tuning an rxs 100 help needed???????
inov8
PostPosted: 16:10 - 15 Aug 2008    Post subject: tuning an rxs 100 help needed??????? Reply with quote
Hi have an rxs 100 and want to do the look of it up.
Ive attached a pic of what i want to do to it.
Can any one reccomend a belly pan that would fit nicely with some modifications.
also reccomendations on a front and back mudguard, rear shocks & exhaust and help would be much appreciated Wink
bladerunner
PostPosted: 17:23 - 15 Aug 2008    Post subject: Reply with quote
The little RXS is quite tunable as it has the same reed block and transfers as an rd 125 lc. I'd be tempted to fit a micron or big one pipe on it and jet it you should get an extra 10mph out of it and a bit nippier getting there..as for the styling..erm thats up to you Shocked Shocked
Rockhopper
PostPosted: 05:54 - 16 Aug 2008    Post subject: Reply with quote
I think you've got the pictures the wrong way around, the first bike looks loads better!
virus
PostPosted: 09:40 - 16 Aug 2008    Post subject: Reply with quote
Id much rather ride the second one, looks like a good bit of fun offroad.
Anyway back to the point, a universal MX front mudguard will fit, you just need to make a compression fitting to hold it into the bottom of the steering stem. basically, from the bottom up: bolt, mudguard, suitably sized pipe, nut. Tighten that up and the pipe will get compressed and expand sideways, this should lock it into the steering stem, also make use of any tapped holes on the bottom of the yoke to add other mount points though, you dont want that coming out any time soon.
rear shocks, just buy some stiffer longer ones with the same fitting, 14 inchers would suit.
rd125lc belly pan should fit on nicely with a bit of bracketing.
And heres a tip from ben over in america on how to make expansion chambers for 2ts.
For two-stroke riders looking for a cheap, power-producing alternative to aftermarket expansion chambers, try the following: find the point on your existing pipe(s) where the diameter becomes largest (usually a foot or so from the downstream end of the headpipe) and cut it (them) there. Then braze the end (converging) cone and stinger from a junk dirtbike expansion chamber to it. You're usually dealing with a large enough and cool enough pipe that braze will be plenty strong, if you do it right. Try to find dirt bike pipes off a model with a similar displacement to each cylinder of your bike. I had some success doing this to an old GT380 triple and a friend's GT185 twin years ago. I used two RM125 pipes and one that was probably off a YZ125 for the 380. I used all of the YZ pipe except the headpipe, in fact, because the middle cylinder of a 380 splits into two exhausts...all I could use of it was the headpipe. The YZ pipe tucked right around the rear wheel with a little cutting and brazing, and that thing would do easy second-gear wheelies afterwards, even with no rejetting. The 185 gained more top-end but lost a lot of low-end, and ended up holing a piston. Multicylinder two-strokes sound incredible with unmuffled expansion chambers. This approach saves a lot of involved mathematics and should work on most restrictive old two-stroke exhausts, at least with some rejetting, but be advised that you'll trash your original pipes doing it. Might want to try it on a spare set of pipes first, and if you run it lean and hole a piston or two, blame yourself for not jetting it right and not doing enough math--like I did. Good luck.
By the way, I take no responsibility if you fuck up your bike by not making the expansion chamber right.
Oh and get over to www.ratbike.org and have a look in the readers rides section for more ideas.
John
own: 81 xs1100g...
inov8
PostPosted: 10:06 - 16 Aug 2008    Post subject: Reply with quote
thanks for that info, very much appreciated Very Happy
inov8
PostPosted: 10:19 - 16 Aug 2008    Post subject: Reply with quote
BLUEX5 wrote:
Port it, do the squish, use a choke side carb off a 31K model RD350YPVS and fit a Micron pipe. Remove the end can and chop it down, also shorten the baffle to suit. Junk the airbox but do not fit a K&N, run an open carb or bellmouth. Remove the oilpump and run on a high quality 30:1 premix.
