| Wise1 |
 Wise1 World Chat Champion
| ssray |
 ssray Borekit Bruiser
| Wise1 |
 Posted: 13:55 - 19 Nov 2008 Post subject: |
Will try that, its a vfr750fg 1986
I was going to try using the compressor later but not sure if that will work. And considered heating some oil in the caliper but got nothing to hold it when the piston fires out and kills someone  ____________________ Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600 |
| Robert2014 |
 Robert2014 World Chat Champion
 Posted: 20:36 - 19 Nov 2008 Post subject: |
Lee Leave Bleed Nipple in and put the Airline into where the Bango Bolt go's and that will Pop out the Piston's for u mate ____________________ If you require a mechanic then I am your man. Bike collection and recovery service available. Don't let a monkey work on your bike, call the family run business on 07778 873 184 01505684994 https://www.rdbikes.co.uk [email protected] |
| Ariel Badger |
 Ariel Badger Super Spammer
| stirlinggaz |
 Posted: 22:35 - 19 Nov 2008 Post subject: |
hi,
you have my sympathies.
im restoring an 1986 fg (though its the californian 700 model) & could not get the pistons out whatsoever- tried wd40,plusgas,airline, clamping one piston etc. wouldnt budge. (rear caliper though)
they had seized on, & when i removed the caliper i spent days trying to get the pistons out, but gave up & i'm just gonna get a replacement caliper! (after i priced new pistons & seals!)
as mine is the same as yours (except engine size obviously, if your needing manuals or any spares, give me a shout-likewise, if you have any spares etc)
just replaced rear shocker & started on front suspension. (still has funtioning ant-dive!)
next step, powdercoat wheels & engine casings (the usa bike has white wheels & gold engine casings)
then rip off the pair/evap system!
cheers,
GAZ
| ms51ves3 |
 ms51ves3 Super Spammer
| Ariel Badger |
| sickpup |
 sickpup Old Timer
| stevo as b4 |
| yambabe |
 yambabe World Chat Champion
 Posted: 23:24 - 19 Nov 2008 Post subject: |
Have you got braided hoses or normal?
If not braided, apparently you could try undoing the bleed nipple and then (making sure the reservoir is full of fluid) squeeze the brake pipe gently with a pair of pliers about 2 inches from the master cylinder and pump the brake to see if you get any pressure.
If you have pressure pump the brakes and ease off with the pliers, then move further down the brake line and repeat, you may need to do it a couple of times.
I am being told that this will restore full pressure to your whole braking system so if you then close the bleed nipple and pump the brakes it should start to push your pistons out. ____________________ Sod falling in love, I wanna fall in chocolate.  |
| stirlinggaz |
| TAX MY BRAIN |
 TAX MY BRAIN Nitrous Nuisance
| Ariel Badger |
| Wise1 |
 Posted: 00:49 - 21 Nov 2008 Post subject: |
However using compressed air while pointing the caliper at a wooden bench to see how far you can get the piston to sink into the plywood is much more fun after all the hard work of trying to free it  ____________________ Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
| Wise1 |
 Posted: 00:50 - 21 Nov 2008 Post subject: |
| stirlinggaz wrote: | hi,
cheers,
GAZ |
Cheers, will drop you a pm  ____________________ Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
The last post was made 17 years, 345 days ago. Instead of replying here, would creating a new thread be more useful? |
