Hand cream - the good stuff
WildGoose
White Van Man
PostPosted: 21:34 - 19 Nov 2008    Post subject: Hand cream - the good stuff Reply with quote
Wanted to put hardcore in the title, but that would probably be asking for trouble on here, going by lately.
I deliver hay and straw, and the baling twine is ripping my hands to shreds after the first hundred or so are handled per day, particularly on the cold days, you see the blood before you feel it.
I need something decent, not some Nivea rubbish that does naff all but make your hands greasy for 10 mins then disappears.
I need something that scottish fisherman or lumberjacks would use, because it works. Along those lines.
Any recommendations please.
NB: Gloves are not an option, they are inefficient and just get stuck everywhere, dropped, soaked through and eventually ripped or lost. Need my hands to toughen up, but to not bleed too much in the process.
Mudskipper
PostPosted: 21:35 - 19 Nov 2008    Post subject: Reply with quote
Neutrogena stuff - it's concentrated (Norweigen fishermen use it).
You can get it unperfumed too.
Good shit. Thumbs Up
https://www.mistrys.co.uk/images/images/Neutrogena_Hand_Cream_3219.JPG_3219.jpg
SlimRick
PostPosted: 22:03 - 19 Nov 2008    Post subject: Reply with quote
Hay hooks FTW
https://www.horsetackinternational.com/images/139352-hay-hook.jpg
Dragonfly
PostPosted: 22:04 - 19 Nov 2008    Post subject: Reply with quote
Eucerin
I use it on face but have the had cream also , all this typing really takes it out of my hands. Mr. Green
Wave2k
G's Stalker
PostPosted: 22:11 - 19 Nov 2008    Post subject: Reply with quote
I get the same problem, i think due to the cold they just dry and the skins cracks and peels, most hand cremes do diddley squat for me.
Ducati 1299 Panigale
2009 Corvette C6 z51
yambabe
PostPosted: 23:08 - 19 Nov 2008    Post subject: Reply with quote
What Mudskipper said, if you're going for a hand cream Neutrogena is definitely the best.
Might be worth looking into barrier creams rather than hand creams though? Neutrogena will help once your hands are cut/chapped etc but a decent barrier cream may lessen the effect of the damage in the first place.
sickpup
Old Timer
PostPosted: 23:09 - 19 Nov 2008    Post subject: Re: Hand cream - the good stuff Reply with quote
if you ask your other half nicely she can put a length of string through the arms of your coat to stop you losing them. Wink
Flip
PostPosted: 00:15 - 20 Nov 2008    Post subject: Reply with quote
I doubt barrier cream would help to be honest Jo.
Gloves would be an obvious thought.
SpicyBlimp
PostPosted: 00:52 - 20 Nov 2008    Post subject: Reply with quote
+1 i use this quite alot after fixing rusty pipes, works a treat Thumbs Up
colin1
Captain Safety
PostPosted: 00:57 - 20 Nov 2008    Post subject: Reply with quote
I've not done the job, but it does sound to me like better gloves are needed, maybe ones secured at the wrist like motorbike gloves...
surgical spirit toughens up skin, so you could use that instead
all moisurisers or hand creams do, is provide a oil based barrer to moisture escaping from the skin
better to drink more fluids in my opinion
fishermans gloves
https://www.devontackleshop.com/epages/devontackleshop_com.sf/?ObjectPath=/Shops/devontackleshop.com/Products/78-11000&ViewAction=ViewProductViaPortal&Locale=en_GB
lumberjacks gloves
https://www.smithfarmstores.com/p-1927-wells-lamont-quilted-lumberjack-gloves.aspx
Suitor_Stu
PostPosted: 01:09 - 20 Nov 2008    Post subject: Reply with quote
https://www.mistrys.co.uk/images/images/E45_Tube_Cream_2790.JPG_2790.jpg
I swear by this stuff - I use handwashes and gels all day which are pretty much rip your skin to shreds (chemically, not physically mind) and i find that the original e45 cream really helps. Tried the Norwegian Formula stuff, but I thought it was too concentrated for my liking, I prefer the feeling of a good dollop of cream in me palms...ooh er matron!
Stu
colin1
Captain Safety
PostPosted: 01:21 - 20 Nov 2008    Post subject: Reply with quote
I forgot to add, I think the hayhooks, are probably the best bet.
PostPosted: 01:51 - 20 Nov 2008    Post subject: Reply with quote
Another vote for Neutrogena hand cream.
The next problem you will have is a rash on your forearms where the ends of the hay prickle them. Wearing a long sleeve top and putting a spiral of gaffa tape or PVC tape along the arm below the elbow (on top of the sleeve) works well for this.
You'll be wanting leather knee patches in your trousers too. You can easily knack three pairs of trousers if you are stacking square bales for a week.
