| StevenF |
 StevenF World Chat Champion
 Posted: 19:46 - 05 Aug 2008 Post subject: Arrgh! Raging! |
Hi,
My battery was flat, so I decided to take out it so I could charge it. After doing that, I thought I may as well check the air filter while the bike isn't going anywhere. So I take the bolt off the tank and try to lift it up, but it's stuck. I go onto https://www.korider.com/ (for the first time) and have a search around, apparently you need to disconnect the fuel lines first.
Sounds easy? Again, apparently they are vacumed, so that when you take it off, no fuel leeks. I take the first line off, fine no problems, I take the next one off and fuel starts spurting out everywhere! I panic, grab a basin near by and try to catch as much as I can. It got so awkward that I had to go in and get some take away dishes which my mum keeps for cooking. In the mean time the fuel is dripping out and all over my bike. I ended up filling around 8 of the containers with fuel!
The garage floor turned in to a pool of fuel and my bike was/is dripping wet.
I put the hose on, trying to get it all out, then grab a brush and fairy liquid to scrub it off. Gave my bike a quick soak as well.
Then a guy from across the road comes over and says: "Have you spilt fuel again?" Again.... again! "Yea I was trying to...." "It's making me sick, again" he said This is the guy who's in his garage 24/7 building his own kitchen, the cheek! As if it's no bad enough that I've got fuel spilt everywhere, he comes over and nags at me - how does that help!
/rant over
I think I'm going to puke  ____________________ My Project - Honda CBR 600 F2/FM |
| Thom |
 Thom World Chat Champion
 Posted: 19:49 - 05 Aug 2008 Post subject: |
What you want is my old nsr i regularly make reference to!
Some arsehole from out the back came round complaining my "lawn mover" was making too much noise and smelt bad, so i revved it up in nutral and smogged him home
Never seen 1 acre of land covered with so much blue smoke  ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
Previous Bikes: 1990 Honda NSR125 'Rothmans' (The smoking one), 1990 Suzuki GS500e 'Caf? fighter' (The loud one), 1987 Kawasaki GPX400r (The quick one), 1997 XJ600s Diversion (The reliable one), 2000 Kawasaki ER-5 (The spontaneously combustive one) |
| S13JYM |
 S13JYM Scooby Slapper
 Posted: 19:50 - 05 Aug 2008 Post subject: |
tell the twat too f**k off nosey c**t and get a pro 2 build his kitchen misreble git  |
| StevenF |
| Oz. |
 Oz. Spanner Monkey
| ms51ves3 |
 ms51ves3 Super Spammer
 Posted: 20:58 - 05 Aug 2008 Post subject: Re: Arrgh! Raging! |
| Steven001 wrote: | Hi,
I put the hose on, trying to get it all out, then grab a brush and fairy liquid to scrub it off. Gave my bike a quick soak as well. |
Would the best thing have been just to put the fuel line back on rather than filling up all your mums takeaway containers?
What you also could have done is found an off cutting of pipe, taken it from 1 part of the fuel tap to the other, thus no leaks and you can still remove your tank. |
| ms51ves3 |
| StevenF |
 Posted: 21:19 - 05 Aug 2008 Post subject: |
| Oz. wrote: | | jimbo07 wrote: | tell the twat too f**k off nosey c**t and get a pro 2 build his kitchen misreble git  |
+1
I'd go shit on his lawn as well just to let him no whose boss! |
The next time he's out working in the garage, I should go and ask him to stop because the sawdust is blowing in my eyes...
| ms51ves3 wrote: | Would the best thing have been just to put the fuel line back on rather than filling up all your mums takeaway containers?
Yes that would've been the best thing to do, unfortunately, it wasn't as easy as it sounds. The fuel tank was still attached by another two lines, meaning it would only lift up about 3cms. I couldn't get my hand in to find it and then shove it back in.
Eventually when it had semi drained, I managed to stop the flow because all the fuel was towards the back of the tank. This gave me time to find the line and push it back in.
| Kickstart wrote: | Suspect you had the fuel tap on "prime". Which means fuel flows even when the engine isn't running. On and reserve settings will probably need the engine to be running. |
I had the fuel tap switched to "off", presumed this would stop all fuel coming from the tank. Also I read that the hoses were vacuumed, again, suggesting that no fuel would come through.
Oh well... House smells a little of fuel now and I feel a little sick
Going to sort it all out tomorrow. ____________________ My Project - Honda CBR 600 F2/FM |
| StevenF |
 Posted: 21:33 - 05 Aug 2008 Post subject: |
| Kickstart wrote: | | Steven001 wrote: | I had the fuel tap switched to "off", presumed this would stop all fuel coming from the tank. Also I read that the hoses were vacuumed, again, suggesting that no fuel would come through. |
Check it really is "off". With a vacuum tap there is no need for an off position, so often the middle position is a prime setting (to allow fuel to flow when the engine isn't running, so filling the carbs if the carbs have been drained without having to crank the engine for ages).
Keith |
It was the guys on the forum that insisted the lines were vacuumed But obviously not. While the fuel was pouring out, I started to change the fuel tap, moving it every way possible, but it wouldn't stop.
Anyway, I wouldn't dare go into the garage just yet, that would involve putting the light on and possibly blowing the house up  ____________________ My Project - Honda CBR 600 F2/FM |
| ms51ves3 |
 Posted: 21:40 - 05 Aug 2008 Post subject: |
If there is a line from one of the inlets to the fuel tap then it is almost certainly a vacuum tap.
Entirely possible that the diaphragm in the tap is stuck so cannot cut off the fuel supply. To be honest it is worth sorting out. As it currently stands should one of the needle valves in the carb get stuck then the engine is quite likely to fill with most of the contents of the petrol tank while parked. Few years back I left the Bandit on prime by mistake and lost about 14L of petrol into the engine and airbox over night .
| StevenF |
 Posted: 21:47 - 05 Aug 2008 Post subject: |
| Kickstart wrote: | Hi
Keith |
I hope that doesn't happen with me.. Actually, it won't, there's hardly any fuel left in the tank now Anyway, I just put the line that I pulled out back in, so all should be fine.
What was the result of all that fuel leaking into the engine and airbox? Was it repairable? ____________________ My Project - Honda CBR 600 F2/FM |
| StevenF |
| Moonie |
 Moonie World Chat Champion
 Posted: 22:21 - 05 Aug 2008 Post subject: |
Errm, did you not think to just shove a screwdriver in the line? ____________________ Don't practice it until you get it right, practice it until you don't get it wrong.
Presenting the one and only Chinkmobile  |
| Phil_G |
 Phil_G Traffic Copper
 Posted: 22:59 - 05 Aug 2008 Post subject: |
Just read that again. Am I right in thinking that there are 4 pipes to the fuel tap? If so sounds like a remotely mounted tap. Guess 2 pipes from the tank to the tap (one for fuel on, one for reserver), one vacuum pipe from the intake to the tap and one petrol pipe from the tap to the carbs? If so I suspect you disconnected one of the pipes from the tank to the tap.
| StevenF |
| Moonie |
| StevenF |
The last post was made 18 years, 51 days ago. Instead of replying here, would creating a new thread be more useful? |
