rs 50 or 2 stroke knowledge
Hutchysrs50
PostPosted: 23:15 - 25 Dec 2008    Post subject: rs 50 or 2 stroke knowledge Reply with quote
right my rs 50 is running crap, but that is NOT what i would like people to ask about... Mr. Green
reeeet!
would having NO airfilter on make it run Rich OR run Lean.
Only answer if you knwo the answer please, had people say the "THINK" or "HEARD" doesnt help me here, and its christmas and iv been drinking and its pissing me off.
or just leave a comment if you knwo about the Mixture screw on delotro 13mm 16mm 21mm (wich way does what)
Merry Christmas.... Ho Ho Ho... Neutral
Gilera SC 125 - Current
RS2MATRIX
PostPosted: 23:17 - 25 Dec 2008    Post subject: Reply with quote
Well, no air filter leaves a flood gate for air, so LEAN Mr. Green
Hutchysrs50
PostPosted: 23:18 - 25 Dec 2008    Post subject: Reply with quote
thanks jesus.
now, are you sure about this, not read it on a christmas cracker or made it up
PostPosted: 00:08 - 26 Dec 2008    Post subject: Reply with quote
Hutchysrs50 wrote:
thanks jesus.
Well what do you think? An airbox is more restrictive than none at all, so if there's less restriction to the air, more can flow.
Removing an air filter or airbox will make the bike run lean.
Hutchysrs50
PostPosted: 00:12 - 26 Dec 2008    Post subject: Reply with quote
ahh you replyed to my other topic aswell, i shall give you some karma after this.
do you KNOW which way to turn the mixture screw to make is richer or leaner?
THANKS Karma
PostPosted: 00:18 - 26 Dec 2008    Post subject: Reply with quote
THANKS Karma
On an air screw, you turn it clockwise to make the mixture richer (more fuel) and anti clockwise to make the mixture leaner (less fuel).
Hutchysrs50
PostPosted: 00:20 - 26 Dec 2008    Post subject: Reply with quote
THANKS Karma
perfect, as i thought, but i recall you saying difernt in my other topic
PostPosted: 00:26 - 26 Dec 2008    Post subject: Reply with quote
You recall wrong Wink
ms51ves3 wrote:
Turning the screw clockwise (in) will decrease the air flow on the idle circuit making the mix richer.
Hutchysrs50
PostPosted: 00:31 - 26 Dec 2008    Post subject: Reply with quote
yeh i went back to check and found the same thing Embarassed
But lets not play the blame game here.... Mr. Green
dont you just love christmas... 23 minutes left of it aswell... Thumbs Up Mr. Green
hope you enjoyed yours Very Happy
Hutchysrs50
PostPosted: 14:16 - 26 Dec 2008    Post subject: Reply with quote
Would you happen to know Which say on the needle hight settings does what Razz if you do, kinda give a step by step way of changing it... as some people say move the needle up, but mean the circlip up (putting the needle down)
chanks!
PostPosted: 14:22 - 26 Dec 2008    Post subject: Reply with quote
Running without a filter should make it leaner.
The idle mixture is adjusted with a screw normally, but there are 2 types. One lets more fuel in when you undo it, richening the mixture, the other lets more air through the idle circuit and undoing it leans the mixture. In either case only relevant on a closed throttle, or with tiny openings.
Needle may have a clip and a set of positions. Moving the clip down towards the pointed end of the needle means that the needle sits higher in the slide, and so for the same throttle position a narrower part of the needle is obstructing the fuel from the nozzle in the carb which gives a richer mixture.
Hutchysrs50
PostPosted: 14:27 - 26 Dec 2008    Post subject: Reply with quote
Thank you Mr. Green
i asume you know alot of 2 stokes... so..
im running a 110 jet (as you may remember from my other thred) and i know its too big, but i cant get a smaller one for a while Thumbs Down
anyway, im trying to "bodge" the fuel with the mixture screw, needle hight and idle screw... im also thinking about up-rating the oil flow aswell, after this the bike will be setup to run for an 80cc big bore kit, think it would run ok on a standard 50cc with 80cc settings? Embarassed
PostPosted: 15:01 - 26 Dec 2008    Post subject: Reply with quote
Oil pump won't make a massive difference. You can easily adjust it for a small difference though. No point in doing this in advance of fitting the 80cc kit.
The idle mixture screw, needle and main jet all control different parts of the throttle openings fueling. You cannot really use the idle mixture screw and needle adjustments to make up for a far too big main jet. Main jet basically controls the fueling at full throttle (which in a 50cc bike is going to be what you are on 90% of the time).
Hutchysrs50
PostPosted: 15:36 - 26 Dec 2008    Post subject: Reply with quote
Ok thanks, shame you didnt reply quicker, iv just had to push it home Mad
and its rather cold out!!
it was running fine for about a mile (away from home) at 1.1 mile (on way back) didnt wona know.... Rolling Eyes
The last post was made 17 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 86.9 Kb
