Grooming Question
Renton
PostPosted: 00:36 - 24 Feb 2009    Post subject: Grooming Question Reply with quote
OK so this is mainly aimed at the guys here, but ladies, if you have any info you'd like to share, please feel free.
Does anyone else suffer from in growing hairs after they shave?
I try to avoid have a full wet shave as much as possible because when it grows back I get loads of in growing hairs on my neck....and they are fucking irritating. I find it very un pleasant because when they grow inwards and get infected they end up as a spot.
I've heard all the usual "exfoliate", "use a special razor", "wash your face before", tips that are supposed to work. Well my brother does all of them!! I honestly wouldn't want to know how much it all costs, because it still doesn't work.
So does anyone have a 'routine' that seems to prevent them?
I'm currently using tweezers to remove the offending hairs, but that's no massage.
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
Itchy
PostPosted: 00:45 - 24 Feb 2009    Post subject: Reply with quote
Dry shave with a leccy razor? , they don't give a very close shave and thus avoid in grown hairs....
You could always get a shave like they do in Iran ie thread it out.
Renton
PostPosted: 00:53 - 24 Feb 2009    Post subject: Reply with quote
My preferred method is my beard trimmer, when I can be bothered, and take it down very short and it's quite a decent one so it's not a half arsed attempt. But I find even with that they still occur, just not as much.
ncrn
PostPosted: 01:02 - 24 Feb 2009    Post subject: Reply with quote
Mine is to have a very hot shower before hand, make sure it is a fairly long shower as well so all of your pores loosen up, really clean your face as well. Then as I get out start filling the sink with very hot water, and put some decent quality shaving foam on and massage it in well.
Then make sure the razor is cleaned well in the water and heated a bit and carefully shave, don't put a lot of pressure on just try to glide over the face.
When its all gone clean your face with hot water, then straight after splash all over with cold water. Its a bit of a shock but it helps, I then use some aftershave balm and job done.
Are you shaving with or against the grain of your hairs? You can tell by running your hand over your face and feeling for the rougher direction of travel.
Shaun
Likes 'em bent
PostPosted: 01:09 - 24 Feb 2009    Post subject: Reply with quote
Confused
I get in the shower, get out, shave, whack on some after shave, done. Never had a problem with ingrowing hairs or shaving rash.
I'm a man.
Renton
PostPosted: 01:13 - 24 Feb 2009    Post subject: Reply with quote
I tend to have odd cleaning habbits, a routine of the way I do things (I won't elabirate), but in short I shave first, then have a shower.
I've always wanted one of those old shaving brushes (not sure of the name of them). They look like a make up brush but it's oviously for massaging in the shaving foam/cream/gel.
https://img.alibaba.com/photo/11249110/Shaving_Brush.jpg
And maybe a cut throat to go along with it Smile
Whenever I do have a proper wet shave I do use Nivea (for men Very Happy ) after shave balm for sensitive skin....crap. My sister bought me sum years ago and have always used it.
I'm not sure which way you'd call which, but I shave up the neck, and down the cheeks. If that makes sense.
Renton
PostPosted: 01:15 - 24 Feb 2009    Post subject: Reply with quote
Shaun wrote:
Confused
I'm a man.
I've seen pictures of you, don't flounce around here with your brass ones on lol.
Tarmacsurfer
PostPosted: 01:37 - 24 Feb 2009    Post subject: Reply with quote
That's likely a major contributor. As others pointed out up the thread, heating the face either with steam, a hot towel or simply hot water in the shower makes the pores open and the stiff short hairs softer, meaning they'll cut rather than get driven back into the skin as the razor is drawn across.
As to using a cut throat, if you're prepared to spend the time then it does give a good shave.
My favoured razor is currently the "Fusion" thingy, much as it irks me to lend credence to the advertising it's the best I've found yet. Usually used with Gillettes "sensitive" gel as my skin reacts to alcohol badly. If I try using aftershave or suchlike then I spend the following week looking like I've been slapped in the face with a very hot pizza.
I'm immortal. Well, so far.
Azonicben
PostPosted: 01:44 - 24 Feb 2009    Post subject: Reply with quote
I normally grow a half arsed beard then get a proper cut throat shave at the barbers with my hair cut
Renton
PostPosted: 01:50 - 24 Feb 2009    Post subject: Reply with quote
I had a wet shave earlier and I did try to wash my face with hot water before hand (I always try to do it when wet shaving). Maybe I just need to keep the hot water on there longer. I guess it doesn't help that my facial hair is almost as thick as me.
I think if you can shave well with a decent cut throat then you've got an art.
I don't bother with all those 17 blade high mark up gizmos. Simply because I watched a programe few years back about shaving and "Britains Best Barber" said that you honestly don't need that many blades, any more than two is a waste.
panrider_uk
PostPosted: 10:43 - 24 Feb 2009    Post subject: Reply with quote
I was having the same problem with the occasional ingrowing hair.
I tried the Fusion razor and it is very good (as long as you switch the vibrating head on).
As said, shower before you shave to heat up your skin.
