostPosted: 21:33 - 05 Aug 2008    Post subject: Reply with quote
It was the guys on the forum that insisted the lines were vacuumed Crying or Very sad But obviously not. While the fuel was pouring out, I started to change the fuel tap, moving it every way possible, but it wouldn't stop.
Anyway, I wouldn't dare go into the garage just yet, that would involve putting the light on and possibly blowing the house up Shocked
PostPosted: 21:37 - 05 Aug 2008    Post subject: Reply with quote
I should have never challenged you great one *bowes*
PostPosted: 21:40 - 05 Aug 2008    Post subject: Reply with quote
If there is a line from one of the inlets to the fuel tap then it is almost certainly a vacuum tap.
Entirely possible that the diaphragm in the tap is stuck so cannot cut off the fuel supply. To be honest it is worth sorting out. As it currently stands should one of the needle valves in the carb get stuck then the engine is quite likely to fill with most of the contents of the petrol tank while parked. Few years back I left the Bandit on prime by mistake and lost about 14L of petrol into the engine and airbox over night Embarassed .
StevenF
PostPosted: 21:47 - 05 Aug 2008    Post subject: Reply with quote
Shocked
I hope that doesn't happen with me.. Actually, it won't, there's hardly any fuel left in the tank now Embarassed Anyway, I just put the line that I pulled out back in, so all should be fine.
What was the result of all that fuel leaking into the engine and airbox? Was it repairable?
PostPosted: 21:50 - 05 Aug 2008    Post subject: Reply with quote
It was fine, just had to drain all the oil (rather more came out than usual......). Even the airbox was half full of petrol.
StevenF
PostPosted: 21:52 - 05 Aug 2008    Post subject: Reply with quote
That sounds like a right mess, glad you got it all sorted!
Cheers for all the info, Keith. I'll keep you updated.
Moonie
PostPosted: 22:21 - 05 Aug 2008    Post subject: Reply with quote
Errm, did you not think to just shove a screwdriver in the line?
Phil_G
PostPosted: 22:49 - 05 Aug 2008    Post subject: Reply with quote
Small screwdriver Wink
1997 Kawasaki ER 500 A1:- Once again, Its merely crap Smile
PostPosted: 22:59 - 05 Aug 2008    Post subject: Reply with quote
Just read that again. Am I right in thinking that there are 4 pipes to the fuel tap? If so sounds like a remotely mounted tap. Guess 2 pipes from the tank to the tap (one for fuel on, one for reserver), one vacuum pipe from the intake to the tap and one petrol pipe from the tap to the carbs? If so I suspect you disconnected one of the pipes from the tank to the tap.
StevenF
PostPosted: 23:06 - 05 Aug 2008    Post subject: Reply with quote
I have no idea. There were 3 - I think - pipes connected to the fuel tank. As far as I was aware, I had to remove all three in order to get the tank off. I removed one, no problems, then I removed another one and fuel starting coming out like an elephant pissing.
Moonie
PostPosted: 23:29 - 05 Aug 2008    Post subject: Reply with quote
That would be the tank that would only lift up 3cm, not the pipe Wink
StevenF
PostPosted: 23:52 - 05 Aug 2008    Post subject: Reply with quote
Yea, that's what I was meaning... Smile
The last post was made 18 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 133.83 Kb
