| Hutchysrs50 |
 Hutchysrs50 World Chat Champion
 Posted: 23:15 - 25 Dec 2008 Post subject: rs 50 or 2 stroke knowledge |
right my rs 50 is running crap, but that is NOT what i would like people to ask about...
reeeet!
would having NO airfilter on make it run Rich OR run Lean.
Only answer if you knwo the answer please, had people say the "THINK" or "HEARD" doesnt help me here, and its christmas and iv been drinking and its pissing me off.
or just leave a comment if you knwo about the Mixture screw on delotro 13mm 16mm 21mm (wich way does what)
Merry Christmas.... Ho Ho Ho...  ____________________ Gilera SC 125 - Current |
| RS2MATRIX |
 RS2MATRIX Spanner Monkey
 Posted: 23:17 - 25 Dec 2008 Post subject: |
Well, no air filter leaves a flood gate for air, so LEAN  |
| Hutchysrs50 |
| ms51ves3 |
 ms51ves3 Super Spammer
| Hutchysrs50 |
 Posted: 00:12 - 26 Dec 2008 Post subject: |
ahh you replyed to my other topic aswell, i shall give you some karma after this.
do you KNOW which way to turn the mixture screw to make is richer or leaner?
THANKS  ____________________ Gilera SC 125 - Current |
| ms51ves3 |
| Hutchysrs50 |
| ms51ves3 |
| Hutchysrs50 |
 Posted: 00:31 - 26 Dec 2008 Post subject: |
yeh i went back to check and found the same thing
But lets not play the blame game here....
dont you just love christmas... 23 minutes left of it aswell...
hope you enjoyed yours  ____________________ Gilera SC 125 - Current |
| Hutchysrs50 |
| Kickstart |
 Kickstart The Oracle
 Posted: 14:22 - 26 Dec 2008 Post subject: |
Running without a filter should make it leaner.
The idle mixture is adjusted with a screw normally, but there are 2 types. One lets more fuel in when you undo it, richening the mixture, the other lets more air through the idle circuit and undoing it leans the mixture. In either case only relevant on a closed throttle, or with tiny openings.
Needle may have a clip and a set of positions. Moving the clip down towards the pointed end of the needle means that the needle sits higher in the slide, and so for the same throttle position a narrower part of the needle is obstructing the fuel from the nozzle in the carb which gives a richer mixture.
| Hutchysrs50 |
 Posted: 14:27 - 26 Dec 2008 Post subject: |
| Kickstart wrote: | Hi
Keith |
Thank you
i asume you know alot of 2 stokes... so..
im running a 110 jet (as you may remember from my other thred) and i know its too big, but i cant get a smaller one for a while
anyway, im trying to "bodge" the fuel with the mixture screw, needle hight and idle screw... im also thinking about up-rating the oil flow aswell, after this the bike will be setup to run for an 80cc big bore kit, think it would run ok on a standard 50cc with 80cc settings?  ____________________ Gilera SC 125 - Current |
| Kickstart |
 Posted: 15:01 - 26 Dec 2008 Post subject: |
Oil pump won't make a massive difference. You can easily adjust it for a small difference though. No point in doing this in advance of fitting the 80cc kit.
The idle mixture screw, needle and main jet all control different parts of the throttle openings fueling. You cannot really use the idle mixture screw and needle adjustments to make up for a far too big main jet. Main jet basically controls the fueling at full throttle (which in a 50cc bike is going to be what you are on 90% of the time).
| Hutchysrs50 |
The last post was made 17 years, 292 days ago. Instead of replying here, would creating a new thread be more useful? |
