Toughness of clutch
kawashima
PostPosted: 00:48 - 22 Mar 2009    Post subject: Toughness of clutch Reply with quote
I practised wheelying and some slalom ridings on my W650 a little bit harsh, now this is the second time I have to ask changing my clutch Thumbs Down
I posted in a japanese W650 forum and asked if they have had same troubles, but most of them replied to me saying "YOUR RIDIGN IS WRONG!"
I got typical expected responses and now I am disappointed Thumbs Down
What I feel is
-clutch spring is too soft (since it was new)
-I couldn't find any tougher clutch kit for this bike.
Please post any thing about clutch.
-How many times you have changed clutch?
-What caused the damage to your clutch?
-If you use tougher clutch kit, what is it like compared to normal one?
p.s. mechanic said they might have to change clutch housing and hub and others too due to the damage when I first burnt the clutch. They suggested me to buy a new bike Shocked . There's no good bike in kawasaki line up. I want 800-900cc class but kawasaki doesn't have any. I hope honda makes VFR800 street fighter someday. Why did I buy W650? Because I was too short for DL650, and it was my mistake.
own:2020 Serow 250
MaybeGuy
PostPosted: 02:42 - 22 Mar 2009    Post subject: Reply with quote
i dont really know how any sort of riding would burn out a clutch.
i've had my GSXR over a year now, got just short of 33000 miles on it, and as far as i know, is on the original clutch (was on 21000 when i got it).
the abuse i've put it through, thousands of wheelies, racing starts etc, and it hasnt begun to slip at all.
i would say its a fault of some sort, or general bad maintenance that caused it.
if your clutch feels light, chances are the springs are too soft, or some have fallen out.
replace them with heavier duty ones.
kawashima
PostPosted: 03:01 - 22 Mar 2009    Post subject: Reply with quote
I was doing balance practice on the road paint for about one hour and my clutch began to smell strange. (Keep reving with rear brake on) That was too bad for clutch.
I'm going change springs too. I'll keep searching for stronger springs.
own:2020 Serow 250
MaybeGuy
PostPosted: 03:08 - 22 Mar 2009    Post subject: Reply with quote
its a wet clutch, so it should put up with it no problem. have you checked your oil level?
kawashima
PostPosted: 03:30 - 22 Mar 2009    Post subject: Reply with quote
Thanks for your replies.
Yesterday I changed to new oil at the shop, and it was still sliding, so I asked the shop guy to ride my bike. He was saying "this is something wrong with this clutch. It's sliding in 5th gear".
Now my bike is at the shop. I telephoned the shop now, he said he is asking other riders to check how they feel the clutch, before they open the clutch. But it's rainy today, so they'll test tomorrow.
He said he'll contact me what parts is necessary before he order.
own:2020 Serow 250
MaybeGuy
PostPosted: 03:33 - 22 Mar 2009    Post subject: Reply with quote
the damage could have been cause by the oil level being too low previously. if it is slipping, you'll need new friction plates most likely. costing around £40 for a full set.
kawashima
PostPosted: 03:42 - 22 Mar 2009    Post subject: Reply with quote
Thanks, I hope I don't have to change housing and hubs too. I changed whole friction plates after I burnt them, I tried not to damage them after that, but they started sliding again Confused .
Mechanic also know this and he was wondering like me.
own:2020 Serow 250
PostPosted: 09:32 - 22 Mar 2009    Post subject: Reply with quote
Sounds like you have worn the clutch out with your antics. Repeated slipping of the clutch under power WILL wear it out because that's what it's designed to do.
Be aware that every bit of metal and fibre you wear off your clutch will get suspended in your oil and travel around the engine with it wearing out other parts. You might also have notched the clutch basket with the repeated abuse.
The guys on the W650 forum are kinda right - the reason it's slipping is because of the way you have treated it - whether that's right or wrong is up to you and your wallet to decide.
PostPosted: 10:08 - 22 Mar 2009    Post subject: Reply with quote
I've had similar issues in the past; were the metal plates 'blued'?
This seems to make them extra-slippy.
Either new metal plates, or for a start you could try roughing them up slightly with sandpaper.
While they're not quite in the capacity range you want, surely both the Z750 and Z1000 are quite similar to what a VFR800 streetfighter would be like?
I wouldn't get too hung up on capacity - I've ridden a 1300 that had less power than my 250 at the time Smile.
Incidentally, clutches aren't too hard to do your self if you've got a few tools - in some cases you do need air/electric impact wrench, but not for the Kawasakis I've done.
