drz 400 restricter please.
dudeskin
PostPosted: 12:48 - 30 Sep 2008    Post subject: drz 400 restricter please. Reply with quote
hi guys, im looking at buying a drz400 with SM wheels, im on my restricted licence. does anyone have the washer lying around?
il buy it off someone no problem.
or does anyone know the dimensions of it so i can get one made up?
any help would be great, as i wont buy the bike if i can't sort something.
cheers,
dudeskin
live hard, die young, leave a damn good looking corpse.
PostPosted: 13:31 - 30 Sep 2008    Post subject: Reply with quote
buy the bike if you want it... According to a US website I've just read, they measured it at 34.2 horses. It would be a very arsey copper who quibbled over 1bhp, especially when most Dynos have a tolerance of a few bhp!
An intake restrictor for one would be a stupid O ring with such a large hole that it is more like a circlip!
If I were you, I'd buy it and then put a cable tie around the throttle stop so you can't open the throttle those last couple of MM, and then it should make less than 33bhp... Smile
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Greenychris
PostPosted: 14:36 - 30 Sep 2008    Post subject: Reply with quote
You shouldn't post the same thread in two different sections.
Confused me for a few seconds Confused
Bike: Honda CB 400. Car: Pug 306 HDI.
'Car is for traveling somewhere in particular because you have to, Bike is for traveling nowhere in particular because you want to.' -skluff
RGE, Ride in peace.
dudeskin
PostPosted: 14:57 - 30 Sep 2008    Post subject: Reply with quote
i thought so myself, but a bit of confusion keeps your mind going Laughing .
i knew it wasnt much more power, and i thought it might have lost that little bit over 33bhp over a few years.
i think ill go or it, and just ride it, its not like i've ever been stopped on the hornet (that i restricted myself).
cheers,
dudeskin
PostPosted: 15:40 - 30 Sep 2008    Post subject: Re: drz 400 restricter please. Reply with quote
Is it the E or SM model you are looking at?
The E has a little more power, but the SM should be very close to 33hp if not on 33hp or below. I'd get it to a dyno first.
ben_wheely
PostPosted: 17:30 - 30 Sep 2008    Post subject: Reply with quote
Im sure i heard my S version was just over, like 35-36 bhp
Surely then the SM is too ?
PostPosted: 19:12 - 30 Sep 2008    Post subject: Reply with quote
The S and SM should make the same power. May be just over, but should be close - will depend on the dyno and many other factors.
PostPosted: 19:39 - 30 Sep 2008    Post subject: Reply with quote
There is a difference between crank power and rear wheel power. I suspect that the police would go with a dyno reading which is at the wheel.
Charlie
PostPosted: 20:11 - 30 Sep 2008    Post subject: Reply with quote
Run it on a dyno, £25 could save you £200 for a F1 international restriction kit.
nick606
PostPosted: 20:50 - 30 Sep 2008    Post subject: Reply with quote
Im just wondering what everyone though of the S model or any really. Just in general, power delivery, acceleration etc etc i think you get the point. I had a go of one which was down geared and it was completely not what i was expecting Neutral
JBurrows88
PostPosted: 09:46 - 01 Oct 2008    Post subject: Reply with quote
They are alot of fun. I miss mine! They have loads of acceration and will cruise at 65/70. I changed the oil and filter every 1000miles. ( it only takes 1.7l so its not exactly costly) Very Happy
My mate and i went to Ireland last week and did 1000 miles and he was on a drz. So if anyone tells you that 'you cant'. They are a silly tit! Laughing In fact it was more comfy than my XJR (but i think thats because my seats lost its surport and my legs are a little to long for the bike!)
The drz puts out 35/36! They are just above the limit. Look on ebay. they're are always on for like 20quid, and they are not exactly hard to put in!
Dave
XJR400 Kenney Roberts Paint Job
PostPosted: 10:02 - 01 Oct 2008    Post subject: Reply with quote
Depends what you're expecting, I guess.
It was about what I was expecting I found my DRZ-E engined CCM quite fun because it was low powered and really needed to be worked to keep at a semi-reasonable pace. They are neither light nor fast for what they are, but are an ok compromise of weight, power and reliability for back-roads and greenlining.
ben_wheely
PostPosted: 10:42 - 01 Oct 2008    Post subject: Reply with quote
Whats greenlining Laughing
What power does the E model put out ? Ive just found out my S engine has been maintained so badly (from previous owners), someone has bodged the cam chain which overtime has broke the valves/seals, and there is a blockage in the water and now the piston and barrel has overheated and is just nackered. On ebay there is a whole E model engine going pretty cheap, so maybe get that one fitted in.
PostPosted: 10:47 - 01 Oct 2008    Post subject: Reply with quote
The uses a different carb I think, but shouldn't be too hard to do the swap.
The only makes a few more horsepower than the S - maybe 37/38.
ben_wheely
PostPosted: 10:49 - 01 Oct 2008    Post subject: Reply with quote
Yea different carb and cams i believe. If i change the engine to an E, but dont fit the bigger carb on it would this cause problems ?
ben_wheely
PostPosted: 11:21 - 01 Oct 2008    Post subject: Reply with quote
Anyone ? I dont want to start a new post
PostPosted: 11:26 - 01 Oct 2008    Post subject: Reply with quote
Calm down... expecting a reply in under 30 minutes might be pushing it a bit Smile.
I expect you could get the old carb to work ok with the new engine, but you'd have to get it setup right (never a bad thing whatever).
ben_wheely
PostPosted: 11:30 - 01 Oct 2008    Post subject: Reply with quote
Ok thanks. True about the waiting, it was only because i saw everyone replying to the 3 topics about 'what motocross bike', so i knew you were all about still.
The last post was made 17 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Offroad & Supermoto All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 96.89 Kb
