Bike in gear but not moving
AJ
PostPosted: 13:35 - 08 Apr 2009    Post subject: Bike in gear but not moving Reply with quote
HI just changed chain & sprockets, put everything back in correct order, and double checked. Now the bike will not pull forward when in gear. I can even move the rear wheel by hand when the bike is up on its centre stand and in gear.
The bike is an 97 bandit 600 S.
Any input would be great thanks AJ
PostPosted: 13:53 - 08 Apr 2009    Post subject: Reply with quote
Is your front sprocket done up to the correct torque and is it into the splines on the output shaft properly?
AJ
PostPosted: 16:19 - 08 Apr 2009    Post subject: Reply with quote
Thanks for reply big ham, evertything torqued down correctly. I pulled front sprocket towards me by 2mm and that seems to have done the trick. Just did a 25 mile test along b and a roads and working fine. Again thanks for your input AJ
PostPosted: 21:24 - 08 Apr 2009    Post subject: Reply with quote
Umm did you just move the sprocket by hand to make it work? If so then you need to take a closer look - I sense impending doom!
sickpup
Old Timer
PostPosted: 23:34 - 08 Apr 2009    Post subject: Reply with quote
Was there a spacer on the rear of the original front sprocket? If not you are in for some wallet pain.
Ariel Badger
PostPosted: 23:46 - 08 Apr 2009    Post subject: Reply with quote
If the sproket is only on the shaft by2 mm things will turn into swarf.
I agree with Geri and the Pup. вы имеете проблему
Vin
PostPosted: 08:15 - 09 Apr 2009    Post subject: Reply with quote
No reply from the OP Neutral
Davie_G71
PostPosted: 14:26 - 09 Apr 2009    Post subject: Reply with quote
I'm sorry - but i can't believe he thinks that this is a solution?
This could end in tears and pain, if it hasn't already.
Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003.
ZRX61
Victor Meldrew
PostPosted: 19:28 - 09 Apr 2009    Post subject: Reply with quote
Great! front row seat. Pass the popcorn Cool
Handsome
PostPosted: 19:44 - 09 Apr 2009    Post subject: Reply with quote
Right, first things first...When you've put it in gear, are you letting the Clutch out ?...
Vin
PostPosted: 22:41 - 13 Apr 2009    Post subject: Reply with quote
Well I guess it resulted in a big crash! Crying or Very sad
Davie_G71
PostPosted: 08:42 - 14 Apr 2009    Post subject: Reply with quote
Very worrying actually. He seems like a regular poster, does anyone have a number for him?
PostPosted: 16:58 - 14 Apr 2009    Post subject: Reply with quote
Is this a case of deja-thread? He did exactly the same thing 6 months ago AND worked out what was wrong!
https://www.bikechatforums.com/viewtopic.php?p=1966474
Step-away from the spanners AJ...
The last post was made 17 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 78.04 Kb
