| Dragonfly |
 Dragonfly Super Spammer
| Nufkamp |
 Nufkamp Traffic Copper
 Posted: 16:01 - 06 Oct 2008 Post subject: |
Had the same issue with my daughter's lappy, same make and model. On her's it was a dry joint where the dc input is soldered to the board. ____________________ As seen on Google Street View https://tinyurl.com/yfdvojc |
| Dragonfly |
 Posted: 16:08 - 06 Oct 2008 Post subject: |
I was thinking that as I had an old keyboard that needed soldering around the output point. I dont want to send it away on the garentee as they take ages! plus I dont want people poking through my lap top. Was hoping it was the charger there and i know it will only get worse to the piont where I dont beable to switch it on anymore. |
| Dragonfly |
| Nufkamp |
 Posted: 16:23 - 06 Oct 2008 Post subject: |
Depends how steady your hand is with a small tip soldering iron mate, I got one of the electrical engineers at work to pull it apart and fix it. ____________________ As seen on Google Street View https://tinyurl.com/yfdvojc |
| Dragonfly |
| panrider_uk |
 panrider_uk World Chat Champion
| Nufkamp |
 Posted: 05:46 - 07 Oct 2008 Post subject: |
Thinking about it you should be able to meter across trhe contacts of the charger socket with a Fluke meter, if it comes up as open circuit then its the socket. If there's continuity then it's most likely the charger. ____________________ As seen on Google Street View https://tinyurl.com/yfdvojc |
| Dragonfly |
| panrider_uk |
| Nufkamp |
 Posted: 15:33 - 07 Oct 2008 Post subject: |
Use a multimeter and see if there's a resistance (ohms) between the contacts on the charger socket. If the meter shows ohms (continuity) then this means the circuit is intact. No ohms (open circuit) basically means a wire is off between the socket and the mobo. These sockets really are too fragile, my daughter's one has been fixed twice. ____________________ As seen on Google Street View https://tinyurl.com/yfdvojc |
| Dragonfly |
 Posted: 13:26 - 08 Oct 2008 Post subject: |
Took it to the place that takes care of acer warrentys and they tried it and it was the charger and gave me a new one under warrently! Happy days! I thought I was going to be without it for a while and actually cried tears at the thought of this But I got it back today new charger and its working great  |
| rc211v |
 rc211v Nitrous Nuisance
| Nufkamp |
 Posted: 14:06 - 08 Oct 2008 Post subject: |
Good man, all's well that ends well.  ____________________ As seen on Google Street View https://tinyurl.com/yfdvojc |
| Dragonfly |
The last post was made 17 years, 336 days ago. Instead of replying here, would creating a new thread be more useful? |