Mark
mooserx
PostPosted: 10:55 - 24 Feb 2009    Post subject: Reply with quote
the best way i found to avoid ingrowing hair is thus.
exfoliate first,
trim to stubble
soak face with hot flannel
rub some vaseline onto the beard to really open pores and soften hair
apply proper shaving soap with a brush, none of this gel crap
shave with the grain of your beard in long strokes
rinse razor after each stroke
rinse face well
cold flannel on your face to close pores
apply good moisturiser, i use clinique but nivea etc is fine
as for type of razor its personal preference but i prefer fewer blades so use a double bladed razor, usually one of the cheap bic/gillette ones, i don't like these fancy cack handed affairs with 200 blades and electronic pulses, they look like footballers use em.
also the barber will only use 1 blade when he uses a cut-throat.
i suppose the secret is to open your pores and soften your whiskers as much as possible.
or just grow a beard.
TL1000r-handful.
mooserx
PostPosted: 10:58 - 24 Feb 2009    Post subject: Reply with quote
you can get em from superdrug cheap as chips, they are the best thing for applying shave soap as they massage your face and open your pores.
TL1000r-handful.
Mr.Everready
PostPosted: 11:35 - 24 Feb 2009    Post subject: Reply with quote
The shower route is the best option. I actually shave while in the shower, plenty steam and hot water on the go all the time.
PostPosted: 12:35 - 24 Feb 2009    Post subject: Reply with quote
mooserx wrote:
exfoliate first,
trim to stubble
rinse face well
Now with 30% less gay.
Nicky-Jano
PostPosted: 13:45 - 24 Feb 2009    Post subject: Reply with quote
Try hair conditioner, I did and after a few weeks I noticed a big difference.
Skin felt softer and less irritated.
It just forms a more lubricated barrier between the skin and razor than normal shaving foam does.
So it stops the razor irritating the pores and slides over the skin easier.
Also use warm water it opens up the pores more so hair doesn't get trapped inside.
JonB
Afraid of Mileage
PostPosted: 14:26 - 24 Feb 2009    Post subject: Reply with quote
I found the Fusion to be absolute cack and gave an uncomfortable shave. The best wet shave razor I have used so far is a Mach 3. I did buy a Wilkinson Sword for cheapness of replacement blades but there blades aren't very well designed and hairs get stuck inbetween them.
Tonka
PostPosted: 15:39 - 24 Feb 2009    Post subject: Reply with quote
Helpful Linky?
I watched that 10 Years Younger programme the other week and it had a fella on there. They took him off to the Barber for a proper shave and the strict no-nos were tweezing and shaving against the hair growth Rolling Eyes
Kwaks
I'm not a fast rider
PostPosted: 16:20 - 24 Feb 2009    Post subject: Reply with quote
Was gonna say, always shave in the direction of growth, I have lost count of the times I have seen people shave under the chin against the growth Rolling Eyes
And, yes use hot water to wet face before lathering, but it is essential that you use cold water to rinse off the razor during, hot will blunt it.
www.cliqueycuntsmcc.co.uk
JonB
Afraid of Mileage
PostPosted: 16:32 - 24 Feb 2009    Post subject: Reply with quote
Which way is with the hair growth? I shave downwards from my chin, is that right?
iooi
PostPosted: 19:24 - 24 Feb 2009    Post subject: Reply with quote
Simple answer.. Laughing
Don't shave. Rolling Eyes
Grow a beard Thumbs Up
PostPosted: 23:18 - 24 Feb 2009    Post subject: Reply with quote
Agreed. Stop being such a pussy-whipped metrosexual and grow a beard like nature intended.
steppen22
PostPosted: 03:02 - 25 Feb 2009    Post subject: Reply with quote
I shave in the shower - saves time cleaning up too, straight down the drain hole. No mirrors, obviously, but I know my own face well enough to do the job.
I also take my electric toothbrush in the shower - brush teeth whilst rinsing hair.
Occassionally I bang one off in the shower too. Again, straight down the drainhole, wash while you wank.
It's all about saving time. No one - man or woman - should spend more than 30 minutes a day doing all this shit. After 30 minutes in the bathroom, a woman's attractiveness increases minute byminute, but a man's decreases.
This is despite of all your daft "manly" products with their daft "manly" brandnames. The health and beauty industry is trying to colonise the male body - given masculine names, and a masculine tone to tradiotnal female products there's no further area of the female body to exploit (where to go after scented pussy sprays? It's all been done now).
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
Renton
PostPosted: 21:52 - 25 Feb 2009    Post subject: Reply with quote
iooi an stinkwheel.....you hippies lol. I have a 0.5 hair cut, I'm not about to grow a beard to look like Captain Spalding.
Tonka, thanks for that. The narrators accent was very annoying, but the information was helpful none the less.
As I shaved the other night, my neck is now covered in the mutant hairs. I'm not so fussed about the pain of them, this I can deal with, but I'm a bit of a clean freak and I hate that it looks like I'm covered in dirty spots....when they are not just spots.
mooserx, ta, shall try an get down there to see what is available.
Would reply to the rest who have posted but I've got to go out.
Thanks for all the info and tips guys (and gal) Thumbs Up .
superstacker
PostPosted: 22:16 - 25 Feb 2009    Post subject: Reply with quote
Surely i wasnt the only person who thought this was a thread about entraping underage girls on the internet??!
I'll get my coat Razz
The last post was made 17 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 133.99 Kb
