Breaking and entering
 Topic moved: from Random Banter to Dear Auntie BCF... by G (24 Feb 2009 - 23:10)
mistergixer
PostPosted: 20:30 - 24 Feb 2009    Post subject: Breaking and entering Reply with quote
The key to the door of my shed is lost, predictably the door is locked.
The door has a fairly sturdy mortice deadbolt lock, the shed also has windows.
Any ideas on the best method (i.e least damage) to use to break into the shed?
Space Monkey #7
Quote Me Happy
PostPosted: 20:31 - 24 Feb 2009    Post subject: Reply with quote
Nuke it from space.
Dragonfly
PostPosted: 20:43 - 24 Feb 2009    Post subject: Reply with quote
Wooden or steal shed?
Skudd
PostPosted: 20:44 - 24 Feb 2009    Post subject: Reply with quote
Use the back door.
Polo
PostPosted: 20:45 - 24 Feb 2009    Post subject: Reply with quote
Unscrew the hinges?
My mum smells your fingers
Shaun
Likes 'em bent
PostPosted: 20:55 - 24 Feb 2009    Post subject: Reply with quote
Angle grinder, I bought one a while back, it's amazingly useful!
PostPosted: 21:07 - 24 Feb 2009    Post subject: Reply with quote
If they're visible, hacksaw the tops of the hinge pins off and drive them out with a nail.
mistergixer
PostPosted: 21:31 - 24 Feb 2009    Post subject: Reply with quote
It's a wooden shed, and it's not stolen.
Space Monkey #7
tutton
PostPosted: 21:58 - 24 Feb 2009    Post subject: Reply with quote
Hows it locked, if its like most normal sheds its just a sliding bolt on the front door, then a padlock over it to stop it moving if so, the screws for the bolt lock are usually on the outside, just unscrew the small metal bit furthest away from the bolt shud open fine then
pablouk
PostPosted: 00:07 - 25 Feb 2009    Post subject: Reply with quote
I once watched a programme where they had to build a machine that could smash its way into a shed(I think?)
Build one of them.
They are great.
Keeping The Nation Pissed
Do not anticipate trouble or worry about what may never happen. Keep in the sunlight. ~Benjamin Franklin
PostPosted: 00:16 - 25 Feb 2009    Post subject: Reply with quote
How many levers does the key have?
If it is a cheap two lever one, there are probably under 30 different keys. Ask your mates for a go of their keys.
Ichy
PostPosted: 00:34 - 25 Feb 2009    Post subject: Reply with quote
No messing about.
Smash the glass and then replace it with perspex for less than a tenner.
Itchy
PostPosted: 00:39 - 25 Feb 2009    Post subject: Reply with quote
Just tear the door off its hinges if its a wooden one, now just put the hinges on the other side of the the door opening to repair it.
Pedd
PostPosted: 00:50 - 25 Feb 2009    Post subject: Reply with quote
As has already been said do the hinges, if there on the inside just go thru window and do em
Dont Click HERE
Current modes of transport = 125 superdream (in bits atm), 1978 GS750 chop, bandit 600(main one), 1982 bmw r100rs,
cx500 trike (hey its fun) oh and the car to ferry the missus and dogs around Smile
steppen22
PostPosted: 03:06 - 25 Feb 2009    Post subject: Reply with quote
Pick the lock perhaps?
It's worrying easy to do.
Start here.
https://www.scribd.com/doc/7207/CIA-Lock-Picking-Field-Operative-Training-Manual
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
Sparks!
Sir Tart-a-lot
PostPosted: 03:14 - 25 Feb 2009    Post subject: Reply with quote
Cut a man-shaped hole in the side with a chainsaw Thumbs Up
iooi
PostPosted: 07:13 - 25 Feb 2009    Post subject: Reply with quote
tutton wrote:
Hows it locked,
How hard is it to read 3 lines...... Rolling Eyes
I would go for the window route and then remove the lock from the rear of the door.
V2
PostPosted: 07:14 - 25 Feb 2009    Post subject: Reply with quote
80mm mortar round, remember to stand well back Thumbs Up
bazza
PostPosted: 10:03 - 25 Feb 2009    Post subject: Reply with quote
Phone the cops from a call box and say there's a swarthy chap with a beard and a rucksack hiding inside your shed. And you definitely saw wires. And a gun. And heard the word "jihad".
Annabella
Like a person, only smaller
PostPosted: 10:57 - 25 Feb 2009    Post subject: Reply with quote
Do as I did to break into a villa in Portugal...
Take the panes of glass out of the windows (provided it's single glazing) Thumbs Up Just gently lever off the beading and pop the glass out. You will, of course, need some silicon sealant to replace the glass... which I found in the swimming pool shed thing, but didn't have a gun so had to try and reapply using a broom handle.
Avast! Pirates ahoy!
I did Cadwell! Very Happy
Dragonfly
PostPosted: 11:35 - 25 Feb 2009    Post subject: Reply with quote
pfft easy............ burn it down Mr. Green
cyberglass
PostPosted: 13:41 - 25 Feb 2009    Post subject: Reply with quote
If you can see the actual bolt of the lock take a hacksaw blade wrap the end in some kitchen roll and tape to make a handle and saw through it it shouldnt take to long to get through
Or go the quick route and use an angle grinder
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
pa_broon74
PostPosted: 17:23 - 25 Feb 2009    Post subject: Reply with quote
This sounds like a great night out... Laughing
Find a really fat person and tell them there are doughnuts inside...
Or...
If the dead bolt and reciever are screwed or bolted to the door (as opposed to being part of the door itself.) Drill holes through the wood and with a sturdy bolt and a hammer just whack away until the lock etc parts company with the door and fall away on the inside.
Outside dead bolts are hard to pick, they tend to be corroded and stiff. Yale locks are peice pf piss to defeat, in fact you don't even need to pick them. Take a carpenters saw (flat bladed) and just gently whack it through the wooden door surround level with the lock...
Didn't catch anything.
Annabella
PostPosted: 17:47 - 25 Feb 2009    Post subject: Reply with quote
Who said anything about night?! This was after three months backpacking around Morocco mostly sleeping on beaches and streets, a very long journey by land to Portugal, a day's walk from the nearest bus stop and a big bite off a very evil spider that had hitchhiked in my luggage - I was desperate to get in!
pa_broon74
PostPosted: 18:48 - 25 Feb 2009    Post subject: Reply with quote
Mmm...
Not so good. It still sounds like something I'd be doing at 3am while half cut.
The last post was made 17 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.82 - MySQL Queries: 16 - Page Size: 131.31 Kb