I agree, gloves aren't a good option, your hands will cramp if you wear gloves. The only ones you'd get away with are those skintight yellow buckskin ones. They are expensive and almost impossable to get hold of in the UK.
Charlie
PostPosted: 11:02 - 20 Nov 2008    Post subject: Reply with quote
Used some similar stuff when my ankles were several cracked (from wearing flip flops), and that stuff fixed it in two days. The first day I could and see the difference it had made and by the second it was nearly back to normal.
Skudd
PostPosted: 11:14 - 20 Nov 2008    Post subject: Reply with quote
SlimRick wrote:
Not to be used as a chat up line when picking up women.
Annabella
Like a person, only smaller
PostPosted: 13:38 - 20 Nov 2008    Post subject: Reply with quote
I was definitely going to recommend barrier cream - whilst it generally smells minging you get used to it. It really helped when I was working at hell on earth (heat treatment plant) handling hot metal covered in degreaser all day.
The other thing I used to do, which I suspect you'd be less inclined to try, is wear cotton gloves in bed. Absolutely cover your hands in E45 (really thick) then wear the gloves - the moisturiser will absorb overnight.
Avast! Pirates ahoy!
I did Cadwell! Very Happy
Mudskipper
PostPosted: 14:18 - 20 Nov 2008    Post subject: Reply with quote
https://img.photobucket.com/albums/v246/super_jo/flashdance1-1.jpg
https://harryallen.info/wp-content/uploads/2008/04/flashdanceposter.jpg
Question
sickpup
Old Timer
PostPosted: 23:11 - 20 Nov 2008    Post subject: Reply with quote
Mudskipper stop dribbling please. Wink
Phoenix
Twisted Firestarter
PostPosted: 06:25 - 21 Nov 2008    Post subject: Reply with quote
No amount of skipping round the issue of gloves is going to get around the fact that they are the best solution.
As colin said, find some that fasten around the cuff, or get some very close fitting thin leather ones or something.
I use a grand total of 3 different pairs of gloves a day at work for not totally dissimilar reasons. A pair of riggers gloves for dirty work and dieseling, some rubber gloves to go inside and some cheap fleecey gloves for general work. If I don't use them I end up with sore, red cracking skin on my right hand particularly. I also find that if I wash with handwashes of any kind it makes my skin the same, I have to use plain soap at home which is fine.
Louise
PostPosted: 10:38 - 21 Nov 2008    Post subject: Reply with quote
Atrixo works best for me Thumbs Up
PostPosted: 14:12 - 22 Nov 2008    Post subject: Reply with quote
I give you half an hour wearing gloves to lift bales before your hands cramp and you have to take them off again.
That's if they don't land up trapped in the string on to of the stack.
If they aren't too waterlogged, you can use a pitchfork.
Flip
PostPosted: 14:39 - 22 Nov 2008    Post subject: Reply with quote
https://cgi.ebay.co.uk/Size-9-Ansell-Hyflex-11-500-Kevlar-Gloves-45-Pk-10_W0QQitemZ370117256227QQcmdZViewItemQQptZUK_BOI_ProtectiveGear_RL?hash=item370117256227&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A2%7C240%3A1318
They're good gloves, normally get a week or more out of a pair working with steel but they aren't cheap. £45 for 10.
WildGoose
White Van Man
PostPosted: 15:29 - 22 Nov 2008    Post subject: Reply with quote
Thanks for all the replies, I've picked up some atrixo, and have some of that Neutrogena on the way (the Norway flag alone, sells it to me Razz how clever of them).
The key thing is I want my hands to stay supple long enough for them to toughen up a bit, rather than cracking/ripping and then having to start over.
Gloves are fine when dexterity isn't required, but as stinkwheel seems to know, hay bales can be really awkward getting your fingers under the twine in order to pick them up it rules out gloves instantly on all but the loosest bales. We throw them a lot as well, the gloves would get stuck in the bale and sap the kinetic energy out of the throw, just at the worst time.
Hay hooks FTW
Might be useful for carrying individual bales a distance, but can't see any other use for that, short of hanging dead people from. Thinking Looks a very american idea, introducing a sharp metal object to a dodgy enough problem.
WildGoose
White Van Man
PostPosted: 15:34 - 22 Nov 2008    Post subject: Reply with quote
You'll cease to be top courier extraordinaire if you insist on giving out all your trade secrets like that. Razz
Flip
PostPosted: 15:55 - 22 Nov 2008    Post subject: Reply with quote
The lack of tools is suprising. Hay hooks and thats it. Big bulldog clip type things with teeth is what you need, now go and invent some proper hay handling tools. Laughing
The last post was made 17 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 130.9 Kb