I wouldn't have thought slow speed slipping like that should do damage to the clutch basket really, even drag starts etc don't seem to be a big issue. Aggressive wheelies are more likely to, however.
kawashima
PostPosted: 10:46 - 22 Mar 2009    Post subject: Reply with quote
I regret I was damaging my bike. I changed oil 2 times so I really hope there's no bits of metal anymore. That practise costed me a lot really. This is my fault.
G wrote:
you could try roughing them up slightly with sandpaper.While they're not quite in the capacity range you want, surely both the Z750 and Z1000 are quite similar to what a VFR800 streetfighter would be like?
Thanks for a technic! Oh yes I had forgotten Z750. That's nearly 800 class Smile . I need to save more money before buying next bike Smile
own:2020 Serow 250
cyberglass
PostPosted: 13:27 - 22 Mar 2009    Post subject: Reply with quote
Mate you can get lowering kits for the DL650 that bring it down 25mm or 50mm . Mr. Green there not to expensive around £15 and can be fitted in about 10 minutes.
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
kawashima
PostPosted: 14:58 - 23 Mar 2009    Post subject: Reply with quote
Please let me ask one more question!
I found a clutch kit for W650.
https://www.barnettclutches.com/products/clutch_plates_springs.aspx?type=clutches_other&clutch_make=Kawasaki&clutch_cc=650
I asked the mechanic if they can purchase this and fit it, they responded it's possible but clutch life is shorter than normal.
Is this true?
own:2020 Serow 250
Cigaro
PostPosted: 12:22 - 24 Mar 2009    Post subject: Reply with quote
What kind of oil are you using? Some oil can make it slip.
kawashima
PostPosted: 12:26 - 24 Mar 2009    Post subject: Reply with quote
I've used SJ class kawasaki genuine oil, and this time I changed to Nutec one. It was suggested by the shop. I don't remember the detail of Nutec oil. Price was between SJ one and Motul 300V.
own:2020 Serow 250
PostPosted: 12:29 - 24 Mar 2009    Post subject: Reply with quote
Is this true?
I wouldn't worry too much about the clutch life - I doubt it'll be that much shorter.
What is important, I'd say is to either replace or fix the metal plates - clutch life will definitely be shorter if there's a problem with these.
In the end clutch metal and friction plates are 'consumables' - just like tyres and brake pads. You could ride really slowly everywhere and try and use the brakes as little as possible, which would save you some money in tyres and brake pads.
However, it's not nearly as fun and presumably you're paying some money to have a bike for the fun it gives you, so might as well pay a little extra to make full use of it Smile.
(Though, trying to achieve the same thing with less clutch-slipping might be worth it!)
kawashima
PostPosted: 12:35 - 24 Mar 2009    Post subject: Reply with quote
Thank you! Very insightful post.
own:2020 Serow 250
jack_zxr400
PostPosted: 12:43 - 24 Mar 2009    Post subject: Reply with quote
sounds like you'll need to change the clutch plates and oil again :/
get it working again and sell it
then buy a nice second hand z750 Smile
Previous Bike: ZXR 400
Current Bike: R6
Test Date: 8/8/2008-PASSED
cyberglass
PostPosted: 12:44 - 24 Mar 2009    Post subject: Reply with quote
Kawashima just noticed you had a LSR125 what is parts support like over there had to get rid of mine after a small accident because i couldnt get parts Crying or Very sad
Cracking bike loved it to bits Mr. Green
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
kawashima
PostPosted: 12:57 - 24 Mar 2009    Post subject: Reply with quote
Shop guy said, he can reuse the filtrated Nutec oil. I don't have to dump 7000yen. I will buy Z750 or some decent bike someday!
Hi, as far as we buy from honda shops which have relation to endurance, we can buy necessary parts. But LS125R production has already finished so parts for LS won't be supplied for that long. When I ordered brake lever and clutch lever for spare, I waited more than 1 month Shocked .
own:2020 Serow 250
Moonie
PostPosted: 13:02 - 24 Mar 2009    Post subject: Reply with quote
800-900cc Kwakers.
ZX-9R anyone?
jack_zxr400
PostPosted: 13:04 - 24 Mar 2009    Post subject: Reply with quote
not unless they did a streetfightered one >.<
Current Bike: R6
Moonie
PostPosted: 15:14 - 24 Mar 2009    Post subject: Reply with quote
Must remember to read threads properly.
The last post was made 17 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 125.87 Kb
