hiding and alarm in my airbox
adamcpi50sx08
PostPosted: 13:09 - 25 Dec 2008    Post subject: hiding and alarm in my airbox Reply with quote
do you think it will restrict the air flow at all if install the proccesor for my alarm in my airbox because at the moment that is the hardest place i think it would be for a theif to get to with out the keys, the proccesor box is the size of a credit card and about 3cm thick, thanks alot, adam
CR 125 (OFFROADER) - DEP PIPE ETC
CPI 50 SX 2008 - NO MODS YET EXCEPT FROM A SET OF ACERBIS HANDGUARDS
garyd
PostPosted: 13:32 - 25 Dec 2008    Post subject: Reply with quote
No problem Thumbs Up
CRF230 all you need
Alabama Blacksnake
PostPosted: 14:05 - 25 Dec 2008    Post subject: Reply with quote
Na i wouldnt of though there would have been a problem.
cheers tom
Bikes i've owned: mobylette ----- Ts 50er ------ GS 400e ------ CB250n superdream ------r6 ------ bandit 400 ----- 2005 kx 125
Bikes i have:dtr125 field bike that doesnt not seem to die!!! 1992 gsxr 750 Very Happy
trevoriv said: Leathers are like teenage girls, the tighter the better.
PostPosted: 17:24 - 25 Dec 2008    Post subject: Reply with quote
I'd worry a bit about it getting damaged. Not impossable for bikes to occasionally spit flames back through their carbs and you generally land up with a fair bit of oil and stuff lurking about in there.
Just put it somewhere that can't be easily reached and is out of the weather. Under the saddle is usually as good as anywhere.
My oppinion is that if they go as far as removing the saddle to get at it, they are stealing the bike no matter what you do. Hiding it further in just means they do more damage looking for it which you have to repair if the bike eventually turns up again. I don't use steering locks for the exact same reason.
tutton
PostPosted: 18:30 - 25 Dec 2008    Post subject: Reply with quote
Is the siren away from the processor, if the alarms situated in airbox too, would be quite useless. just a thought Laughing
I wouldnt put mine in, ive had sludge appear in there and bugs and just general grit, which i wouldnt want to smother electrically newfangery in.
garyd
PostPosted: 09:40 - 26 Dec 2008    Post subject: Reply with quote
Where does all this sludge /bugs /grit go to in your airbox Shocked
CRF230 all you need
tutton
PostPosted: 13:29 - 26 Dec 2008    Post subject: Reply with quote
It goes no where,
as theres a foam filter in there.... Laughing
funmonkee
PostPosted: 00:21 - 27 Dec 2008    Post subject: Reply with quote
I've heard of an alarm being put at the bottom of the battery box. Not sure that's a good idea myself, as battery boxes can trap water Thumbs Down
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
PostPosted: 00:43 - 27 Dec 2008    Post subject: Reply with quote
As well as being prone to getting battery acid spilled in them on occasion.
iooi
PostPosted: 07:22 - 27 Dec 2008    Post subject: Reply with quote
Bugs and bits get in through the air intake..... Sludge tends to come up throught the crankcase breather pipe that many bikes route into the airbox for emmisions reasons Wink
What about the inside of the headlamp for the card if its so small Thumbs Up
Pernig
PostPosted: 19:48 - 27 Dec 2008    Post subject: Reply with quote
wouldn't there be a heat issue there?
H100 Breaking for spares
salty21
PostPosted: 20:26 - 27 Dec 2008    Post subject: Reply with quote
just slap in on the tank... till be rate Thumbs Up
loply
PostPosted: 20:29 - 27 Dec 2008    Post subject: Reply with quote
First off, it's going to get oil and petrol fumes all over it, eventually leading to it failing.
Secondly, you'll achieve nothing by hiding it in there.
If somebody has the time and situation to be able to remove your seat/fairings to remove the alarm, you think putting it in the airbox is going to affect them? Ofcourse not, even an idiot could follow the wires there so it isn't hidden, and on a lot of bikes removing the airbox is easier than the tail fairings!
All in all, stupid idea, best not to bother mate... Under the seat or tail fairings.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Blue_SV650S
PostPosted: 21:41 - 27 Dec 2008    Post subject: Reply with quote
+1 ... its a bad idea ...
Also if it is a sports bike the airbox is 'tuned' in size and shape, sticking summin in there will change these properties ... its not going to stop the bike running, but it will stop the 'harmony'!! Thumbs Down
Cigaro
PostPosted: 16:16 - 28 Dec 2008    Post subject: Reply with quote
There's better places to put it than in the airbox. Just put it under the tank or under the seat.
The last post was made 17 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 87.34 Kb
