| zxcvbnm |
 zxcvbnm Renault 5 Driver
| Cptn. Awesome |
 Cptn. Awesome Crazy Courier
| zxcvbnm |
| baldy |
 baldy World Chat Champion
| zxcvbnm |
| baldy |
 Posted: 13:33 - 07 Aug 2008 Post subject: |
Just buy a honda cg haynes book, it's pretty much the same engine. or even better, try and get one for that bike. If you've never done this before, it is a must. When you start you should give the engine a good clean first, it stops bits getting into the engine. Don't forget to drain the oil first.
The tools you will need are;
a decent socket set,
a pair of snipe nose pliers,
possibly a cross head screwdriver.
You will also need a top end gasket kit, piston and rings, pin and circlips. DO NOT use the old circlips on the new piston, it could destroy your engine if they get deformed when you remove them.
Like i say, the haynes book will explain it better.
hope this helps.  ____________________ One day i will rule the world, just not today. |
| zxcvbnm |
| baldy |
| norton |
 norton Derestricted Danger
| zxcvbnm |
| zxcvbnm |
The last post was made 18 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
