Cant get any pressure to pump pistons from caliper
Wise1
PostPosted: 13:41 - 19 Nov 2008    Post subject: Cant get any pressure to pump pistons from caliper Reply with quote
Bike has been sitting for years so all the pistons are seized. Got back done ok and now onto front.
I had to remove the caliper completely to get pads out first, then I put the caliper back on to line to bleed and pump the pistons out, but I just cant get any pressure at all back in to pump them out.
Fluid is coming out of the bleed nipple and cant see any air.
The only difference between back and front being the pistons are in opposite ways, so for the back I could grip the inside of the piston to ease it out but with them being round the other way on the front I cant get anything inside the piston to help so the only way is to ease them out using fluid.
Just cant see why I cant get pressure built up after I have taken them off, there are no leaks anywhere.
any suggestions?
Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600
ssray
PostPosted: 13:52 - 19 Nov 2008    Post subject: Reply with quote
What bike? try tying the brake lever back to the handlebar overnight, it allows any air out of the top of the system.
Ray
Wise1
PostPosted: 13:55 - 19 Nov 2008    Post subject: Reply with quote
Will try that, its a vfr750fg 1986
I was going to try using the compressor later but not sure if that will work. And considered heating some oil in the caliper but got nothing to hold it when the piston fires out and kills someone Smile
Robert2014
PostPosted: 20:36 - 19 Nov 2008    Post subject: Reply with quote
Lee Leave Bleed Nipple in and put the Airline into where the Bango Bolt go's and that will Pop out the Piston's for u mate
If you require a mechanic then I am your man. Bike collection and recovery service available. Don't let a monkey work on your bike, call the family run business on 07778 873 184 01505684994 https://www.rdbikes.co.uk [email protected]
Ariel Badger
PostPosted: 21:59 - 19 Nov 2008    Post subject: Reply with quote
Screw a grease nipple in the hole where the bleed is and blank off the hose connection with a plug and pump grease into her, she will pop.
stirlinggaz
PostPosted: 22:35 - 19 Nov 2008    Post subject: Reply with quote
hi,
you have my sympathies.
im restoring an 1986 fg (though its the californian 700 model) & could not get the pistons out whatsoever- tried wd40,plusgas,airline, clamping one piston etc. wouldnt budge. (rear caliper though)
they had seized on, & when i removed the caliper i spent days trying to get the pistons out, but gave up & i'm just gonna get a replacement caliper! (after i priced new pistons & seals!)
as mine is the same as yours (except engine size obviously, if your needing manuals or any spares, give me a shout-likewise, if you have any spares etc)
just replaced rear shocker & started on front suspension. (still has funtioning ant-dive!)
next step, powdercoat wheels & engine casings (the usa bike has white wheels & gold engine casings)
then rip off the pair/evap system!
cheers,
GAZ
PostPosted: 22:38 - 19 Nov 2008    Post subject: Reply with quote
1930 Ariel wrote:
Screw a grease nipple in the hole where the bleed is and blank off the hose conection with a plug and pump grease into her, she will pop.
How do you then get the grease out?
Ariel Badger
PostPosted: 22:43 - 19 Nov 2008    Post subject: Reply with quote
Tissue and petrol like cleaning your nob after a dirty handed w@nk. If the caliper is this seized the entire thing needs striping so a spot of grease does no harm.
sickpup
Old Timer
PostPosted: 23:12 - 19 Nov 2008    Post subject: Reply with quote
Or you could just send it to me to strip and rebuild.
stevo as b4
PostPosted: 23:20 - 19 Nov 2008    Post subject: Reply with quote
I managed to use a piece of tube connected to a foot pump once, to remove pistons from the caliper of my mate's KTM. We tried the airline method on the front caliper though, and the next thing we heard was the ricochet of the piston hitting all the walls of his metal garage, and land on top of a shelf. We barely saw where it went, as we we ducking to avoid a direct hit between the eyes! It certainely removed the piston easily enough, but with far more violence than i thought it would!
Not sure if id try it again after that TBH.
yambabe
PostPosted: 23:24 - 19 Nov 2008    Post subject: Reply with quote
Have you got braided hoses or normal?
If not braided, apparently you could try undoing the bleed nipple and then (making sure the reservoir is full of fluid) squeeze the brake pipe gently with a pair of pliers about 2 inches from the master cylinder and pump the brake to see if you get any pressure.
If you have pressure pump the brakes and ease off with the pliers, then move further down the brake line and repeat, you may need to do it a couple of times.
I am being told that this will restore full pressure to your whole braking system so if you then close the bleed nipple and pump the brakes it should start to push your pistons out.
stirlinggaz
PostPosted: 08:05 - 20 Nov 2008    Post subject: Reply with quote
hi,
Sickpup, worth rebuilding?
figured it'd probably be a helluva lot cheaper & easier just getting a s/h working caliper?
pm me with details? oh & i'll be needing braided hoses as well.
cheers,
GAZ
TAX MY BRAIN
PostPosted: 20:59 - 20 Nov 2008    Post subject: Reply with quote
as said by other poster's
use compressed air , or grease gun,
just a word of warning they will pop out like a rocket .....
i always place a piece of wood between the piston's this will help in two ways,
it will stop the piston's flying out and it will also ensure that all the pistons come out
( one before the other so ones out and ones stuck )
also place a heavy towel over the caliper just in case they do fly might say your face,
good luck
i also ride the local bike.............she's like a moped great fun to ride as long as your friends dont see you !!
Ariel Badger
PostPosted: 22:16 - 20 Nov 2008    Post subject: Reply with quote
Grease is far safer than air as it does not compress and release a vast amount of kinetic energy. Things plop out rather than pop out.
Wise1
PostPosted: 00:49 - 21 Nov 2008    Post subject: Reply with quote
However using compressed air while pointing the caliper at a wooden bench to see how far you can get the piston to sink into the plywood is much more fun after all the hard work of trying to free it Thumbs Up
Wise1
PostPosted: 00:50 - 21 Nov 2008    Post subject: Reply with quote
stirlinggaz wrote:
hi,
cheers,
GAZ
Cheers, will drop you a pm Thumbs Up
The last post was made 17 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 95.15 Kb
