help:bike runs for 2 minutes and then the engine just stops!
zxcvbnm
PostPosted: 23:13 - 05 Aug 2008    Post subject: help:bike runs for 2 minutes and then the engine just stops! Reply with quote
i recently had a problem with my 2000 honda xr100. the bike does not start in less i jump start it, and when it starts it only runs for a about 2 minutes at idle. and about 20 seconds seconds when in 5th gear. the bike ran fine before once i just shut it off and now it has this problem. i had this problem once before but i turned up the idle srew and it was fine then. i took the drain screw of and turned the gas on and it came out fine. also i have oil on the pplug and blue smoke but that was there a while so its probly just the rings or something. so can someone please telll me why its only runing this long!
ride it like you stole it!
Cptn. Awesome
PostPosted: 11:21 - 06 Aug 2008    Post subject: Reply with quote
Sounds like fuel starvation mate. I had a similiar problem with my Viffer. What I'd done was replace the pipes from the fuel tap with new pipes (stiff with being new). And I'd cut them slightly longer so the one pipe that I hadn't replaced was kinked.
this all mean that I could bump the bike and it'd start and run for a bit but I'd be riding along and come to stop at a roundabout or junction and it would cut out regardless of whether the clutch was in or out.
Basically the engine will be able to pull the fuel through a kinked pipe (because of vacuum created by engine) but when you slow down or whatever the vacuum lessens and the pipe closes up.
Dunno if any of that helps but its worth checking.
Rides - '60 Plate Ford Fiesta Zetec 1.25, '03 Plate Kawasaki ZX6R B1H and an '87 VFR400 NC24
Naughty Fawbish: "An eagle is but an eagle until the suns flare blinds his prey." - Fawbish, 2010.
zxcvbnm
PostPosted: 19:39 - 06 Aug 2008    Post subject: bike Reply with quote
i am not sure this is any thing with the pipes becouse like i said when i take the drain screw off it comes out fine. my pipe also has a gas filter on it. ill check with what u said tho. any more suggestens??
baldy
PostPosted: 19:47 - 06 Aug 2008    Post subject: Reply with quote
If the plug is oily and there is blue smoke then that is bad.
You say it like the rings are a part that you dont need. If the rings are worn that bad, it will run like a dog if at all.
One day i will rule the world, just not today.
zxcvbnm
PostPosted: 23:43 - 06 Aug 2008    Post subject: bike Reply with quote
i no the rings are bad and it will wreck the egine if i leave it to long. but it cost me alot to replae the rings and if there is something else wroung that might be really bad then i might not want to keep the bike. im going to replace the rings my self for the firist time so if any one has any tips on doing it and and what kind of tools i need to bye it would be nice to tell me. if i did not already tell u my bike is a 2000 honda xr100, SOHC, single cilender. four stoke. and its an off road bike that i bought for only 200. u plrobly see me on this site alot but becouse my bike is not to great. also im only 14 years old. any how these are the tools i think i need to replace the rings: shop manual for my bike, feeler gage for the valves (which i think i need) do i need to take the valves train apart? maybe some thing to put the rings on?. maybe a flex hone. and do you think i need a new pistin to or just rings? and any more toools do u think i need? any how back to the egine running for only 2 mins. it seems it only runs like 10 seconds now. and any more suggetens on the bike running for only 1o seconds? sorrry i wrote so long.
baldy
PostPosted: 13:33 - 07 Aug 2008    Post subject: Reply with quote
Just buy a honda cg haynes book, it's pretty much the same engine. or even better, try and get one for that bike. If you've never done this before, it is a must. When you start you should give the engine a good clean first, it stops bits getting into the engine. Don't forget to drain the oil first.
The tools you will need are;
a decent socket set,
a pair of snipe nose pliers,
possibly a cross head screwdriver.
You will also need a top end gasket kit, piston and rings, pin and circlips. DO NOT use the old circlips on the new piston, it could destroy your engine if they get deformed when you remove them.
Like i say, the haynes book will explain it better.
hope this helps. Thumbs Up
zxcvbnm
PostPosted: 19:29 - 07 Aug 2008    Post subject: bike Reply with quote
ok thanks, so u meen the hanynes manual is better then the 2000 honda xr100 shop manual? were would i get a haynesss manual? and i am going to buy some carb cleaner u think that will help with my other problem with it not gettin enogh gas? and dont i have to bore or over size it when i replce the rings and pisten?? and im gessing i should buy a new pisten to right? thanks please replay back peaples thanks
baldy
PostPosted: 13:45 - 08 Aug 2008    Post subject: Reply with quote
If you take the barrel to a bike shop, they should advise you if you need a oversize piston or not.
cleaning the carb may help, but if its burning as muck oil as you say it is, it wont help as oil will make it bog down and clog up.
The haynes manual goes into a lot more detail than a owners manual. Plus there is propper pictures not just a bit of a diagram.
norton
PostPosted: 21:07 - 08 Aug 2008    Post subject: Reply with quote
check the tank vent, a small motor wont drag through much fuel and it could take that long to cause a vacuum in the tank
do you get a hissing sound if the filler is opened after it cuts out?
zxcvbnm
PostPosted: 23:52 - 08 Aug 2008    Post subject: bike Reply with quote
ill check with the hissing sound. but i could not find a hanyes manal for my exsct bike. some 1 menchend about bying a hanyes honda cg manual but will it say all the specs for it like what are the valve clearcceses for my 2000 honda xr100? and i was going to bye a shop or service manual not the owners manaul. and also i live vvey outof he way to go to any shop. couldent i just bye a flex hone or some thing? thanks and maybe im just not lokking the right place for the hayness mauaual, do u think i could bye 1 at honda or not. please repla yback anyone
zxcvbnm
PostPosted: 20:29 - 09 Aug 2008    Post subject: bike Reply with quote
SO any one GOT ANY MORE SUGGTIONS??
The last post was made 18 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 71.47 Kb
