Pillion seat issue - rookie mistake!!
MG#43
PostPosted: 19:19 - 25 Jan 2009    Post subject: Pillion seat issue - rookie mistake!! Reply with quote
Hi,
A couple of years ago I swapped the standard seat unit of my bike with a race unit. In doing so I removed the cable and lock mechanism for removing the pillion seat. When putting the standard unit back on some time after I forgot to put back the cable and lock and snapped Rolling Eyes the pillion seat pad in place without thinking, the outcome, i can't remove the pillion pad so can't get underneath to do what I now need to do, which is replace the subframe due to damage. Any one got any tips? thanks! Laughing
Slinn84
PostPosted: 19:46 - 25 Jan 2009    Post subject: Reply with quote
I think a lot pf people have done the same thing. I did it my old GSX750F.
My solution was to simply order a new seat and then hacksaw off the old one. Once you can get under the seat you can just pull the mechanism to release the rest of it.
nightshaddow
PostPosted: 08:51 - 26 Jan 2009    Post subject: Reply with quote
depends on the bike sometimes you can remove some pannels and you can do it by that others you have to do as slinn said
Tristan.
PostPosted: 09:08 - 26 Jan 2009    Post subject: Reply with quote
What bike is it, on my FZR the rear light comes convieniently off and gives access. If you can;t be bothered to sort a new lock do what I do, and route the cable out the lock hole. Has worked fine so far.
Also instead of hacksawing through the seat you could also go through the undertray with a dremel or something, then patch the hole back up with duct tape. Though take care not to catch any wires (Or CDIs)
MG#43
PostPosted: 16:01 - 26 Jan 2009    Post subject: Reply with quote
Sv650k3. the lock is there, but the cable was removed the last time i took the seat off. I can get my hand underneath but the mechanism is inside what i can actually get my hands on. I need to check what I'm playing with on my other bike then try again I recon. I'd rather not have to hack saw it!! Confused Shocked
Sir Black Pig
PostPosted: 16:24 - 26 Jan 2009    Post subject: Reply with quote
If you can get your fingers on it, can you get a piece of thin wire at it to unsnap the lock/ pull the lock open?
Eurotrip 2009
Sportugal 2010
The last post was made 17 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 48.77 Kb
