| joop200789 |
 joop200789 Renault 5 Driver
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 11:53 - 01 Nov 2008 Post subject: |
Here's an MOT checklist, it'll give you an idea of what's looked at.
https://www.vosa.gov.uk/vosacorp/repository/Motorcycle%20MOT%20Inspection%20Checklist%20(VT%2040M).pdf ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| joop200789 |
| stirlinggaz |
| joop200789 |
| tutton |
 tutton World Chat Champion
 Posted: 18:56 - 01 Nov 2008 Post subject: |
At the descresion of the garage.
Some will,
Some wont and will fail you, try charge you to do it, and then print the pass cert off  ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
Current: '02 ZX636 A1P '51 CCM R30 |
| Method |
 Method World Chat Champion
 Posted: 10:43 - 02 Nov 2008 Post subject: |
Is the bike a UK RS? A lot are imported which means that your headlight will be firing its kick the wrong way.
Put the bike up against a wall and shine the headlights at it on dipped beam - look for the headlight kick (the bit that goes higher than the rest of it - you will see what i mean).
If it kicks to the left, you can relax. If it kicks to the right, then you have at least an import headlight and you either will need to replace it for MOT or at least tape over it so as to block the kick. ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado
My Bikepics.com - No Brakes, No Gears... No Fear. |
 Posted: 18:41 - 02 Nov 2008 Post subject: |
To set the headlight height, simply shine your headlight on dip-beam onto a wall from about 10 feet away (on level ground). Now roll the bike towards the wall - the spot of light should move upwards very slightly as you roll the bike forwards. If it moves down you need to adjust the beam downwards. ____________________ a.k.a 'Geri'
| joop200789 |
The last post was made 18 years, 14 days ago. Instead of replying here, would creating a new thread be more useful? |
