| Visitor Q |
 Visitor Q $25 whore
 Posted: 16:54 - 18 Dec 2008 Post subject: New development. Massive backfires but no starting. - Update |
Further to this thread there are new symptoms.
Bike now refuses to start. If the starter is held down (clutch in, lights off and with choke on) the engine does not catch, then after about 40 seconds there is by far the loudest backfire I've ever subjected my ears to.
The fuel pump is making weird clicking/solenoid noises, and the generator/stator area is just making whirring noises.
This is following the bike only running on full choke the other day, then running rough.
This to me seems like a fueling problem, but I'm not certain how to go about with it. Also the sparkplugs are a bit ancient, reckon that could cause all of this?
By the way, I'm not really that lazy. I'd love to fit all kinds of new things, but the way lack of any access makes most jobs a complete ballache. I just don't fancy tearing off the airbox and carbs just to change throttle cable or sparkplugs etc, especially as the thing invariably doesn't work afterwards. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 17:16 - 18 Dec 2008 Post subject: |
Sounds like you have no fuel getting to the carbs.
The fuel pump will get louder and make clicking noises when there is no fuel running through it.
 ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 19:21 - 18 Dec 2008 Post subject: |
Will have a look at pipes and such. Really hate diagnosis
As for sparkplugs, a full set for mine is like 25 quid. It seems like an utter ball ache but I'll give it a go to rule it out. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| Itchy |
 Itchy Super Spammer
 Posted: 19:25 - 18 Dec 2008 Post subject: |
£25 for spark plugs? , sparks for a CBR are NGK £2.20 each, the ball ache is getting them out, tank off airbox off, then you can get to them.
I wonder if the CBR will take the NTV fuel pump bodge , ie if the fuel pump on the NTV goes you can disconnect the pipe and lead it into the carb and it runs ok if a bit rich. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 19:38 - 18 Dec 2008 Post subject: |
Haha, you're all going to call me sucker now, but I just bought 4 Iridium ones for £30 delivered.
Considering EVERY normal spark plug on fleabay was £5 plus, and the sets of 4 were £25 plus I figure for the extra fiver. Treat the bike (even if it is a placebo) since I've omitted even checking them for 3 years
Just checked haynes and its adamant its a 1 spanner retard job. I could never see how you'd get to them so assumed it was a sod.
Ah well, post is still working fine so will whack them in asap.
Also haynes mentions nothing about how to drain float bowls. They don't exist apparently. And to get the carbs off is an utter swine, I remember it vividly from de-restricting it. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| metal ken |
 metal ken Spanner Monkey
 Posted: 19:39 - 18 Dec 2008 Post subject: |
If you find the pump is working i would check if the Spark plugs are wet once you crank the engine over a few times.
Then I would check the plugs are sparking properley, Take them out & put them against the engine with the ht lead attatched and they should spark when you crank the engine, this will test the coils and leads aswel.
Check the feul filter aswel, make sure it is not blocked.
Good Luck, Ken  ____________________ My motorbike breakers metalken.co.uk
Current bikes, GSXR750 Fighter, GSXR7/12, RD350 race rep, KH400 |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 19:57 - 18 Dec 2008 Post subject: |
| CHR15 wrote: | oh dear....
iridium plugs might work, but only when your enigne is set up properly. ( i hope you prove me wrong but ive had bad experiences with them before)
Aye I saw the fun on BCF. To be honest I've thought the bike has been running lovely recently, and thats with 3 years worth of gunge on the plugs. I think the CBR just doesn't care, and if they don't work that well I should have the money by summer to swap them over and flog the iridium ones.
I think its just something I need to get out of my system.
| Quote: |
why does everyone keep going on about fuel? if it back fires alot, then theres plenty of fuel getting there, but the spark is so awful, there has to be loads of fuel in the cylinder and then it will go bang. burn off the fuel, and the cycle starts over. |
The whirring fuel pump, mental choke business seem most like fuel though
The fact its not catching despite turning over could be fueling or spark.
I'm going to chuck an extra jerry can in the tank so I can get it back onto main for sure (I turned it to reserve when it originally started spluttering, although it was about 10-20 miles early).
