Oil light wont go out...
superstacker
PostPosted: 20:19 - 06 Aug 2008    Post subject: Oil light wont go out... Reply with quote
Hi guys,
Bike is a ZX6-R J1 (2000)
Just changed the oil and filter, and now the oil light wont go out...
Ive checked and checked and checked the level on the flat, run the engine up and then let it cool down...taken it for a short ride around camp... and still it wont go out..
If the level is correct what am i missing?
Finglonga
PostPosted: 20:30 - 06 Aug 2008    Post subject: Reply with quote
Its not oil level its oil pressure. Check the oil pressure sender as it may be faulty, that's the usual cause. DON'T ride it until you have found the cause though as if its the oil pump you will damage the engine.
Andy Sez....
F.Y.Y.F.F.
SpeedfightBoi
PostPosted: 20:44 - 06 Aug 2008    Post subject: Reply with quote
Top her up with oil mate Wink
superstacker
PostPosted: 20:59 - 06 Aug 2008    Post subject: Reply with quote
Thanks for the quick replies guys...it just seems weird something would have failed at the same time i did the oil change?
Gazdaman
I did a trackday!!!
PostPosted: 21:07 - 06 Aug 2008    Post subject: Reply with quote
Did you do up the filter properly? And is the level definitely correct?
And yes, it could be the sender, but as said before. Don't ride it until you find the problem!
Gaz
superstacker
PostPosted: 21:13 - 06 Aug 2008    Post subject: Reply with quote
I did up the filter as tight as possible by hand...this was with locked arms with all my weight on it, so it is tight...the level has been checked by two people on the flat and its just below the full mark in the window...
Im downloading a manual now but i dont know how i could tell if the sender is fooked? or indeed where it is?
Gazdaman
I did a trackday!!!
PostPosted: 21:14 - 06 Aug 2008    Post subject: Reply with quote
The manual holds the key to that one.
Gaz
superstacker
PostPosted: 21:16 - 06 Aug 2008    Post subject: Reply with quote
welll its 15 mins of download away...
Charlie
PostPosted: 22:28 - 06 Aug 2008    Post subject: Reply with quote
Something similar happened to my Dad's transalp. He got it checked by the garage and they decided it was a fault sensor. Fingers crossed eh!
ZRX61
Victor Meldrew
PostPosted: 23:22 - 06 Aug 2008    Post subject: Reply with quote
STOP!!
I can't believe no one on here knows about this, it's a common glitch.
When you change the oil on the zZX6's you need to leave the filter just a tad loose & crank the engine until oil spurts out, then screw the filter on tight.
Altho now that you have ridden it around with no oil pressure you've probably fucked the crank/rod bearings.
This problem has been common knowledge for AT LEAST EIGHT FUCKING YEARS Rolling Eyes
MaybeGuy
PostPosted: 00:16 - 07 Aug 2008    Post subject: Reply with quote
oil pressure switch?
ZRX61
Victor Meldrew
PostPosted: 00:25 - 07 Aug 2008    Post subject: Reply with quote
What part of my previous post are you having difficulty understanding? Rolling Eyes
superstacker
PostPosted: 05:46 - 07 Aug 2008    Post subject: Reply with quote
ZRX61 wrote:
STOP!!
Thanks very much..im on it this morning! I'll let you know how it goes, but Karma given anyway Wink
Ghost
PostPosted: 07:52 - 07 Aug 2008    Post subject: Reply with quote
I have heard that you need to fill the filter with oil before screwing it on or as mentioned crank it over at slow speed till its full then check the level again, not sure if this applies to all ZXRs but I did this on my 400 just in case.
Hope you work it out.
superstacker
PostPosted: 11:41 - 07 Aug 2008    Post subject: Reply with quote
Sorted now guys thanks!
Finglonga
PostPosted: 11:48 - 07 Aug 2008    Post subject: Reply with quote
What was the problem then?
Andy Sez....
F.Y.Y.F.F.
PostPosted: 06:47 - 08 Aug 2008    Post subject: Reply with quote
I was under the impression it's good practice to do this with all bikes? At least I always have......
Barry_M2
PostPosted: 08:40 - 08 Aug 2008    Post subject: Reply with quote
I've never ever heard of this in my 16 years of working on engines. I've never done this and never had a problem. Filling the oil filter with oil will do nothing at all. It will however cause a bit of a mess when you come to screw it in place when all the oil spills out, as the majority of filters screw in side on.
The filters will fill with oil when you put the oil in the normal way. If you want to check this, put oil in without the filter on and watch it all spill out again!! Laughing
After replacing the filter and oil, turn the engine over without letting it fire (remove the plug caps) until the oil light goes out.
Job done. Thumbs Up
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
Rockhopper
PostPosted: 19:35 - 08 Aug 2008    Post subject: Reply with quote
I've heard of this problem with some kawasakis as well and i've never even owned one.
Finglonga
PostPosted: 19:53 - 08 Aug 2008    Post subject: Reply with quote
I have never done it either, the only oil that touches the filter when its being fitted is on the rubber O ring to make it easier to remove next time its changed.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 20:37 - 08 Aug 2008    Post subject: Reply with quote
ZRX61 is right you have to prime the system like he says. If the bike has had any load put on it whatsoever though (like riding it around camp), you're looking at bearing damage.
Finglonga
PostPosted: 21:52 - 08 Aug 2008    Post subject: Reply with quote
You don't have to, just run the engine until the oil pressure light goes out. Been doing it for 20 years without any engine troubles. Wink
Andy Sez....
F.Y.Y.F.F.
PostPosted: 22:02 - 08 Aug 2008    Post subject: Reply with quote
It's a problem particular to the model. Oil pressure switches usually activate at around 10psi, so if he's ridden the bike with the light on it's likely there wasn't enough pressure to prevent bearing contact.
cal91
PostPosted: 01:04 - 09 Aug 2008    Post subject: Reply with quote
Tut Tut hope you havent done too much damage Thumbs Up
my oil light is always on lmao and my temp light. It comes on after been ridden for 10mins. They both flicker with my indicators as well lol its wierd.
But no actuall problems lol
We are the Patriots! Love your country.
The last post was made 18 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 125.96 Kb
