| texas peat |
 texas peat Borekit Bruiser
| andi |
 andi Crazy Courier
| texas peat |
| stirlinggaz |
| andi |
 andi Crazy Courier
| andi |
 andi Crazy Courier
| stirlinggaz |
| stirlinggaz |
| texas peat |
| texas peat |
| texas peat |
| andi |
 andi Crazy Courier
| stirlinggaz |
 Posted: 17:09 - 18 Sep 2008 Post subject: |
| texas peat wrote: | and while were on it...whats the correct adjustment for the clutch? the manual says screw the screw all the way in then back half a turn then lock the lock nut...is that right? |
hi,
the cable is a bit tricky to hook on & off through that wee hole, but taking the casing off is just plain cheating, lol.
nothing snagging on the cable, making it too short?
have you tried fitting it backwards?
loosen clutch lever assembly off & move a few mm towards centre of top yoke, then hook cable onto clutch lever, screw adjuster barrel all the way in, route cable straight down making sure its not snagged on anything, & then try & hook the other end onto the cam/plate thingie(while thats slackenned off a bit)?
are we talking really sort or just a few mm?
probably better off with a new cable anyway, perhaps the wrong cable was fitted, putting too much strain on the clutch release cam/puller?
as far as your manual goes, that sounds about right for adjusting a brand new cable,
but expect it to stretch a bit, especially in first few weeks, then your as well adjusting it the same way, rather than using the barrel adjuster on bar, as this doesnt give much adjustment & it does stretch a fair bit, then it settles down .
mind & leave a wee bit of free play at lever.
good luck!
cheers,
GAZ |
| texas peat |
 Posted: 18:24 - 18 Sep 2008 Post subject: |
BINGO! done it.
released the adjuster screw right out and gave the clutch arm a push with my finger while i just about managed to get the cable into the handlebar adjuster with the extra bit of free cable i gained.
thanks for all the help fella's. no doubt i'll be bothering you all again soon!!!
 ____________________ \||/
| stirlinggaz |
 Posted: 19:16 - 18 Sep 2008 Post subject: |
hi,
NICE ONE!
knew it had to be something simple!
usually is on these bikes, just takes ages to find out & then you need impossibly small hands & fingers to get into the area that needs attention!
cheers,
GAZ |
The last post was made 18 years, 19 days ago. Instead of replying here, would creating a new thread be more useful? |
