| inov8 |
 inov8 Two Stroke Sniffer
 Posted: 16:10 - 15 Aug 2008 Post subject: tuning an rxs 100 help needed??????? |
Hi have an rxs 100 and want to do the look of it up.
Ive attached a pic of what i want to do to it.
Can any one reccomend a belly pan that would fit nicely with some modifications.
also reccomendations on a front and back mudguard, rear shocks & exhaust and help would be much appreciated  |
| bladerunner |
 bladerunner World Chat Champion
 Posted: 17:23 - 15 Aug 2008 Post subject: |
The little RXS is quite tunable as it has the same reed block and transfers as an rd 125 lc. I'd be tempted to fit a micron or big one pipe on it and jet it you should get an extra 10mph out of it and a bit nippier getting there..as for the styling..erm thats up to you  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| Rockhopper |
 Rockhopper Trackday Trickster
| virus |
 virus World Chat Champion
 Posted: 09:40 - 16 Aug 2008 Post subject: |
Id much rather ride the second one, looks like a good bit of fun offroad.
Anyway back to the point, a universal MX front mudguard will fit, you just need to make a compression fitting to hold it into the bottom of the steering stem. basically, from the bottom up: bolt, mudguard, suitably sized pipe, nut. Tighten that up and the pipe will get compressed and expand sideways, this should lock it into the steering stem, also make use of any tapped holes on the bottom of the yoke to add other mount points though, you dont want that coming out any time soon.
rear shocks, just buy some stiffer longer ones with the same fitting, 14 inchers would suit.
rd125lc belly pan should fit on nicely with a bit of bracketing.
And heres a tip from ben over in america on how to make expansion chambers for 2ts.
| Quote: | For two-stroke riders looking for a cheap, power-producing alternative to aftermarket expansion chambers, try the following: find the point on your existing pipe(s) where the diameter becomes largest (usually a foot or so from the downstream end of the headpipe) and cut it (them) there. Then braze the end (converging) cone and stinger from a junk dirtbike expansion chamber to it. You're usually dealing with a large enough and cool enough pipe that braze will be plenty strong, if you do it right. Try to find dirt bike pipes off a model with a similar displacement to each cylinder of your bike. I had some success doing this to an old GT380 triple and a friend's GT185 twin years ago. I used two RM125 pipes and one that was probably off a YZ125 for the 380. I used all of the YZ pipe except the headpipe, in fact, because the middle cylinder of a 380 splits into two exhausts...all I could use of it was the headpipe. The YZ pipe tucked right around the rear wheel with a little cutting and brazing, and that thing would do easy second-gear wheelies afterwards, even with no rejetting. The 185 gained more top-end but lost a lot of low-end, and ended up holing a piston. Multicylinder two-strokes sound incredible with unmuffled expansion chambers. This approach saves a lot of involved mathematics and should work on most restrictive old two-stroke exhausts, at least with some rejetting, but be advised that you'll trash your original pipes doing it. Might want to try it on a spare set of pipes first, and if you run it lean and hole a piston or two, blame yourself for not jetting it right and not doing enough math--like I did. Good luck. |
By the way, I take no responsibility if you fuck up your bike by not making the expansion chamber right.
Oh and get over to www.ratbike.org and have a look in the readers rides section for more ideas.
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| inov8 |
 Posted: 10:06 - 16 Aug 2008 Post subject: |
thanks for that info, very much appreciated  |
| Blau Zedong |
 Blau Zedong Banned
| inov8 |
| inov8 |
| inov8 |
 Posted: 10:40 - 16 Aug 2008 Post subject: |
has any 1 got any ideas for a rear mudgurad that would fit on nicely  |
| virus |
 Posted: 11:18 - 16 Aug 2008 Post subject: |
Dont bother fitting a new rear mudguard, just trim the old one down with an angle grinder, cut off any unimportant bits, like the plastic below the numberplate etc.
| inov8 |
 Posted: 11:20 - 16 Aug 2008 Post subject: |
just had a quick mess about merging the bikes to get an idea what it would look like with a standard exhaust
out come  |
| inov8 |
| bladerunner |
| inov8 |
 Posted: 12:53 - 16 Aug 2008 Post subject: |
I want to concentrate more on the looks of the motorbike at the moment, is that the website for bdk mate,
https://www.bdkraceeng.co.uk/
couldn't find anything bout that on there, am guesing have to contact the about is.
cheers josh |
| Blau Zedong |
 Blau Zedong Banned
| inov8 |
 Posted: 17:05 - 16 Aug 2008 Post subject: |
another cool rxs100 done up  |
| bladerunner |
| inov8 |
| bladerunner |
| virus |
 Posted: 18:29 - 16 Aug 2008 Post subject: |
Get a set of shocks from a MZ250, they have 2 settings, are 14 inches, and cheap, perfect for jacking up little bikes.
| inov8 |
 Posted: 18:31 - 16 Aug 2008 Post subject: |
Not had chance t measure them yet, as its at my mates garage being rebored at the moment, Hopefully should be done on monday for me to pick up, Il measure them then. I just want larger shocks to jack the bikes back end up (for looks)  |
| inov8 |
| inov8 |
 Posted: 18:37 - 16 Aug 2008 Post subject: |
I dont want to paint the tank and side panels as there in excellent condition. I've been trying to think of a colour to paint the mudguards and bellypan, so far i think white will go with it, any one else have a better sugestion, can't wait to get this done, hopefully found an rd125lc belly pan  |
| inov8 |
| Blau Zedong |
 Blau Zedong Banned
The last post was made 17 years, 238 days ago. Instead of replying here, would creating a new thread be more useful? |