Also going to try starting it with the fuel tank open to check if theres a problem with the breathers.
You are right though, the sporadic backfires are confusing. Could there just be a blockage in the jets meaning limited fuel is getting in, so it eventually goes pop.
Or maybe just the plugs died (although that wouldn't happen on 4 plugs at once). ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| Visitor Q |
 Visitor Q $25 whore
| sickpup |
 sickpup Old Timer
| GSXR_Warrior |
 GSXR_Warrior Scooby Slapper
 Posted: 20:50 - 18 Dec 2008 Post subject: |
My GSXR was doing exactly the same a couple of days ago. Sure enough a change of plugs sorted it out. ____________________ GSXR600K4 Blue - fastest colour. No mods as yet. Happy with standard bike.
www.twitter.com/GSXR_Warrior |
| Visitor Q |
 Visitor Q $25 whore
| Visitor Q |
 Visitor Q $25 whore
 Posted: 00:08 - 19 Dec 2008 Post subject: |
Found one for £7
Will check tomoro to see if it flow alright or not, as thats my last £7 in the bank
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 00:32 - 19 Dec 2008 Post subject: |
im gunna say what i always do when shit like this happens,
check your valve clearances/.
every one ignores doing them, as they think its a hard job, or are too scared,
buy a 5 quid feeler guage, leave the bike over night, whip the tank ect, plugs out and remove rocker cover,
then its just 10 mins work to check,
(write down all your clearances) and if all is good and clearances are with in spec, then all good,
if not, then it'll be time to get new shims,
the number of times its the root of evil .....
although i think its just a fueling issue, but may be not  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 01:29 - 19 Dec 2008 Post subject: |
| hmmmnz wrote: | im gunna say what i always do when shit like this happens,
the number of times its the root of evil ..... |
I REALLY do want to do it. Honest. I'm just scared. Not to check them.
More to tale off fairings, tank, airbox, carbs, rocker cover, check clearances which will obviously be out.... then what. Put it all back together and take it to a mechanic? Try it myself and cock it up spectacularly and then take it to a mek?
Bah. Where do you live Hmmmmmmmz. If I buy you a pint will you do it for me? Please?
In all seriousness its on my to-do-list when I have some money or a mate I can blag. But then again so is carb balancing.
But as with all bike work I just loathe taking off lots of other bits to check/fix other bits. When my sump was buggered I didn't mind having to go through the utter bugger of removing radiator to remove exhaust to remove sump. Because I KNEW it needed doing. My throttle cable could do with being changed, but I'd have to tear off tank to get at the airbox to get off the carbs to get at the cam to get one end of the cable of.
Drives me nuts on a 'couldnt hurt to change em' type of thing.
This is why I ride a honda  ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| D O G |
 D O G World Chat Champion
 Posted: 04:57 - 19 Dec 2008 Post subject: |
Hmmmz lives in NZ, so unlucky.
What we need is a stikied thread written by someone who knows what they're doing (preferably Sickpup) on trouble shooting poor running, and correct setup and maintenance of fuelling and ignition.
Since it seems to me (and I would have thought is fairly true), that these are two major aspects of poor running. Other bits like top and bottom ends make noises which you can hear, but fuelling and ignition affect the quality of the bike's running, including most starting problems.
You know, like a checklist as to what they would do if someone brought the bike to them with a starting/poor running issue. I think it would be so helpful, and stop the wasting of shitloads of time and money (like I did) of the people like me who have a poor knowledge of how to diagnose and isolate a running problem.
Oh, and posting in the thread should be restricted to a select group of people (maybe 5 on here) to preserve its quality.
Unlikley to happen, but it would be marvellous. |
| sickpup |
 sickpup Old Timer
| Barry_M2 |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 18:21 - 19 Dec 2008 Post subject: |
Right. Quite pleased with my diagnostic foray earlier;
- We have a good spark.
- Took out all plugs, will be replacing them but asides from looking old and a /bit/ oily. Look exactly like the 'normal' plugs from Haynes.
