clutch cable fitting???
texas peat
PostPosted: 15:35 - 18 Sep 2008    Post subject: clutch cable fitting??? Reply with quote
ive just put new clutch plates and springs on my bike but now im trying to refit the cable when i locate the cable end into the clutch release arm at the engine end theres not enough free cable at the other end to attach it to the handlebar end adjuster. have i done something wrong or is it the wrong cable that was on.
andi
PostPosted: 15:49 - 18 Sep 2008    Post subject: Reply with quote
Is it a pushrob/cam type or direct?
Before: Suzuki GT 185. Honda Superdream 250. Yamaha RD350LC. Suziki RG250. Yamaha FZS600. Honda CBR600F3
Now: Honda Fireblade 929
texas peat
PostPosted: 15:54 - 18 Sep 2008    Post subject: Reply with quote
sorry...forgot to say its an aprilia rs 125 2001. havent got a clue what 'type' it is mate to be honest. i just cant figure out why i aint got enough free cable to attach it to the handlebar lever.
stirlinggaz
PostPosted: 15:56 - 18 Sep 2008    Post subject: Reply with quote
Hi,
if you have fitted it correctly onto the little cam type thing, at clutch end,have you routed the cable correctly?
how much is it short by?
& where did you get the cable from & are you sure its the correct one?
most people seem to have bother getting it fitted at the engine end, lol
have you measured it against the old one?
cheers,
GAZ
EDIT - are you re-using the old cable? if so, you have definately fitted something wrong as the old cable will be stretched.
andi
PostPosted: 15:58 - 18 Sep 2008    Post subject: Reply with quote
If its direct then there should be a barrel adjustor near where the cable clips into the engine end.
Does the clutch cable attach to the same side as the clutch?
andi
PostPosted: 16:06 - 18 Sep 2008    Post subject: Reply with quote
OK googling reveals that an RS125 has a barrel adjustor on the engine end. Loosen this a bit until the cable can go back into the lever without undue effort. 2-4 mm play is what your after.
stirlinggaz
PostPosted: 16:13 - 18 Sep 2008    Post subject: Reply with quote
hi,
clutch cable goes into a hole in engine casing,
access to it is through a pull off plastic gearbox oil filler cap, slightly lower down from were cable enters.
it then hooks onto the cam.
sounds like the cable is incorrectly routed.
cheers,
GAZ.
stirlinggaz
PostPosted: 16:19 - 18 Sep 2008    Post subject: Reply with quote
hi,
youve lost me there?
barrel adjuster is on clutch lever at handle bar.
cable adjustment, at engine end is via " aprilia clutch adjustment tool" or using a socket (11 or 12mm iirc) held by molegrips, to hold/loosen lock nut & screwdriver, through centre of socket to loosen/tighten screw.
cheers,
GAZ
texas peat
PostPosted: 16:43 - 18 Sep 2008    Post subject: Reply with quote
when i took the cable off the handlebar adjuster was all the way in so there was no freeplay at all. i had to take the clutch cover off to free it that way. would that suggest the previous fitter has fitted it the same way. its about 5-10mm short of being able to attach to the handlebars. as far as i can see its in place ok at the engine end...(not many places it can go really) and the cables sliding freely in its outer sleeve,just dont seem to be enough of it??????????????????????
texas peat
PostPosted: 16:44 - 18 Sep 2008    Post subject: Reply with quote
ive just ordered a new clutch cable to see if that will fix it...hopefully whoever has had it before has done a d.i.y. job on it and the new one should be ok....fingers crossed!
texas peat
PostPosted: 16:48 - 18 Sep 2008    Post subject: Reply with quote
and while were on it...whats the correct adjustment for the clutch? the manual says screw the screw all the way in then back half a turn then lock the lock nut...is that right?
andi
PostPosted: 16:59 - 18 Sep 2008    Post subject: Reply with quote
OK its a pushrod type. Do that adjustment first and then see if the cable will fit.
stirlinggaz
PostPosted: 17:09 - 18 Sep 2008    Post subject: Reply with quote
hi,
the cable is a bit tricky to hook on & off through that wee hole, but taking the casing off is just plain cheating, lol.
nothing snagging on the cable, making it too short?
have you tried fitting it backwards?
loosen clutch lever assembly off & move a few mm towards centre of top yoke, then hook cable onto clutch lever, screw adjuster barrel all the way in, route cable straight down making sure its not snagged on anything, & then try & hook the other end onto the cam/plate thingie(while thats slackenned off a bit)?
are we talking really sort or just a few mm?
probably better off with a new cable anyway, perhaps the wrong cable was fitted, putting too much strain on the clutch release cam/puller?
as far as your manual goes, that sounds about right for adjusting a brand new cable,
but expect it to stretch a bit, especially in first few weeks, then your as well adjusting it the same way, rather than using the barrel adjuster on bar, as this doesnt give much adjustment & it does stretch a fair bit, then it settles down .
mind & leave a wee bit of free play at lever.
good luck!
cheers,
GAZ
texas peat
PostPosted: 18:24 - 18 Sep 2008    Post subject: Reply with quote
BINGO! done it.
released the adjuster screw right out and gave the clutch arm a push with my finger while i just about managed to get the cable into the handlebar adjuster with the extra bit of free cable i gained.
thanks for all the help fella's. no doubt i'll be bothering you all again soon!!! Very Happy
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
stirlinggaz
PostPosted: 19:16 - 18 Sep 2008    Post subject: Reply with quote
texas peat wrote:
BINGO! done it.
hi,
NICE ONE!
knew it had to be something simple!
usually is on these bikes, just takes ages to find out & then you need impossibly small hands & fingers to get into the area that needs attention!
cheers,
GAZ
The last post was made 18 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 88.42 Kb
