| steppen22 |
 steppen22 World Chat Champion
 Posted: 19:44 - 02 Nov 2008 Post subject: how do I change brake fluids/brake problem? |
My wheel is still stiff, and I'm getting a little fed up now. I've stripped, cleaned and copper eased the caliper, and I return today and yet again I can hardly move the front wheel with my hand. I really could do without this with my test approaching and u turns, etc, being nightmarishly extra difficult becuase of this. I figure the piston is forcing itself out when the bike is stationary, and I can't think why other than upset fluid pressure.
So I'll need to change fluids. but
a) the screws on my cylinder won't budge. WD40? (but won't this work it's way into the chamber?)
b) I'm not sure what to do. Just unscrew the cable from the caliper and let it flow into a pot. Fill up via cylinder. Or do I need to fill whilst draining - is that what the little nipple under the rubber seal is for?
https://img262.imageshack.us/img262/2377/pict0683kc8.jpg ____________________ no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL. |
| LeeR |
 LeeR World Chat Champion
 Posted: 20:00 - 02 Nov 2008 Post subject: |
The little nipple is where you bleed the fluid from, get yourself a short piece on tubing, slip it over the nipple and drop the open end into a jug. Now while someone squeezes and holds the brake lever (or you can cable tie it) turn the nipple and bleed some fluid out.
Alternatively just open the reservoir and remove the excess fluid using a pippet/syringe or kitchen roll. ____________________ My claim to fame: Austin Vince nicked my pen... |
| TAX MY BRAIN |
 TAX MY BRAIN Nitrous Nuisance
| Cigaro |
 Cigaro World Chat Champion
| finpos |
 finpos World Chat Champion
| Ichy |
 Ichy World Chat Champion
 Posted: 19:38 - 04 Nov 2008 Post subject: |
To undo the master cylinder screws first try the correct size screwdriver, if that doesn't work go for an impact driver, as a last resort https://www.bikechatforums.com/viewtopic.php?t=148055
Do a search for brake bleeding or find someone who can show you how, its a bit risky to be playing with brakes when you have little idea of what to do.
As for the original problem, I've seen the little fluid return hole in the master cylinder get partially blocked with some gunk and cause similar problems, might be worth cleaning it all out. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| rotax81 |
 rotax81 Nearly there...
| Ichy |
| Cigaro |
| Vincent |
 Vincent Banned
| Ariel Badger |
 Ariel Badger Super Spammer
| steppen22 |
| Cigaro |
The last post was made 17 years, 344 days ago. Instead of replying here, would creating a new thread be more useful? |
