Any plumbers out there?
J0Al1
PostPosted: 17:32 - 21 Oct 2008    Post subject: Any plumbers out there? Reply with quote
Im bugged by this . . .
Lived here for 3 years. When I moved in the boiler was OLD . . illegal, but I had it serviced and told the guy that the heating turns on even when set to timer on12 timer off 12. Ditto for the water.
BUT . . not all the time. Sometimes its fine and doesnt turn on.
He serviced it n reset it n tested it, said it was fine.
No different.
18 months later I get a new boiler and have the heating system redone throughout the house. Told this plumber about problem and he said by replacing the pump or something in the airing cupboard would solve it.
New boiler, new pump , new turning bits on the end of radiators, system drained etc. . 2k whatever it cost.
STILL same issue.
I have at the moment no heating on, the program is set to 'off'. BUT occasionally it still comes on.
I always have water program on, but set the am and lunch times to 8am 8am and 12pm 12pm then 4:30 - 5:30pm. . But still sometimes i get hot water coming on in the morning or lunch.
Ive tried to see a pattern . . ie is is it after I do an extra hour hot water? No! Weekend thing? No.
Totally random. Ive reset the boiler. I have set the hot water form 12 - 12:05 and it sometimes turns off and sometimes doesnt.
I dont wanna pay for all this heating when Im at work!!!
Any ideas, Id appreciate an end to this insanity.
Itchy
PostPosted: 17:54 - 21 Oct 2008    Post subject: Reply with quote
I had a similar problem recently I borrowed somebody's clock (its one of those manual analogue ones not a electronic one) , and his worked ok mine didn't it also tripped the fuses (bistables) in the house each time it came on...
Replaced the pump (myself) , and the clock cost me £50 problem went away ...
But there is another tricky way around it as I saw in HK where 'boilers' are plugged into the mains via a special socket like ovens...
is to go out to Maplins or something and buy a socket timer thing and just have it switched on all the time and have the socket timer turn it on and off.
Stoo
PoshBoy
PostPosted: 20:49 - 21 Oct 2008    Post subject: Reply with quote
Do you know if you have a hot water storage tank? White meter electricity? A clock switch beside/near your fuse board? Something is calling for hot water/heating. I assume it's not a combi boiler you have as you should only have the boiler firing when the tap is turned on.
rotax81
PostPosted: 20:57 - 21 Oct 2008    Post subject: Reply with quote
if you go to the screwfix site they have a fantastic forum with all sorts of plumbers/electricians on there.
i asked a question about a shower on there once and had 8 replies within 5 minutes Thumbs Up
https://www.screwfix.com/talk/index.jspa?ts=23984
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
Stevep
PostPosted: 19:31 - 22 Oct 2008    Post subject: Reply with quote
OK need to know make of boiler
Make of programmer
And if any fitted room stats or cylinder stats and what they are set at
Harleys run Forever
Ant
PostPosted: 20:35 - 22 Oct 2008    Post subject: Reply with quote
without looking/testing id say either faulty clock or incorrect wiring
04 ZX10R ~
yen_powell
PostPosted: 20:42 - 22 Oct 2008    Post subject: Reply with quote
It's your three way valve sticking with limescale. The valve that channels hot water to your radiators, or your hot water tank or to both, gets clagged up and sticks open when the hot water comes on. This makes your radiators heat up even though they shouldn't.
I have had this, the cheap cure is to turn it manually on and off a few times to clear it (it has an electric motor which you just take off so you can get a spanner on the valve stem). The real answer is to replace it though.
XT1200Z and a DR350 in bits
J0Al1
PostPosted: 20:54 - 22 Oct 2008    Post subject: Reply with quote
AHHH! Sounds like its fixable if I can work out what I've got (which is a hot water bottle at the moment). I will take a look.
Mr. Green
Thanks for the replys
yen_powell
PostPosted: 21:23 - 22 Oct 2008    Post subject: Reply with quote
Mr. Green
Mine is in a cupboard with the hot water tank. Get someone to turn on the heating or hot water and listen by the hot water tank. You will hear a little electric servo whirr slowly. That's the electric switch on the 3 way valve which on mine you can remove by undoing 4 screws and lifting it away.
If you fix it, make sure to turn the heating on a few times over the summer just to make the switch move back and forth and stop limescale building up.
J0Al1
PostPosted: 18:15 - 27 Oct 2008    Post subject: Reply with quote
Finally, I have . . .
I water boiler in the airing cupboard upstairs.
Honewell programer for water and heating in kitchen.
Honewell dial for heating temperature in sitting room.
Halsten Eden VBX 18 boiler for water temp in kitchen.
I'll print this thread out when I'm back in office and see if Dad understand what Ive got to do.
Had a night off last night (son with his Dad last night) so a lie in, WOW, unheard of. . . . bloody hot water woke me up at 6:30!!!! its . . . set to off Sad
Thanks again for all help, I'm sure I'll get it sorted soon.
Cheers x
Stevep
PostPosted: 18:23 - 27 Oct 2008    Post subject: Reply with quote
Your water boiler upstairs is it a Cylinder and does it have a stat attached to the side with a dial on it should be set at around 60c
The honeywell proggrammer in Kitchen has it dual controls or what model number is it
Sounds to me if the hot water programmer was off and the heating was on as though you have a mid position diverter valve which would naturally send it to cylinder if your stat was in a demand mode regardless of what clock is set at
It could also be wired wrong in that it is wired as a s plan when you have a y plan system installed
Harleys run Forever
J0Al1
PostPosted: 18:30 - 27 Oct 2008    Post subject: Reply with quote
Yup for upstairs
ST6400C - it allows me to set water and heating times. On left is overide, once, extra hr and cont. On right is, set time, run programm, off, reset etc
Smile)
Stevep
PostPosted: 20:24 - 27 Oct 2008    Post subject: Reply with quote
What is the cylinder thermostat set at
Also what is room stat set at
What are your individual programmes both hot water and Central Heating
Take it you have it on run programme and on twice a day for both hot water and ch
Harleys run Forever
S1KE
PostPosted: 07:51 - 28 Oct 2008    Post subject: Reply with quote
motorised valve in airing cuboard, replace Thumbs Up
random twat!
* xbox live mickeyc26
* zx6r b1h 2004 GREEN !
J0Al1
PostPosted: 09:12 - 28 Oct 2008    Post subject: Reply with quote
Cylinder is at 60
Heating is at 18
Program is set to off for heating (cos im tight) - this seem to be behaving set to off.
Program set to run program for water
Auto & run program for both
Water set to on at 6:30am off at 6:30am, but alas comes on.
The elec pump in the airing cupboard was replaced, as the plumber that visited said it was the cause.
From reading the above, I can only think its wiring. When the first plumber came 3 years ago, I dont think he replaced the circuitboard/wiring under the front of the programmer, simply put a new front on.
Its so annoying, im having to set the water n heating to on off to not come on at times im likely to be there so I can then turn it off. LOL
If it was wiring fault, wouldnt the required water not work . . as in water on at 4pm - off at 5pm not work sometimes?
Stevep
PostPosted: 21:45 - 28 Oct 2008    Post subject: Reply with quote
Try moving off to 6.31am as it could be overiding it by being on same time Also on the back of the programmer there is a wireing diagram have a look see if it is wired as per the diagram and has no extra cross links in it
Harleys run Forever
The last post was made 17 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 93.52 Kb