- Fuses are fine, no (visible) breaks
- Fuel is getting through the tap
- Fuel is getting through the filter at full speed
- Breather pipes etc are not blocked, cracked etc
- Pump didn't pump (into a jerry can) when still hooked up and the starter was pressed, yet pumped fine (quite impressively even) when hooked up to the battery...
So either that (^^^^) is normal, or it's something to do with the wiring to the fuel pump?
In which case why is the generator making mental noises too?
Oh and with the full tank and the on main full the bike did originally try to catch, could hear it doing the normal cold start chugging. Then big backfire and nothing but electrical clicks/whirs.
| m0l0t0v |
 m0l0t0v World Chat Champion
 Posted: 18:35 - 19 Dec 2008 Post subject: |
Checked for fuel in the carbs yet?  ____________________ '99 Hornet 600 , VFR 400 NC30 '92 , Kasawamasaki GT 550 , '98 Hornet 600
**\Tarmacsurfer/** said: It's that immaculately manly coiffure of yours isn't it. One glimpse of your virile locks and the punters can't wait to buy whatever it is you suggest, as it might let them be just a little bit like the Adonis that is our very own Molly Doovydoo said: Its not my fault I can't get it up properly, I just wasn't blessed  |
| sickpup |
 sickpup Old Timer
| Visitor Q |
 Visitor Q $25 whore
| Timmeh |
 Timmeh World Chat Champion
| Visitor Q |
 Visitor Q $25 whore
 Posted: 13:58 - 23 Dec 2008 Post subject: |
Righto.
Replaced the fuel pump cut-off relay.
No joy. Still does the same thing. Would even try to catch this time and the alternator/generator is making a lot of noise. I don't know if it's normal (and the engine noise would block it out) or a symptom.
Either way, can someone please give me a clue as to how to use the CDI to check;
The wiring from fuel pump to relay
The relay
The CDI/Wiring
I'll love you forwever. G'wan, it's Christmas. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| Robby |
 Robby Dirty Old Man
 Posted: 15:18 - 23 Dec 2008 Post subject: |
Remember that around 90% of fuelling problems turn out to be electrical.
So, quick check for fuel getting to the carbs - open up a carb float bowl drain screw, and see if some fuel comes out. Should be about an eggcup full in each carb, and most bikes I've had will run for about 200-400 yards with what's in the float bowls. So it will start and run for a short while.
No fuel there? Carry on with diagnosing the fuel system upstream of the carbs.
Another branch is the electrical system. If you're getting a flat blue spark on all four plugs, you can expect that this is working well.
Still no life? I'd be looking at valve clearances. Depending on which way they tend to wander on your bike, they will either make the valves open less, meaning less air and fuel getting into the combustion chamber, or they will make them open more, resulting in low compression.
I think on your bike they will tighten up - meaning the open less. Combine this with a closed throttle and you don't have a lot filling your cylinders when you try to start it.
A compression test never hurts as well, if you have a tester.
Gypsy option, just for you. Hook up a car battery and crank it for ages. See if it catches.
I've had a couple of hondas that showed similar symptoms. One was my old NC24, it was just a dog. The other was my CB250RSA, which I also never fixed. Looking back I think it was the valve clearances, and the knackered battery didn't help.
Final thought - stop putting the airbox back on, you'll just be taking it off again. Faults like this always take ages to sort. In the end you'll have knocked the killswitch. |
| Kickstart |
 Kickstart The Oracle
 Posted: 15:31 - 23 Dec 2008 Post subject: |
Not sure on the exact layout of your bike, but as a quick try take off the fuel tank, and the fuel pump. Connect some fuel pipe to the carbs fuel intake (or just use the pipe from the pump to the carbs), put a small funnel in the end of it and put petrol into the funnel. Then try starting the engine. If it fires up then you know the problem is the feed for the fuel from the tank (ie, pump or its circuits).
The pump is there as the carbs are higher than most of the fuel tank. If the pumps is dead then as a very short term bodge you could probably remove the pump from the feed, run fuel pipe directly from the tank to the carbs and run the bike with the tank brimmed (just be aware it will probably stop running when there is still 2/3~3/4 of a tank of fuel left).
To check the cdi, best thing to do is probably to just crank it over and use a strobe light to check the timing.
The last post was made 17 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
