how to unscrew an unmovable screw?
steppen22
PostPosted: 17:07 - 08 Dec 2008    Post subject: how to unscrew an unmovable screw? Reply with quote
I want to change my dot4, however, the screws won't budge. I've finally unscrewed one having sprayed (reluctantly) the top of the chamber with wd40, howeverm the second screw is stubbornly staying put.
what to do, what to do...?
ybr125
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
4Stroke
PostPosted: 17:15 - 08 Dec 2008    Post subject: Reply with quote
Try with a good pair of grippy, chunky pliers if you don't mind tearing it up.
I find the screws on round master cylinders protrude quite abit, enough to get a good hold with the pliers anyway.
stirlinggaz
PostPosted: 17:24 - 08 Dec 2008    Post subject: Reply with quote
hi,
are you talking about the 2 screws that hold the cover on the m/c?
these always round off, cos folks use the wrong screwdriver on them!
just last night removed one by grinding the top of the screw off with the pink pointed grinding stone attachment on the dremel.took about 5mins.
cover then lifts off & your left with the stub of the screw.
this comes out with molegrips.
replace with decent screws.
cheers,
GAZ
chillpill
PostPosted: 17:34 - 08 Dec 2008    Post subject: Reply with quote
or if you dont have a dremel drill it
if the bottom doest come out youll have to drill it a tiny bit bigger if youve got enough room and helicoil and new thread in there
Jello
PostPosted: 17:37 - 08 Dec 2008    Post subject: Reply with quote
Impact driver.
Marvelous tools.
Honda MTX 125
4Stroke
PostPosted: 17:40 - 08 Dec 2008    Post subject: Reply with quote
Jello wrote:
Impact driver.
Marvelous tools.
On the master cylinder though? Confused
Mudskipper
PostPosted: 17:43 - 08 Dec 2008    Post subject: Reply with quote
Search for master cylinder bolt on here.
https://www.bikechatforums.com/viewtopic.php?t=159066&highlight=master+cylinder+bolt
When I had to get mine out, my first attempt worked, which was hammering a cheapo torx bit (like allen key but star shaped) into the chewy mess and turning that.
If that hadn't worked, first I'd have tried to turn it using a punch as a drift, then if that failed then drilling head out with dremel pink bit and removal of cap and mole grips on bolt stumps was next.
Bishbash
PostPosted: 17:55 - 08 Dec 2008    Post subject: Reply with quote
If you have rounded them off do the following;
Find a nice hand held drill, size up the drill bit you need from the loose screw. You'll need one roughly the same size as the thread of the screw.
Drill the head of the screw off, you dont need to completely drill all of if off. No need to go overboard with it, just enough to really weaken the head of the screw, then pull the top off.
Then you can get the thread of the screw out with a pair of pliers and then replace the screw. Thumbs Up
baldy
PostPosted: 18:38 - 08 Dec 2008    Post subject: Reply with quote
If you drill a hole in the head a little bit smaller than a torx(sp?) bit and hammer the torx bit in, it will unscrew it. i've done this on many a rounded bolt and it works a treat. Just don't drill too deep, a few mm will do on a master cylinder screw.
One day i will rule the world, just not today.
jam125
PostPosted: 18:56 - 08 Dec 2008    Post subject: Reply with quote
hi when i rounded the screws in my master cylinder i used a small sharp punch to tap it round till its finger tight and then replaced them with nice stainless allen head bolts.
ZRX61
Victor Meldrew
PostPosted: 21:15 - 08 Dec 2008    Post subject: Reply with quote
4Stroke wrote:
Jello wrote:
Impact driver.
Marvelous tools.
Yup, used it on dozens of them
befdelta7
PostPosted: 22:24 - 08 Dec 2008    Post subject: Reply with quote
had that happen before, i cut i line in it with a hacksaw then used a flat head screw driver to unscrew it Thumbs Up
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
Ichy
PostPosted: 23:05 - 08 Dec 2008    Post subject: Reply with quote
Nice bit of sawing, all of mine have been countersunk.
More ways to undo them than you will ever need.
https://www.bikechatforums.com/viewtopic.php?t=148055
fatsamurai
PostPosted: 23:15 - 08 Dec 2008    Post subject: Reply with quote
Jello wrote:
Impact driver.
Marvelous tools.
Seconded Thumbs Up
Hyosung GT125 Thumbs Up [SOLD] -> Suzuki GSX 750W Thumbs Up [SOLD] -> SV650S Sick [Crashed] -> FZ6 Cool
lutmfurl
PostPosted: 23:46 - 08 Dec 2008    Post subject: Reply with quote
Wilkinsons are selling a screw removing attachment for a drill at the mo. (well my local one is). Amazing bit of kit. They have them reduced to about 3 quid. Fits into your drill and bites into the head and hey presto out comes your screw. You get 2 sizes and I can tell you that its well worth the spend.
We came, we saw, we drank the place dry.
befdelta7
PostPosted: 02:41 - 09 Dec 2008    Post subject: Reply with quote
there is always a way to remove a stubbon, rounded screw... always!
i have spent countless hours of my life over the years sitting, looking and thinking of a way on how to get a rounded screw out, never once been defeated thoe Mr. Green
just a bit of imagination and some "go"... bam job done Cool
The last post was made 17 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 90.31 Kb
