Charger or lap top?
Dragonfly
PostPosted: 15:53 - 06 Oct 2008    Post subject: Charger or lap top? Reply with quote
I dont know which it is but its annoying me. My charger dosnt seem to want to work half the time and when it charges the lap top it just stops working and before you kow it the battery is dead and you have to insert it in and mess with it a bit before it workd again.
I am hopeing its the lead as that only costs £25 all together and i dont have to send it away for fixing as its the only computer i have at the min.
Its an acer aspire by the way. Charger or something inside lap top?The red light is still on and the plus symbol is shown its plugged in but if I move it about or look in a fwe mins the plug symbol will not be there and I will be getting warnings of a low battery
Nufkamp
PostPosted: 16:01 - 06 Oct 2008    Post subject: Reply with quote
Had the same issue with my daughter's lappy, same make and model. On her's it was a dry joint where the dc input is soldered to the board.
As seen on Google Street View https://tinyurl.com/yfdvojc
Dragonfly
PostPosted: 16:08 - 06 Oct 2008    Post subject: Reply with quote
I was thinking that as I had an old keyboard that needed soldering around the output point. I dont want to send it away on the garentee as they take ages! plus I dont want people poking through my lap top. Was hoping it was the charger there Crying or Very sad and i know it will only get worse to the piont where I dont beable to switch it on anymore.
Dragonfly
PostPosted: 16:09 - 06 Oct 2008    Post subject: Reply with quote
is it an exspert job then? Crying or Very sad
Nufkamp
PostPosted: 16:23 - 06 Oct 2008    Post subject: Reply with quote
Depends how steady your hand is with a small tip soldering iron mate, I got one of the electrical engineers at work to pull it apart and fix it.
Dragonfly
PostPosted: 17:34 - 06 Oct 2008    Post subject: Reply with quote
Humm I wouldnt want to be wreaking the lap top completly but I did solder my keyboard when it done this when I was a teen. But that was a crappy piano kepboard not a lap top where my life depends on it or I will surely die of boredom. Thinking
panrider_uk
PostPosted: 22:44 - 06 Oct 2008    Post subject: Reply with quote
Maplins do a charger for about £30 that will power your Acer.
Cheapest thing to try if you can't borrow one from elsewhere to try first.
If it turns out it is the laptop, you can always sell the charger on ebay.
Mark
Nufkamp
PostPosted: 05:46 - 07 Oct 2008    Post subject: Reply with quote
Thinking about it you should be able to meter across trhe contacts of the charger socket with a Fluke meter, if it comes up as open circuit then its the socket. If there's continuity then it's most likely the charger.
Dragonfly
PostPosted: 08:29 - 07 Oct 2008    Post subject: Reply with quote
Can I have that in laymans terms please Embarassed
I just lifted the lap top and the plug symbol is off again! touch it wrong and it goes off. I want it to be the charger but somehow I think the first answer is right Crying or Very sad I now have to sit here and dosconnect it as it dosnt seem to charge now and fiddle with the plug in back of lap top. Its on garentee still i just cant go a week without it.
panrider_uk
PostPosted: 13:09 - 07 Oct 2008    Post subject: Reply with quote
Take the laptop to Maplins and explain the situation. I would think they'd let you try a charger before buying.
Mark
Nufkamp
PostPosted: 15:33 - 07 Oct 2008    Post subject: Reply with quote
Use a multimeter and see if there's a resistance (ohms) between the contacts on the charger socket. If the meter shows ohms (continuity) then this means the circuit is intact. No ohms (open circuit) basically means a wire is off between the socket and the mobo. These sockets really are too fragile, my daughter's one has been fixed twice.
Dragonfly
PostPosted: 13:26 - 08 Oct 2008    Post subject: Reply with quote
Took it to the place that takes care of acer warrentys and they tried it and it was the charger and gave me a new one under warrently! Happy days! I thought I was going to be without it for a while and actually cried tears at the thought of this Shocked But I got it back today new charger and its working great Mr. Green
rc211v
PostPosted: 14:05 - 08 Oct 2008    Post subject: Reply with quote
Used to have an acer too. It was the charger that got screwed. They replaced with a new one for free. Then it went out again after a year.
VFR400 (NC30)
Nufkamp
PostPosted: 14:06 - 08 Oct 2008    Post subject: Reply with quote
Good man, all's well that ends well. Thumbs Up
Dragonfly
PostPosted: 16:46 - 08 Oct 2008    Post subject: Reply with quote
Well if it packs up again they arnt that dear to replace on ebay if the warrently runs out, I kinda think it was my fault as it was tangled up for a while and probably put strain on it but they said it wasnt and I kept zip about that lol . But I was really impressed with the customer service of this place and how quick they had it sorted.
The last post was made 17 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 88 Kb
