wheres the indicator relay on a derbi senda!!!!
davthegreat
PostPosted: 17:01 - 09 Nov 2008    Post subject: wheres the indicator relay on a derbi senda!!!! Reply with quote
does anyone have any idea where the indicator relay is on a derbi senda because i dont have a clue where it is and i really need to buy a led one to replace it.
ive looked under the seat and in the front behind the front cowl but no look and also ive listerned for it and still can not find i.
please help , thanks
Ant132
PostPosted: 17:20 - 09 Nov 2008    Post subject: Reply with quote
Could it be mounted to the frame underneath the tank?
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
davthegreat
PostPosted: 18:04 - 09 Nov 2008    Post subject: Reply with quote
right i had a look under the tank and couldnt find anything black box a like.
but heres the problem i put all the led indicators on the bike and when i start the bike and turn one side on they flash really slow but when i rev the bike they flash at a normal speed (bike ticks over at 1900rpm and they flash slow , and at about 3000rpm they flash normal) could it be my battery being rubbish because my battery has always been at low charge and isnt very good and i never thought of getting a new one because the bike worked fine with out it. Being a kick start and the lights and everything worked ok without the need for a good battery.
could this be the solution to my problem in which buying a new battery will make my led indicators work
thanks for any help or repiles
rotax81
PostPosted: 18:36 - 09 Nov 2008    Post subject: Reply with quote
it certainly sounds like your battery has had its day. if its more than 3 years old change it anyway as it will be a lot better.
as for your flasher unit look for a silver one as well as a black one as it can be either Thumbs Up
if you can, follow a wire back from the indicator to find it.
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
davthegreat
PostPosted: 20:51 - 09 Nov 2008    Post subject: Reply with quote
right i looked for the relay thing around the bike by tracing wired and it came back to the rectifyer? also ive been doing some digging on google and you know and found out that derbi senda's have a rectifyer/relay its a combined unit so im hoping to not have to change that
also on battery terms. yes it is older than 3 years i think its the original and also before i bought the bike it had been stood for a couple of months or more so i think the battery has seen better days.
but the main thing is if i get a new battery will it make my indicators work properly. thanks for the help
rotax81
PostPosted: 21:03 - 09 Nov 2008    Post subject: Reply with quote
when you are revving the motor the volts go up so the flashers are getting what they want, hence they are working fine.
at low revs your 'knackered' battery can not cope.
best to get a volt meter on it.
12v should read at least 12.5v WITHOUT the bike running.
13v+ with it running over 5000rpm
6v should read at least 6.2v without the bike running
nearly 7v+ running over 5000rpm
my guess is yours will be under its volts with the ignition off Thumbs Up
davthegreat
PostPosted: 21:07 - 09 Nov 2008    Post subject: Reply with quote
right ok tomos ill get the good old volt metre out, but if the battery is under volt and i buy a new one do you know if it will make my indicators work fine without buying a new relay or resistors
also the normal indicators work fine on the bike at tick over revs ???
thanks
rotax81
PostPosted: 21:13 - 09 Nov 2008    Post subject: Reply with quote
check all your wiring to make sure everything is clean and tight,
especially what you changed as they were 'ok' before the change.
make sure the LED contacts are clean.
check the battery terminals are clean and tight as dirty or loose ones can lose power.
davthegreat
PostPosted: 21:16 - 09 Nov 2008    Post subject: Reply with quote
ok will do thanks
im gonna try a new battery or "12v supply" tomos to see if the indicators work with a decent battery on also i will check conections as wel just to make sure
thanks for your help ill have a update tomos Thumbs Up
and i hope they will work with a non trashed battery cos otherwise it gets complcated with resistors and relays Sad
The last post was made 17 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 60.92 Kb