The above is what my mate did to an RXS and it went like stink. He was planning a 125 conversion untill it got nicked.
before i start modifying the engine, by making these changes, what's the chances of it blowing the engine up lol ??
inov8
PostPosted: 10:32 - 16 Aug 2008    Post subject: Reply with quote
Is it possible to fit electic start to this?
inov8
PostPosted: 10:40 - 16 Aug 2008    Post subject: Reply with quote
has any 1 got any ideas for a rear mudgurad that would fit on nicely Wink
virus
PostPosted: 11:18 - 16 Aug 2008    Post subject: Reply with quote
Dont bother fitting a new rear mudguard, just trim the old one down with an angle grinder, cut off any unimportant bits, like the plastic below the numberplate etc.
John
own: 81 xs1100g...
inov8
PostPosted: 11:20 - 16 Aug 2008    Post subject: Reply with quote
just had a quick mess about merging the bikes to get an idea what it would look like with a standard exhaust
out come Laughing
inov8
PostPosted: 11:38 - 16 Aug 2008    Post subject: Reply with quote
what do you reckon a kx60 mudgaurd would look and fit like? any one
bladerunner
PostPosted: 12:05 - 16 Aug 2008    Post subject: Reply with quote
I'd say the pipe is the first thing you want to change as it will be the bit that gives the best performance gain!! Fitting a front mudguard like that will just give you a face full of water every time it rains but hey I guess it's your bike so your choice!!
If you want silly power then BDKracing do a 190cc big bore for them with a matching pipe....as well as a tuned pipe for the std 100cc top end..but it wont be cheap but hey scaring them aprillia 125's and cagiva mitos on an RXS100 has always got to be a giggle!!
inov8
PostPosted: 12:53 - 16 Aug 2008    Post subject: Reply with quote
I want to concentrate more on the looks of the motorbike at the moment, is that the website for bdk mate,
https://www.bdkraceeng.co.uk/
couldn't find anything bout that on there, am guesing have to contact the about is.
cheers josh
inov8
PostPosted: 17:05 - 16 Aug 2008    Post subject: Reply with quote
another cool rxs100 done up Wink
bladerunner
PostPosted: 17:08 - 16 Aug 2008    Post subject: Reply with quote
yes mate thats the bdk website alright! I see they still have a contact sam button but he left bdk last month when offered a job by Honda. not much they dont know about making bikes go faster!!
inov8
PostPosted: 17:40 - 16 Aug 2008    Post subject: Reply with quote
Can anyone reccomend any where to get a pair of 14inch shocks with same fitting, can't find any on ebay. thanks in advance
bladerunner
PostPosted: 18:04 - 16 Aug 2008    Post subject: Reply with quote
as a matter of interest have you measured the length of your standard shocks first?Tthat is hole center to hole center by the was. Also you'll want to match the spring rates for the size bike. No point putting shocks on with springs for a 750 four on the little RXS
virus
PostPosted: 18:29 - 16 Aug 2008    Post subject: Reply with quote
Get a set of shocks from a MZ250, they have 2 settings, are 14 inches, and cheap, perfect for jacking up little bikes.
John
own: 81 xs1100g...
inov8
PostPosted: 18:31 - 16 Aug 2008    Post subject: Reply with quote
Not had chance t measure them yet, as its at my mates garage being rebored at the moment, Hopefully should be done on monday for me to pick up, Il measure them then. I just want larger shocks to jack the bikes back end up (for looks) Wink
inov8
PostPosted: 18:34 - 16 Aug 2008    Post subject: Reply with quote
John
cheers will have a scan for them, your help has been greatly appreciated.
thinking of chopping both the original mudguards down smaller (like the bike in the las pic i posted)
will get pics up of when the bikes done Very Happy
inov8
PostPosted: 18:37 - 16 Aug 2008    Post subject: Reply with quote
I dont want to paint the tank and side panels as there in excellent condition. I've been trying to think of a colour to paint the mudguards and bellypan, so far i think white will go with it, any one else have a better sugestion, can't wait to get this done, hopefully found an rd125lc belly pan Wink Very Happy
inov8
PostPosted: 18:45 - 16 Aug 2008    Post subject: Reply with quote
John
had a scan on google, ebay - no luck in finding them Sad
The last post was made 17 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 127.79 Kb
